| oem replacment drilled, slotted, dimpled rotors sorry for my horrible typing and spelling but i have a couple of ?'s is it safe to use oem replacment slotted, dimpled, or drilled rotors? i hear if you use them in high speed racing it can cause cracking, any professional opinion would GREATLY be appreciated
__________________ --------------> loves BMW |
__________________ trevor |
| OEM works fine... only way I can see you warping rotors is uneven and/or too much torque on the wheel bolts. or no cool down laps.. and letting the car sit there.
__________________ http://www.bmwpower.ca |
| just get some stock rotors.. the metalurgy of the brembo replacements seems to work well . I would stay away from anything that is drilled. You might want to consider having them crio treated. That seems extend there life about 20%.. And remove the backing plates from the front and rear rotors this will aid in getting air to them and increase there life.... |
