Go Back   DTMPower BMW Forum > DTMPower Forum Archive > Archived Threads
Register FAQ Members List Calendar Mark Forums Read
Old 12-12-2001, 05:51 PM
Gez Gez is offline
Rides:E36
Region: Other
Gez is a New Registered Member
How to remove the headlights????
I just want to find out...how do u remove the headlights from the e36 bmw....ive never battled so much in my life to get the damn things out...can anyone of u help me out and tell me how do it?????
Old 12-12-2001, 05:53 PM
stockman
Guest
Posts: n/a
2 bolts holding them down... to the side/behind headlights
and 3? on top...
Old 12-12-2001, 07:09 PM
Rides:93 325is
caball88 is a New Registered Member
check jim p's site out. he has nice detailed photos.
http://www.apexcone.com/Lighting/Eur...llipsoids.html
Old 12-13-2001, 11:55 AM
Rides:2001 Titanium Silver M3
SilverE46M3 is a New Registered Member
and 3? on top...
This is correct. The stock headlights have 3 screws that connect the top of the light (used for leveling the light) and a screw that must be removed by taking out your corners, and then another screw directly behind the headlight.....
2001 Titanium Silver ///M3 (Stock for Now )
1999 Titanium Silver ///M3/2 (SOLD)
Old 12-13-2001, 04:12 PM
Hellred's Avatar
Rides:2003 BMW M3
Region: USA - New England
Hellred is a New Registered Member
just yank the shit out of them
Old 12-13-2001, 04:32 PM
Rides:red
rayster is a New Registered Member
5 bolts holding them in... 3 across the top (I'm sure you've already figure these three out. One that points straight down behind your parking light, and the last night (also pointing straight down) is a little tricky to get to, but is closest to the kidney grills. You have to remove the black plastic, triangular shroud that is centered on top of the kidney grills. (Or at least remove the few screws on the side so that you can gently bend back the shroud to get access to that last headlight bolt. Good luck.
Thread Tools
Display Modes
BB code is On
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171
