Go Back   DTMPower BMW Forum > Technical Discussions > Z-Series
Old 04-10-2006, 07:18 AM
Scott May's Avatar
Custom User Title
Rides:e36 325i, e30 m3, e36 m3, nothing
Scott May has achieved their Master LicenseScott May has achieved their Master LicenseScott May has achieved their Master LicenseScott May has achieved their Master LicenseScott May has achieved their Master LicenseScott May has achieved their Master LicenseScott May has achieved their Master LicenseScott May has achieved their Master LicenseScott May has achieved their Master LicenseScott May has achieved their Master LicenseScott May has achieved their Master License
tckline carbon roadster
dont know if anyone has talked about this before (i tried searching but the search now adays is complete not usefull).
BMW Tuner and Sport Car Racing Team, TC Kline Racing Inc. is proud to introduce the Carbon Roadster, the first complete car offered by the company. The Carbon Roadster is a focused ultra high performance sports car based on the already excellent dynamics of the BMW Z4. TC Kline’s passionate adherence to the fundamental principals of light weight and dynamic performance has resulted is a true sports car.
The Carbon Roadster weights 2,680 lbs., has 346 hp and corners with 1.06G grip. Take a minute to soak that in. The CR weighs 150 lbs. less than a Honda S2000, has the HP of a Porsche 911, and has wider wheels and tires than a Ferrari F430. Incredibly, the CR weighs 700 lbs. less than a BMW M3 while maintaining the same power.
The Body; The entire skin of the CR is manufactured from Carbon Fiber Composites. The changes to the Z4 bodywork are a direct result of the application of the principals of "form follows function". Walk around the CR and you will not find any body lines which do not serve as an extension of function. The Carbon Roadster body work incorporates aerodynamic performance enhancements with a front air dam, front wheel house vents, side skirts, and rear diffusers. The body also has all four fenders flared I" to accommodate wider wheels and tires. The use of carbon composites to make the body reduces the weight of the CR tremendously while maintaining a strong durable skin.
Interior: TC Kline has contracted with Recaro to produce a one piece shell performance seat specifically for the CR upholstered in Alcantera and Leather. These light weight performance seats feature cutouts for a driver harness and will have exceptional support while maintaining excellent driver comfort. These Recaro/TC Kline seats are similar to those found in the E46 BMW M3 CSL or the Porsche Carrera GT.
The Drive Train: On the 25th of October, 2005, BMW AG introduced the Z4 M Roadster. The Z4 M Roadster incorporates the E46 M3 Drive train. The TC Kline CR is based on that car and shares its 3.2 liter motor, 6 Speed Transmission and M Lock Differential. TC Kline upgrades the drive train with an Aluminum flywheel for quicker throttle response, improved acceleration and lighter weight. TC Kline has also developed a thin wall stainless steel exhaust system for the CR. This exhaust system is significantly lighter than the stock system, improves horse power by 13 and has the outlet in the center of the rear bumper between the two Carbon Fiber Diffusers.
The Suspension: KONI Double Adjustable Coil-Over struts and rear shocks valved to TC Kline Specifications are already accepted by the BMW enthusiast as the standard for street and track performance and directly contribute to the 1.06G cornering grip the CR develops. The suspension springs for the CR are made in Germany from a light weight alloy steel and TC Kline has a variety of spring rates available which allow the owner to tune the CR to their personal taste. The CR front struts are topped off with TC Kline designed front Camber Plates for quicker turn-in and steering feel and Delrin bushings replace the standard rubber bushings in the front lower arms and rear trailing arms for quicker response and markedly improved feel. These TC Kline components significantly reduce the unsprung weight resulting in a more responsive suspension.
Brakes: Performance Friction Corp. has created extremely rigid and light weight aluminum MonoBloc calipers for use on the CR. The front caliper is a four piston design with four brake pads for superior modulation and high brake torque and the rear caliper is a two piston design sharing the same pads. The large floating rotors have aluminum hats for light weight. The front rotor diameter in 345 mm, and 328mm rotors are on the rear. The PFC Carbon Metallic Brake Pads offer exceptional brake loads for extremely short stopping distances. These ultra performance brakes also contribute significantly to reducing the unsprung weight of the Carbon Roadster.
Wheels and Tires: The final design for the wheels has not been determined, however, the specifications have. As on this prototype, all four wheels will be a one piece forged aluminum design for the lightest weight and strength. The CR standard front wheels are 19x9.5" and the rears are 19x10.5". Optional wheels in 18x9.5" and 18x10.5" will be available in forged aluminum as well for those drivers who want to take advantage of a larger selection of ‘R’ Compound tires and/or are interested in a more comfortable street ride. Magnesium forged wheels will be offered in 18x10" front, 18x11" rear for optimum track performance. The Michelin Pilot Sport Cup is currently the highest performance tire available for the street. The standard sizes for the CR are 265/30x19 front and 295/25x19 rear, (Not yet available). These Sport Cup tires produced 1.06 G cornering in a Car and Driver test driving a TC Kline Z4 using the same suspension as supplied on the CR. The Michelin PS2 Ultra high performance tire will be available in both 18 and 19" as a no charge option. The PS2 tires offer extended wear with less grip than the Sport Cup tires.
With some detail changes, the CR prototype you see here will be offered for sale in the late spring or early summer of 2006. The TC Kline Carbon Roadster will be assembled in the TC Kline Racing Shop in Columbus, Ohio. The CR will be available in all of the BMW Z4 M Roadster colors, and any special color can be accommodated for a small extra charge. The CR will be limited by production capability to 100 cars. The final price of the Carbon Roadster is not set. However, expect the price to be in the mid $90,000. range.
There will be two option packages for the CR.
Soft ride package. This package will use the new self adjusting KONI FSD (frequency sensitive damping), technology dampers for a softer ride with minimal sacrifice in grip, softer spring rates, 18" wheels, Recaro Sport Seats and Michelin PS2 tires. This suspension will maintain the factory rubber bushings in the suspension. This is a no cost option.
Track Attack Package: This package offers 18x10" front, 18X11" rear forged Magnesium Wheels shod with 265/35x18 front and 295/30x18 rear Michelin Pilot Sport Cup Tires, Competition rate springs, PFC Slotted Rotors, High Temp. SRF Brake fluid, Recaro Racer SPG Driver Seat, Driver and passenger racing harnesses, and TC Kline Spherical Ball Joint Suspension. The cost for this option package has not been set at this date.
For further information you can go tcklineracing.com, or call TC Kline Racing at 614-771-7744.
TC Kline Racing
"Uncompromising BMW Performance"
Specifications
+ Body
TC Kline Carbon Fiber Composite skin over steel unibody
+ Dimensions
Length 161.5"
Width 70.1"
Height 50.2"
Wheel Base 98.3"
+ Track
Front 60.2"
Rear 61.4"
+ Weight 2,680 lbs (unladen)
+ Interior
Recaro/TC Kline Custom light weight one piece shell seat w/ Alcantera and Leather upholstery
Optional – Recaro Sport Seats of Recaro Racer SPG Racing Seats
+ Engine
BMW 3.2 L inline Double overhead cam 6 Cylinder w/Iron Block and Aluminum Head - 346 hp @ 7900 rpm - 232 lb/ft torque at @4900 rpm
+ Exhaust
TC Kline Thin Wall Stainless w/center outlet
+ Flywheel
TC Kline 11.2 lbs Aluminum
+Transmission
BMW 6 Speed Manual
Gear Ratios 1)4.35 2)2.496 3)1.665 4)1.23 5)1.00 6)0.851
+ Differential
BMW M Lock Limited Slip
Final Drive Ratio 3.62
+Suspension:
Front:
TC Kline/KONI Dbl Adj Struts
TC Kline light weight 60mm ID Coil Over Springs
TC Kline Adjustable Camber Plates
C Kline Delrin Lower arm Bushings
Rear:
Multi-Link Trailing Arm
C Kline Dbl Adj Shocks
TC Kline Light Weight Coil Springs w/Adjustable Spring Lands
TC Kline Delrin Trailing Arm Bushings (Spherical Ball Joint or BMW Rubber Optional)
+Brakes:
Front
Performance Friction 4 piston MonoBloc Aluminum Calipers
345mm Floating rotor w/aluminum hats
Rear
Performance Friction 2 Piston Aluminum Calipers
328mm Floating rotor w/aluminum hats
PFC Carbon Metallic brake pads
+ Wheels and Tires
Light Weight One Piece Forged Aluminum w/Michelin Pilot Sport Cup Tires
Front – 19x9.5" wheel with 265/30x19" tire
Rear - 19x10.5 wheel with 295/25x19" tire (not yet available)
+ Optional
18x9.5 front and 18x10.5 rear Forged Aluminum
18x10 front and 18x11 rear Forged Magnesium
- from http://www.tcklineracing.com/roadster.htm
Old 04-10-2006, 08:06 AM
BeeEmDubAU's Avatar
disaster in progress
Rides:a car?
BeeEmDubAU has achieved their Master LicenseBeeEmDubAU has achieved their Master LicenseBeeEmDubAU has achieved their Master LicenseBeeEmDubAU has achieved their Master LicenseBeeEmDubAU has achieved their Master LicenseBeeEmDubAU has achieved their Master LicenseBeeEmDubAU has achieved their Master LicenseBeeEmDubAU has achieved their Master LicenseBeeEmDubAU has achieved their Master LicenseBeeEmDubAU has achieved their Master LicenseBeeEmDubAU has achieved their Master License
I remember seeing this somewhere else, but either way, that car is utterly amazing. I absolutely love it, thanks for posting it again.
"Life passes most people by while they're making grand plans for it."
Old 04-10-2006, 04:27 PM
95325is's Avatar
for teh win
Rides:M50 vanos, d16 vtac
95325is has achieved their Master License95325is has achieved their Master License95325is has achieved their Master License95325is has achieved their Master License95325is has achieved their Master License95325is has achieved their Master License95325is has achieved their Master License95325is has achieved their Master License95325is has achieved their Master License95325is has achieved their Master License95325is has achieved their Master License
man i would love to see that car in action
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
