Rotors: OEM full stock blanks... No slotted or crossdrilled smancy pantsy stuff... not worth the money.
Pads: I'm currently on a Carbotech kick... I'd probably go with the panther plus for introductory track use as long as you can live with a bit of dust and noise...
The Bobcat compound is a street and AutoX compound that would work for light track use. The Friction Coefficient (Mu) is 0.50-0.55 and a temp range of ambient up to about 900F.
The Panther Plus compound is good for AutoX or moderate track use. It can be used on the street. However, with an aggressive compound like this, dust and noise can be expected. The Mu is 0.54-0.56 with a temp range of about 150-1250F.
The Panther XP is a race compound friction material designed for track use. It is not recommended for use on the street. This pad will withstand prolonged use on the race track without fading. The Mu is a lofty 0.58-0.60 and the temp range is from 250 all the way up to a scorching 1350F.
Just realize that they mean it when they have a temp range starting at 150deg... It won't bite much below that... So warm up your brakes before you need em' if daily driving something more aggressive than the bobcats.
