Go Back   DTMPower BMW Forum > DTMPower > Showroom
Old 09-25-2003, 07:00 AM
Dado's new Turbo M3 with 540HP. TEC3 standalone engine management. Mod list updated
Video 1 race against supra right click save as
Video of the first pass down the drag strip at low boost.
First pass down the drag strip
Lots of videos in the videos section. Try the following link.
http://dtmpower.net/gallery/videos.php
Had lots of problems with the tuning done by Active Autowerkes so the car is now running a Electromotive engine management system. For more info check this link.
New TEC3 installed by Built Motorsports and Tuned by SIAS Tuning
Click on the following link for info on the first track event that we tested the car on.
Nasa VIR February 21-22 wrap up. Added video
Here are some more pictures.
took some new pictures today, a little dark.
Losing some more weight on the car.
back from ohio, losing some more weight on the car :)
Gallery of pictures to race car conversion.
http://www.capitalaudi.com/gallery/DTMGarage
M3 VS Yamaha R6.
http://www.dtmpower.net/forum/showth...hreadid=112082
First of all I would like to thank the sponsors which helped make this car possible.
CDOC
DAS Sport
KW Suspensions
MA Shaw
MMS Tuning
Kinesis
Stoptech
Rogue Engineering
PRO Form / PFT Films
Teckademics
Autoxcam
KO Performance
Wise Creations
SPA Technique
M3 Motorwerks
Diffsonline.com
95 M3
Engine:
AA Stage 3 Turbo Kit
AA Custom 3.2 M Motor Built
Stage 3 1400 CFM Intercooler
Stage 3 Hybrid Turbo: 60-1 compressor end mated to a clipped TD06 exhaust end
Electromotive TEC3 engine management. Supplied by SIAS Tuning
Pauter rods chromoly rods
JE Pistons 8.3:1 motor
AA Turbo Spec Cams
Knife edged crank
Hi performance valve springs
Dual electric 10” fans
Heat Wrapped exhaust manifold and piping
HKS Racing Bypass Valve
HKS Super Sequential blow off valve
Greddy Boost Controller
Greddy Turbo Timer
AA Water/Alcohol Injection System
Zionsville Aluminum radiator
SPA Technique Oil cooler with braided lines supplied by CDOC
Euro E36 oil filter housing with outlets for oil cooler
Custom 3 inch side exhaust by Jav
AA Custom 3.5" Low Level Air Intake
Fuel starvation kit stage 2 (secondary fuel pump)
Main fuel pump welbro 255
Last dynoed in October 2003 at Altered in Gaithersburg and it made 458 hp to the wheels at 17psi. At 11 psi it made 385 to the wheels.
Transmission:
Active Autowerke aluminum lightweight flywheel
Active Autowerke 4 Puck Racing Clutch
Evo M3 6 speed Transmission supplied by GMG Racing
2.93 Differential with 60% lockup by diffsonline.com - Custom Geared BMW LSD Differentials
AA Shift Knob
AA Short shift kit
Rogue Engineering Finned differential cover
Suspension:
KW Coilovers Variant 3’s:
Independently adjustable rebound and compression damping
Inox-line stainless steel technology
Individual height adjustment
Infinitely adjustable rebound damping
14- level adjustable compression damping
BMW X-Brace
Active Autowerke Rear Toe Bushings
Active Autowerke Rear Camber Correction Arms - BROKEN! snapped in half in middle of a corner.
Upgraded to Turner Motorsport rear camber arms.
RD Sport strut brace
Ground Control Sway bars supplied by MPact Motorsports
Ground Control Camber plates supplied by M3 Motorwerks
Ground control rear shock mounts supplied by M3 Motorwerks
Lighting:
BMW Clear Lenses
ZKW European Ellipsoids with Lava Lighting Angel Eyes supplied by Ko Performance
6,000 K Low beam xenons supplied by Ko
8,500 K foglight xenons from xvision supplied by Import expression (removed for track use)
Wheels:
Kinesis K58 18X8.5 front
Kinesis K58 18X9 rear
Falken 451 235/45/18 front
Falken 451 255/35/18 rear
RRT Stud kit
Exterior:
Vented carbon fiber hood by MASHAW:Porsche Tails & Body Kits for 911, 930, 993, 996 E36 E46 BMW body parts Wings: Lexan Race Glass Windshield
Sparco hood pins
Rieger Carbon Fiber front splitter supplied by MMS Tuning
BMW LTW M3/GT Rear Wing
Removeable Height Extensions in carbon fiber by MASHAW:Porsche Tails & Body Kits for 911, 930, 993, 996 E36 E46 BMW body parts Wings: Lexan Race Glass Windshield
Painted Moldings, door handles, washer nozzles
Full paint Ferrari Code #102
Full front end 3M paint protection film installed by Protective Film Technologies, LLC (PFT)
Brakes:
Road Race Tech Brake cooling plates and ducting
Stoptech 14 inch front with Cobalt racing pads
Stoptech 13 inch rear with Cobalt racing pads
Interior:
Stack ST8110SR Boost Street Dash it has:
Tachometer
Boost Pressure in PSI
Speedometer
Odometer & Tripmeter
Oil & Fuel Pressure readout
Water & Oil Temperature readout
Volt Meter
Fuel Level
Infrared Lap Timing
Predictive Lap Timing
EFI Systems UEGO1000 Wideband O2 Sensor
Sparco Suede steering model 323 supplied by CDOC
Sparco quick release hub supplied by CDOC
Sparco horn kit supplied by CDOC
AA E-brake handle
DAS Sport full welded in cage by CDOC
Nerf padding supplied by CDOC
Fully gutted
Teamtech 5 point harness with camlock supplied by CDOC
Cobra Evolution Technology GT Seats full carbon fiber drivers seat supplied by CDOC
Cobra competition side mounts supplied by CDOC
Cobra sportline for passenger supplied by CDOC
Electronic fire supression system with 3 nozzles supplied by CDOC
Kill switch in cabin and outside supplied by CDOC
Window net supplied by CDOC
Here is a picture of the car when I got it.
Here is after we were done with it
Old 09-25-2003, 07:05 AM
Florida Rep.
Rides:'98 Turbo M3
///MCubed is a New Registered Member
Nice Dado. So how is my 2.93 working out on the car?
'98 M3
GReddy Gauge For Sale (Click Here)
"Come Play with Power"
Old 09-25-2003, 07:08 AM
thanks a lot Carlos. Sorry it came out to that but I was supposed to have one 2 months ago but the information just wasn't being forwarded.
IMO I think the gearing is perfect, the car felt pretty stable doing 180 in 5th. I did not go into 6th though, kinda scared
Rides:'06 330i
jaypod is a New Registered Member
Looks Great Dado! Can't wait to see some clips of you driving the hell out of it! Good Luck in Europe with whatever you rent - have you lined up anything yet?
Cheers!
Old 09-25-2003, 07:09 AM
thanks, looks like a volvo s70 turbo.
Old 09-25-2003, 07:10 AM
EstorilRoc3060's Avatar
Wildcat
Rides:lookin for my Estoril M3
EstorilRoc3060 is a New Registered Member
SOWEET!
Old 09-25-2003, 07:13 AM
Florida Rep.
Rides:'98 Turbo M3
Glad to hear it is holding up. Hmmm, 180mph in 5th, I wonder if I need that 2.79 instead considering I only have a measly five gears
How stable did the car feel at 180?
'98 M3
Old 09-25-2003, 07:15 AM
very stable, I was still changing lanes with no problem. BTW I did get into 6th and the car was still pulling like I was in 5th but I let go right away.
Old 09-25-2003, 07:22 AM
Arman's Avatar
Persian Baller
Rides:04 Jet Black M3
Arman is a New Registered Member
Looking good DADO! I luv the yellow.....
How much power is this beast making exactly?
SHIFT_manually
Rides:'96 Nissan Maxima
nadir has achieved their Master Licensenadir has achieved their Master Licensenadir has achieved their Master Licensenadir has achieved their Master Licensenadir has achieved their Master Licensenadir has achieved their Master Licensenadir has achieved their Master Licensenadir has achieved their Master Licensenadir has achieved their Master Licensenadir has achieved their Master Licensenadir has achieved their Master License
damn, that's crazy sweet!
your car looks beautiful
[ 5-spd 1996 M A X i M A SE ]
__________
Old 09-25-2003, 07:24 AM
Thanks Arman, the color came out too light but not bad
did around 540 to the crank in a 97 degree day.
Old 09-25-2003, 07:41 AM
Al_Walker's Avatar
UK BMW enthusiast
Rides:'90 E30 320i coupe
Al_Walker is a New Registered MemberAl_Walker is a New Registered MemberAl_Walker is a New Registered MemberAl_Walker is a New Registered MemberAl_Walker is a New Registered MemberAl_Walker is a New Registered MemberAl_Walker is a New Registered MemberAl_Walker is a New Registered MemberAl_Walker is a New Registered MemberAl_Walker is a New Registered MemberAl_Walker is a New Registered Member
oOo good gawd, that's just beautiful
make sure you take in Nurburgring when you come over to Europe
Old 09-25-2003, 07:48 AM
///BimmerPower's Avatar
Rides:3.5l Turbo Diesel, zx10r, e36 325, 05 SRT-4
///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License///BimmerPower has achieved their Master License
Congrats on the new car dado. Looks great and its pushing some serious power. Thats one killer toy and I hope you have fun beating on it . Can't wait for the video's of it after the Cannon Ball. Good luck to you and the rest of the crew in Europe.
Paco
Bayerische Motoren Werke
Old 09-25-2003, 07:56 AM
Zor Zor is offline
Interboro Specialist
Rides:95 civic Group N, 99 Subaru Impreza Rally Car
Zor is a New Registered Member
oh my god
Old 09-25-2003, 08:03 AM
CMT CMT is offline
Rides:04 Jeep Liberty
CMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master License
http://www.ziplink.net/~ctroiane/smile/yeah.wav !!!!!
in on page one
in for nutsack surfing
ibpage100000000000000000000000000
Congrats Dado!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
