Old 02-25-2002, 01:31 PM
Hellred's Avatar
Rides:2003 BMW M3
Hellred is a New Registered Member
Clunk when shifting hard in the M coupe
Anyone experience this. Sounds like a diff or tranny mount. Anyone have any feedback?
Thanks,
Greg
Old 02-25-2002, 01:38 PM
Rides:'99 M3
The Judge is a New Registered Member
I know some of the new BMW's like the M3 have a clunking noise in the differential, but it's perfectly normal.
Judge
Old 02-25-2002, 01:42 PM
Hellred's Avatar
Rides:2003 BMW M3
This is a 99 though. Not exactly new. New to me
Old 02-25-2002, 01:49 PM
Rides:'99 M3
Im willing to bet that it is the same technology as the newer ones. Mine also makes an occasional clunking noise. But its usually easy to tell if it is from the diff. It will happen speeding up out of corners and when you switch gears.
Judge
Old 02-25-2002, 02:25 PM
Rides:325is, 1993
Dudenarley is a New Registered Member
It might be the tranny
My dad has a new M3 and the shifts are a bit noisy sometimes. Alot of high performance cars like ferraris do it as well.
Old 02-25-2002, 03:15 PM
Rides:1998 M3/4 Techno Violet
rhyswynn is a New Registered Member
I get that sometimes in first and second, maybe a little bit in third...not even when shifting hard, it seems like when I disengage the clutch really fast, its strange.
So that is fairly normal for M's? Good, I thought something was wrong...haven't noticed it the last few days though.
Old 02-25-2002, 05:05 PM
Rides:95' M3
IlllIlI is a New Registered Member
yea i notice this when disengaiging the clutch quickly too, i think it could be one of the following..
loose diff. mounts
worn diff. mounts
worn flex disk (gubio)
this weekend i'll re-torque the diff. mounts and let you all know if it solved the clunking problem..
hrcoilovers eibachsways aashocktowerbrace aassk 97+nose spalfan
Old 02-25-2002, 05:40 PM
SG_M3's Avatar
Rides:#56 IP M3
the clunk in the new m3 is due to the m variable lock diff. So a clunk in a s52 car would not be normal.
Sean
Old 02-25-2002, 06:13 PM
Rides:95 Turbo M3
Tampaturbom3 is a New Registered Member
!!!!!!!! if you are getting a "clunk"when accelerating and decelerating, it may very well be a broken subframe. I broke a diff bolt and then it separated the steel that makes the subframe. the bolt breaking will cause a clunking noise too (ask Jon Caldito, his did this too). I would take it to the dealer and have them inspect the subframe. Mine broke where the subframe mounts to the car in the rear, drivers side spot. on the top, the steel separated at the seam. it's hard to see it unless you know what you are looking/feeling for. If it is this and you drive you will most likely contort the differential to where it damages the 1/2 shaft and other components (ask me how i know). if it's the bolt, and i hope that it is, it's an easy fix. the 99's bolts are prone to this (ask jon).
another clunking noise can be the shock tower mount, but that would clunk on hitting bumps, not on acceration or deceleration. if the noise is closer to the front, then the driveshaft ujoint (carrier bearing area) is probably shot.
i'm betting on the diff bolts
Tommy
95 AA turbo m3
11.801 @ 119.36 1/4 mile
daily driven, stock looking
Old 02-25-2002, 06:40 PM
Rides:'99 M3
I agree with SG M3. It has to do with the limited slip. Happens in anything from Camaro to Aston Martin. Completely normal.
Judge
Old 02-25-2002, 07:03 PM
Rides:'99 M3
I doubt that would be a problem NA cars. Offcoarse your going to bust something with the power you have.
Judge
Old 02-25-2002, 07:26 PM
Hellred's Avatar
Rides:2003 BMW M3
I've experienced a broken subframe on my 325, and now every car I buy, I check for signs of that. My technician buddy checked the car for that on the lift prior to purchase. We loaded the diff up my keeping the brakes applied, and loading and unloading the drivetrain repeatedly to see what was clunking, but there was nothing apparent.
The car will be going in for a few warranty items, and I'll have my buddy poke around some more.
I'd like for them to figure it out prior to modifying the car. We all know how dealers get when they see mods...
It does occur with quick shifts.
Sounds like a bad mount or a worn bushing...
Thanks for the feedback.
Greg
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692
