Old 03-12-2005, 12:04 AM
Rides:2005 EVO RS
BMWM3Power95 is a New Registered Member
what's wrong with my m3?
Tonight I took my car down to portland international raceway for 1/4 mile drag racing. This was the first time I took my car since its been modified (cold air intake, chip, euro HFM, AA exhaust). Last year when it was stock I ran a 14.776 on a slipping clutch. The clutch has been replaced since then. Tonight I only got 2 runs:
60'-2.309 60'-2.346
330-6.310 330-6.323
1/8- 9.586 1/8-9.604
MPH-76.55 MPH-75.66
1000-12.350 1000-12.364
1/4- 14.709 1/4-14.709
MPH-95.22 MPH-95.82
What's the problem, shouldn't I be running low 14s/high 13s??
Old 03-12-2005, 09:12 AM
Rides:BMW, 318ti/M3, 1995
abdo is a New Registered Member
are you running your stock injectors if so maybe you are starving the engine a bit causing some pinging. Not sure that is you problem but that is what fist came to mind seeing your set up
googd luck
Old 03-12-2005, 09:20 AM
Banned
Rides:95 Alpine ///M3
BSaint has achieved their Master LicenseBSaint has achieved their Master LicenseBSaint has achieved their Master LicenseBSaint has achieved their Master LicenseBSaint has achieved their Master LicenseBSaint has achieved their Master LicenseBSaint has achieved their Master LicenseBSaint has achieved their Master LicenseBSaint has achieved their Master LicenseBSaint has achieved their Master LicenseBSaint has achieved their Master License
damn that sucks... i ran 13.9 @ 102 from just ecu and injectors on shit tires... sence then ive done my mid pipes and intake and some sticky ass tires for the track...i did run 14.2 twice only because i didnt lower my tire pressure... once i did to about 25 -27 psi i was constant 13.9s
Old 03-12-2005, 11:08 AM
Rides:2005 EVO RS
yeah they're stock injectors.
Old 03-13-2005, 08:08 AM
its probably not due to the injectors, because your chip is probably calibrated for your set up correct? maybe do a couple more runs to get more data before you start throwing money at the situation. Does your car feel any different on your daily drives?
good luck
Old 03-14-2005, 05:21 AM
Rides:95 bmw
5speed300 is a New Registered Member
Definitly look into lowering your rear tire pressure and raising the front a bit. Those 60' times arent very good. Im surprised at how low your mph is though. Maybe take your car in for a full tune up? Have a mechanic check it out.
Old 03-14-2005, 05:50 PM
Got DINAN?
Rides:1999 BMW M3 DINAN
hbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master License
I'm assuming you know how to drive stick, i would suggest getting a tune up and maybe replace your injectors with bigger ones, or run octane boost. But 14.7 is kind of wierd with slippin clutch then a new clutch. Maybe it wasn't the clutch that was slipping? That's my .02.
Old 03-14-2005, 08:12 PM
Rides:2005 EVO RS
yeah i know how to drive stick, ive been doing it for almost 2 years.
Old 04-10-2005, 12:40 AM
Banned
Rides:1995 325i
bigred318 is a New Registered Member
practice practice practice
Old 04-14-2005, 08:58 AM
Rides:Black 05' WRX
JF824 is a New Registered Member
like said before, lower you tire pressure. try to get that 60' down.
Old 04-14-2005, 02:23 PM
neenja's Avatar
Former Terps soccer
Rides:Mmmm3 handling monster
neenja is a New Registered Member
you're probably worried its the car? ...i bet it isn't. You're probably just doing something thats causing the low times...no big deal.
bigred318 said it right - practice practice practice -
I road race but i doubt i would do well at a drag strip, ain't the same thing.
98 Dakar M3 NCC BMW CCA Member
BMWCCA NCC
SCCA Club Racing
TC Kline modified suspension
Pilot in training @
Frederick Flight Center
Old 04-14-2005, 10:49 PM
sk8er882's Avatar
Rides:98 323is
sk8er882 has achieved their Master Licensesk8er882 has achieved their Master Licensesk8er882 has achieved their Master Licensesk8er882 has achieved their Master Licensesk8er882 has achieved their Master Licensesk8er882 has achieved their Master Licensesk8er882 has achieved their Master Licensesk8er882 has achieved their Master Licensesk8er882 has achieved their Master Licensesk8er882 has achieved their Master Licensesk8er882 has achieved their Master License
lost time in the launch most likely. Did the car spin? Bog? this would hurt the 60foot and throw the whole run off a bit. Try lower air in the rears and more in the front like others suggested. Also in the 1/8 mile a general rule of thumb is every 100 lbs you take off you gain a tenth! good luck
Old 04-29-2005, 08:16 AM
deep throat's Avatar
Rides:Individual Vert
Region: Middle East
deep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master License
Finally i got how essential light-weighting is
Old 05-02-2005, 10:56 PM
Goofy Dan
Rides:BMW M3 1995
///M3 Drifter is a New Registered Member
Maybe you shouldn't 1/4 it and join us at the track days with the BMW ACA Club.
Old 05-10-2005, 09:53 PM
NMJ-045's Avatar
abc123
Rides:Motor Vechile
NMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master License
Tyre pressure, tyre temp, track temp, air temp, condition of track (Greasy, less rubber than before etc) and of course drag strip all are factors in your time (Assumeing that you drive excatly the way you did before)
Go circuit racing its more fun, and lasts longer than 14 seconds a go...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448
