Old 08-23-2004, 06:23 PM
Rides:1992 M42 (dead), 1994 M42
M42-Technic is a New Registered Member
What sway bar diameters are you guys running for the track? I want oversteer dammit!
I have a unique suspension setup that I'm sure a lot of you have as well. I have a '94 318. However, I swaped to the front strut design which has the front tabs for the M3 sway bar endlinks. Right now I'm using the 20mm M3 rear sway bar and 23.5mm front (strut mounted) M3 bar. I'm just intersted in what you guys are running on the track (especially M3 guys or people with the M3 strut/sway bar design). I still have too much initial body roll. The track I currently attend has lots of very low speed sharp turns. The understeer is killing me. It's probably a track made for FWD cars such as Hondas.
I've tried the Dinan control arm mounted 27.5mm front bar in all settings paired with the 20mm rear M3 bar. There was little to no body roll. However, still way too much understeer. Note that I have a 318, so there's no throttle induced oversteer here.
Last week I ordered a 21mm 2 way adjustable H&R rear sway bar, should be comming in this week. I have a bit of a problem. There are no H&R front sway bars available for the M3 strut mounted design. The only bar they have is 28mm for 325/328! That's much too thick to mount to the strut. Most aftermarket brands use 24-25mm in the front for the M3. I'll probably have lots of understeer agian. What do you think I should do? Should I switch back to the control arm mounted sway design and go with the 28mm front?
Oh yeah, I'm using Bilstein/H&R combo.
Thanks for your opinions guys!
Bry
1994 M-Technic M42
- View my mods
Old 08-24-2004, 10:00 PM
Rides:VW/BMW
LITEWAITM3 is a New Registered Member
If you have a machine shop around, you can make a pretty simple split block mount for a custom bar and get some serious bars in there.
I have jim bell custom on front and rear of my racecar, and its pretty intense.
Heres a shot of the adjustment end of the front right corner (notice subframe integration into cage)
Old 08-25-2004, 01:55 PM
That's an interesting design. I've never seen anything like that before. Is the bar hollow?
1994 M-Technic M42
- View my mods
Old 08-25-2004, 02:41 PM
Rides:VW/BMW
Yea, its a custom job made for race applications only. It'll probablyt run you about $2k for the setup.
Its hollow yes (you can see in the picture). To get an idea of how stiff they are, you only have to jack the carup 3 pumps (normal jack) for the tiresto clear the ground. The suspension does not sag at all as you raise the car (also dueto the moton shocks).
Old 08-27-2004, 06:32 PM
Matthew C Smith's Avatar
Rides:hellrot machine
If it's oversteer you want, just remove the front sway bar. It'll spin like a top. I wouldn't recommend it, but it'll oversteer.
You really shouldn't be using the sway bars to drastically change the dynamics of the car. What spring rates are you using?
Old 08-27-2004, 08:29 PM
S2K
Rides:bmw 320is 83'
listed is a New Registered Member
i agree with matthew c in not trying to use the sway bars to adjust that much. But if you want oversteer from the car with sways you need to probably leave the front one stock and upgrade on the back which will the rear slide more which equals oversteer, you can also do this with damping but i do not know if you have coilovers or an adjustable shock...
Old 08-28-2004, 11:43 AM
I'm using Bilstein dampers, so damper stiffness is not adjustable. I'm using my car for track, so removing the front sway bar would be just downright silly. I want to be able to put my car into a 4 wheel drift or "race drift" hense the need for a stiffer front and rear sway bar combo. I'm not sure what my spring rates are. I was using the Eibach pro kit springs which were progessive springs (didn't like that setup). Now I switched to H&R sport springs. Eibach and H&R company websites state that they cannot provide spring rate info to the public and it's only available for their developers, what a crock! Although many people have suggested mixing and matching springs, I don't usually like to do this. Eg. putting in M3 rear springs.
I'm going to wait for my H&R rear sway bar to come in and see if I like the results. I still feel too much initial body roll. I think the front bar may be too thin. Does a strut mounted sway bar design actually increase stiffness over the control arm mounted design? I know people say it's more effective, but in what way? There is less unsprung weight, but how does that affect the overall handling of the car? Will using a 28mm strut mounted sway bar drastically increase understeer as compared to using the 28mm bar moutned to the control arm? Thanks for your help guys.
Bry
1994 M-Technic M42
- View my mods
Old 08-29-2004, 05:33 PM
Rides:VW/BMW
It depends. If we are talking turn entry/exit, then it can help, but for static turns, while at constant rates, dampers are not going to do it...its going to be spring rates mainly.
Does the car oversteer when you try throttle lift oversteering techniques?
Or doesitjust Plow all the time? A Lot of time a car might feel like its understeering, but it could just be driving technique (no offense, just saying what it could be).
Have you had any instructors or experienced racers/drivers run it?
Search on BF in the track forum, you can get some good answers there, lots has been discussed in the past. Goodluck
Old 09-06-2004, 08:58 PM
Glucas21's Avatar
FSAE Driver
Rides:95' BMW M3
Glucas21 is a New Registered Member
Here is a chart that is very helpful for setting up your car the way you want it. I agree with you, I would take a car that oversteers rather than understeers any day of the week. Hope this helps you.
- Garrett
Old 09-06-2004, 09:10 PM
Thanks for the chart, but that's pretty basic. It's pretty much what most people should know already before fooling around with sway bar diameters.
At any rate, I'm still trying to determine how a strut mounted sway bar differs in stiffness compared to a control arm mounted sway bar. Any theories?
That chart was actually originally from Korman's site
Bry
1994 M-Technic M42
- View my mods
Old 09-06-2004, 09:18 PM
If I'm going quick enough "liftoff" oversteer will work. However, at a low speed track with lots of tight turns I still find my car running a bit wide. At the beginning of the season I was using Eibach pro kit springs. I've noticed that my car would seem to run wide first, then give a bit of snap oversteer. I wonder if this is because of Eibach's progessive springs. When you first turn initially, the spring rate is soft, when you reach the limit, you get a super stiff spring rate thus causing the snap oversteer. I haven't done any serious track driving after installing the H&R springs, I should try that first as I'm sure H&R springs are less progessive and have a much stiffer spring rate. Can anyone confirm this?
I really should get an instructor to test out my car. Just haven't been able to come up with the $400-500 driving school fee
1994 M-Technic M42
- View my mods
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627
