Go Back   DTM Power BMW Message Board Forum > DTMPower > Showroom
Old 10-03-2003, 04:55 PM
SI///M3's Avatar
Rides:BMW, M3, 1999
SI///M3 is a New Registered Member
Professional action shots of my M3 on track
Sample:
Full series: http://www.estorilblue.com/putnampark.htm
Some of them need to be cleaned up in photoshop pretty bad, but I just havn't had the time yet. Even so, hope you enjoy.
Pictures of my car
Old 10-03-2003, 05:01 PM
Fissionx's Avatar
OBD1 S52!
Rides:Mrs. Daisy
Fissionx is a New Registered Member
Awsome!
If you can read this, you're on DTM and you're a moron...
-Dan
Custom Turbo 328
Thanks for help from Eurospeed Performance and Technique Tuning
FOR SALE:
PNP AEM CDI, M3 Clutch, AA Stg1 IC/Piping
Old 10-03-2003, 06:04 PM
J Clark's Avatar
Premiumest Member
Rides:95 Alpine M3
J Clark has achieved their Master LicenseJ Clark has achieved their Master LicenseJ Clark has achieved their Master LicenseJ Clark has achieved their Master LicenseJ Clark has achieved their Master LicenseJ Clark has achieved their Master License
wow. i love all of them.
and i want an m3 so bad.
-Jesse
Old 10-03-2003, 08:38 PM
SG_M3's Avatar
Rides:#56 IP M3
looks great phil.
How are you liking the 450/525's? Mine will be here soon, can't wait to take them to the track. Also, what kind of camber are you running? Swapped hats? and did GC custom setup the camber on your struts? It looks like you are getting very little roll over.
Sean
Old 10-03-2003, 09:04 PM
SI///M3's Avatar
Rides:BMW, M3, 1999
I'm pretty happy with the springs. My only complaint is I seem to be somehow gettings just the tiniest bit of coilbind in the rear which I need to work on. But the balance of the car is great. With my sways set soft/soft the car is extremly neutral with just a hint of understeer, which is just about perfect for the track. I'm running swapped hats which puts me at -2.4 degrees up front and -1.8 in the rear. -2.4 actually performs very well, my front tires have worn amazingly even so that says its pretty much right. Its not a race car, but body roll is is just about nil.... I'm very happy with it overall.
Are you still running the TCK setup and just getting new springs or are you changing out to full GC?
Pictures of my car
Old 10-03-2003, 09:33 PM
SG_M3's Avatar
Rides:#56 IP M3
I'm still on the tck setup and adding 450/525. Glad to see you like it, i'm going to swap the hats this time.
But i'm thinking of selling my setup and just getting the full GC kit with camber plates, or get DA fronts and no plates.
What rear ride height are you running? Probably 11.75 you might no have enough bump stop in the rear? Or you might lower it 11.5" and see. Are you testing by zip ties?
Sean
Old 10-03-2003, 10:06 PM
alen's Avatar
Rides:j31'ed A4
alen alen alen alen alen alen alen alen alen alen alen
OMG, i'm so in love with your car.
Old 10-03-2003, 10:28 PM
SI///M3's Avatar
Rides:BMW, M3, 1999
I havn't done the zip tie test yet, I need to do it though. I was just checking up on my rear brake pads last week and I noticed there looked like some rub marks on the springs. I need to zip tie them tomorrow so that I can see how it holds up during the autocross on sunday.... I'm currently at 11.75" which is pretty low, if I fail the zip tie test I might give 11.50" a shot and see what happens. I'm also thinking of maybe trying a different spring rate back there too....
I origionally planned on getting the DA Konis but actually the GC people talked me outta them. Basically, they said all the extra effort trying to dial in the DAs isn't worth the hassle unless your really racing and such. I dunno though, FWIW I wish I had the DAs, especially since I'm getting better at autocrossing now. Camber plates are on my list of things to do soon, simply because I wanna make sure I get as much life as possible outta my track tires when I get them.
Pictures of my car
Old 10-03-2003, 11:14 PM
SG_M3's Avatar
Rides:#56 IP M3
The DA fronts with SA rears is $1500, the normal track/school kit with plates is $1500. Though for my weekend warrior needs it maybe too much.
From looking at my coilovers compaired to scho's track school kit, the only difference is the rear shocks, his are completely different than mine. Mine are standard length M3 spec koni's, his look nothing like mine and are shorter. But our fronts are the same, except for is his custom geometery. Don't know if its worth the extra money between mine and the GC kit.
I have a set of kosei's with r comps on them in my garage, i'm debating to use them though. I may just sell them and stay on street tires, r comps maybe more than i need.
Sean
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737
