You're right SI///M3, here are the stats for the 3.0 X5/4WD RX.
3.0 X5 left/4WD RX 300 right
Base Price (MSRP) $39,500/ $36,925
Base Invoice $36,105/ $32,493
Destination Charge $695/ $575
Blue Book Suggested Retail N/A / N/A
Safety Features
Driver Airbag Standard/ Standard
Passenger Airbag Standard/ Standard
Side Airbag Standard/ Standard
ABS Brakes Standard/ Standard
Traction Control Standard/ Standard
Child Safety Locks Standard/ Standard
Convenience Features
Air Conditioning Standard/ Standard
Power Windows Standard/ Standard
Power Door Locks Standard/ Standard
Tilt Steering Wheel Standard/ Standard
Cruise Control Standard/ Standard
Leather Seats Standard/ Standard
Power Seats Standard/ Standard
FM Radio Standard/ Standard
Cassette Player Optional/ Standard
CD Player Standard/ Optional
Sunroof Optional/ Standard
Tachometer Standard/ Standard
Rear Window Defroster/ Standard Standard
Luggage Rack Optional/ Optional
Alloy Wheels Standard/ Standard
Full-size Spare Tire Standard/ Standard
Engine Data
Base Engine 3.0L 225 hp I6/ 3.0L 220 hp V6
Turbo / Supercharger None/ None
Horsepower 225 @ 5900 RPM/ 220 @ 5800 RPM
Torque 214 lb/ft./ 222 lb/ft.
Displacement 2979 CC/ 2995 CC
Bore X Stroke 3.31 X 3.53/ 3.44 X 3.27
Compression Ratio 10.2:1/ 10.5:1
Fuel Type Gas/ Gas
Fuel System SEFI/ SEFI
Fuel Economy City 15 mpg / 18 mpg
Fuel Economy Hwy 21 mpg / 22 mpg
Exterior Dimensions
Curb Weight Automatic 4533 lb/ No data
Curb Weight Manual 4586 lb/ 3924 lb
Wheelbase 111 in. / 103.1 in.
Track Front 62 in. / 61.6 in.
Track Rear 62 in. / 61 in.
Length 183.7 in. / 180.1 in.
Width 73.7 in. / 71.5 in.
Height 69.3 in. / 65.7 in.
Ground Clearance 7.1 in. / 7.7 in.
Interior Dimensions
Standard Seating 5 / 5
Optional Seating N/A /\ N/A
Front Headroom 39.8 in. / 38.1 in.
Rear Headroom 38.5 in. / 38.6 in.
Front Legroom 39.3 in. / 40.7 in.
Rear Legroom 35.4 in. / 36.4 in.
Front Shoulder Room 58 in. / 57.8 in.
Rear Shoulder Room 57.2 in. / 57 in.
Front Hip Room No data / 55.2 in.
Rear Hip Room No data / 55.2 in.
Payload & Towing
MFR Passenger Volume 97.6 cu.ft / 100.8 cu.ft
Standard Towing 6000 lb / 3500 lb
Max Towing 6000 lb / 3500 lb
Standard Payload 1473 lb / 1026 lb
Max Payload 1473 lb / 1026 lb
MFR Cargo Volume 16.1 cu.ft / 39.8 cu.ft
Max GVWR 6005 lb / 4950 lb
Steering & Suspension
Turning Diameter (left) 39.7 ft / 41.3 ft
Turning Diameter (right) 39.7 ft / 41.3 ft
Steering Type R&P / R&P
Front Suspension Independent / Independent
Rear Suspension Independent / Independent
Tires 235/65R17 225/70R16
Warranty Info
Basic Warranty 48 mos. / 48 mos.
50000 miles / 50000 miles
Powertrain Warranty 48 mos. / 72 mos.
50000 miles / 70000 miles
Rust Warranty 72 mos. / 72 mos.
Unlimited Miles / Unlimited Miles
Final Assembly United States / Japan
Well, even though it doesn't matter, here are my two cents.
My dad and brother both have BMWs, and they really don't have many problems, but when they do god it's a lot of money.
I trust BMW and Lexus. Both of the companies are trustworthy and reliable. Toyota makes great cars and BMW makes more technologically advanced cars, but both are great nonetheless. Pick whichever one suites you the best, and I'm sure you'll pick the right one.
