Go Back   DTMPower BMW Forum > Technical Discussions > E36 M3
  #16 (permalink)
Old 03-18-2012, 02:42 PM
epj3's Avatar
Rides:1997 M3
epj3 is a New Registered Member
I really don't think it's the guibo... my suspicion that it's the middle u-joint kind of matches this Clunking at the rear of a BMW 540i '97 - YouTube
PS if you decide to replace the driveshaft, the absolute best deal is through cmuzzy on bimmerforums
  #17 (permalink)
Old 03-18-2012, 05:55 PM
eatsleeplax's Avatar
Registered User
Rides:1997 Hellrot m3
eatsleeplax is a New Registered Member
Can't I just replace the u-joint in the driveshaft? Or are some special tools or some shit needed.
  #18 (permalink)
Old 03-18-2012, 06:15 PM
epj3's Avatar
Rides:1997 M3
No, not really. Rebuilding a driveshaft is incredibly complicated. Too many things have to be perfect. Our drive shafts are simply not meant to be serviced. The rebuilt driveshaft from cmuzzy comes with a brand new center bearing.
See here, http://www.dtmpower.net/forum/e36-m3...t-options.html
As I said in that thread, the driveshaft cmuzzy sells is from http://www.driveshaftspecialist.com/...0html/BMW.html and so far mine has been perfect. It looked brand new. If you do go with a rebuilt driveshaft, do not buy one with serviceable bearings (grease zerks) since you'll have to drop the exhaust every 10k miles to service bearings that won't last as long as sealed bearings. All of this considered, I would replace the guibo & inspect the CSB first (since it's easy) and go from there.
  #19 (permalink)
Old 03-18-2012, 10:20 PM
Registered User
Put it up on stands and turned the wheels. Turns out it was just the insulation hanging on the driveshaft and banging each turn. Its all gone now. Still gonna replace the giubo though
  #20 (permalink)
Old 03-19-2012, 12:28 AM
epj3's Avatar
Rides:1997 M3
  #21 (permalink)
Old 03-19-2012, 01:34 AM
Registered User
Originally Posted by epj3 View Post
hey, you guys heard that video, it sounded like something was actually wrong lol
  #22 (permalink)
Old 03-19-2012, 12:22 PM
Registered User
Rides:BMW M3 1995
Region: USA - Great Lakes
MagicM3 is a New Registered Member
I personally dont think insulation, (non Metallic substrate) could cause that noise. I agree with whoever said it is probably the driveshaft itself. Calvin can confirm that my noise was nearly identical. When I replaced the DS with a new CSB The noise is gone. Are you sure its all gone? Very strange....
If you end up going with a new DS, Don't go anywhere except
BMW replacement driveshaft, remanufactured BMW driveshaft, BMW drive shaft
These guys were great to work with and were fast and affordable. I believe that they have a warehouse in CA too!
Hopefully you won't need to go that route though!
good luck
  #23 (permalink)
Old 03-19-2012, 12:56 PM
Registered User
good luck
Yep, for sure completely gone. It was just the guibo catching on the insulation and the insulation banging on the driveshaft. I was able to recreate the sound from liftin and dropping the insulation. In case anyone was unfamiliar the insulation is quite stiff. Its like a hard dried out cardboard / thin particle board material. Its solid crap
  #24 (permalink)
Old 03-19-2012, 01:08 PM
Registered User
Rides:BMW M3 1995
weird! I certainly am familiar with that stuff, I cut all of mine out a year or so ago....shit is nasty!
Thread Tools
Display Modes
BB code is On
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Content Relevant URLs by vBSEO 3.6.0 ©2011, Crawlability, Inc.
