Read more about it: http://www.gelexan.com/gelexan/ http://www.geplastics.com/resins/materials/lexan.html |
Lexen scratches very easily and if you have a spin in the gt3 or hit a really hard bump at speed on the road the lexen rear window has a habbit of popping out.... But as a weight saver its awesome. As someone said there are better places to start... -See dado's car etc. I stripped the interior from my car (all except front carpet section) and all of it weighs a lot, especialy the front seats. I am yet to weight it all but I can tell you now its substantial. ![]() Last edited by NMJ-045 : 04-10-2005 at 02:47 AM. |
| Percy's, a semi-local company to me, sells a hard-coated lexan, called speed-glass, that doesn't scratch nearly as easily. Many thicknesses available And what is corneros talking about again?
| Lexan is a particular brand of polycarbonate. It is prone to scratches because of it's low hardness (108-122 RHR). An alternative to Lexan that would be significantly more resistant to scratches would be an acrylic (63-97 RHM). However, with acrylic you will sacrifice impact resistance to hardness. While Lexan can handle over 10 ft-lb/in, general purpose acrylic is rated for only half that. Lexan also has a significantly higher melting temperature (374-500°F) when compared to that of acrylic (266°F). But a downfall of Lexan is that it will be more expensive than acrylic because of manufacturing processes. Chosing the right material is really dependent upon your appication. Some very good points have been suggested in other replys, and like Highboosted said, there are coatings available to protect your lexan and keep it crystal clear for longer. Hope this helps! ![]()
__________________ '02 325xi | Powerchip™ Tuning | aFe CAI | iPod Adapter |
