Old 03-02-2004, 10:46 AM
Rides:95 BMW 325is
tatawaki is a New Registered Member
Question Which R's to get, and what size?
Looking for some R compound Tires for this years auto-x and track events.
I have a E36 325is. so 15" would fit. I'm guessing 225/50/15 would be best for my car?
any other recommendations?
http://www.bmwpower.ca
Old 03-02-2004, 06:24 PM
L8APX's Avatar
But it's just a 4 :)
Rides:REAL M3
I run that size.
Are you going to use dedicated slicks or are you looking for "One Tire for everything" including street?
Dedicated slick definatly a Kumho Victoracers, heat cycled and unshaved. They will last a while, the first few runs on them will be loose, but as they get older they will tighten up. If you get them shaved they will stick from the word go but you will get alot less autocross runs out of them. The track will also eat them up.
Here is a link:
225 50 15 TIRES
E30 M3, the only real M3
Old 03-02-2004, 07:33 PM
greateratlanta's Avatar
Rides:1995 325is
greateratlanta is a New Registered Membergreateratlanta is a New Registered Membergreateratlanta is a New Registered Membergreateratlanta is a New Registered Membergreateratlanta is a New Registered Membergreateratlanta is a New Registered Membergreateratlanta is a New Registered Membergreateratlanta is a New Registered Membergreateratlanta is a New Registered Membergreateratlanta is a New Registered Membergreateratlanta is a New Registered Member
Would it be pointless to run slicks without adjusting camber settings, baring you don't have adjustable camber plates?
Old 03-02-2004, 08:54 PM
Rides:95 BMW 325is
Originally posted by L8APX
I run that size.
Here is a link:
225 50 15 TIRES
I plan on running dedicated tires for auto-x/tracking. also looking for a cheap set of rims for them. I will probably go used if I can, on both tires and rims.
Old 03-04-2004, 05:54 PM
Supporting Vendor
Rides:the shop car!
pro-imports is a New Registered Member
I noticed you posted a few posts up that you're tracking for the first time...
I'd suggest you NOT run R-comps your first few sessions out on the track. I had one guy ride with me at VIR, complete novice, first track event ever, and he was already talking about getting R-comps. You learn a LOT more on your stock tires. Once you move into a set of R-comps, things will start happening a lot faster (and more violently), and if you don't have the EXPERIENCE to recognize these things as they happen, you will get yourself into a lot of trouble.
Other than that, I have absolutely no input as to what R-comps you should run, sorry
Old 03-05-2004, 01:14 PM
Rides:95 BMW 325is
thanks for the advice, I've been auto-x for 1 year now, I don't plan on 'giving it all i got' when I Track, and I'm taking a school in may. I'm looking for 15" x 7" rims so I can run 225's, however i think 6.5" will still fit 225's is it recommended? I dunno.
Old 03-05-2004, 07:31 PM
Supporting Vendor
Rides:the shop car!
Autocross is NOTHING like going to the track. I've autocrossed full time for a few years too, there are some skills that transfer, but car setup/driving style are completely different.
This is not about "giving it all you got" on the track. When you run Rs and don't "give it all you got," you will NEVER reach the limit, your car will NEVER slide, and you will NEVER learn a single thing. I hate when students develop this mindset that you need R-comps on the track. If you're not pushing it, then how are you going to learn? It's much easier to push it on street tires, things happen much slowly, and you actually start developing reflexes and experience. When you run street tires, the limits are MUCH lower, you will slide a LOT, and you will learn an INCREDIBLE amount.
Anyhow, if you have your mind set on going Rs, then it's your decision, and you're just short selling your time on track. 225s should go on a minimum of a 7" rim.
Old 03-07-2004, 02:02 PM
Rides:95 BMW 325is
It's actually more of a factor of not wanting to ruin my T1-S' so my option is getting another set of tires.. why buy street when there are R compounds. I realize track is completley different, and the problem in my area is it is hard to find Track time. and there are very few events (very few).
i'm no pro at auto-x either, but I want to be more competitave ( I know seat time be better driver first blah blah). I seem to be getting faster and faster each event, I came in 12th out of ~50 entrants. the 11 people before all had R's I was the fastest guy on streets, but I can't seem to catch up to them...
my main focus is auto-x because track time is rare.
thanks for your input.
topic question: is it hard to find 16" R's? are they a lot more expensive then 15"?
Jeremy
Old 03-10-2004, 08:37 AM
Rides:BMW, M coupe, 1999
Schneller Bayer is a New Registered Member
Check out the tire rack and select your vehicle. There are some lightweight 15/16x7's that you may like, such as the ASA AR1, and the Borbet (I forget which one, but it tells you the weight of some), or if you have the money, go with SSR, 15 or 16. Their 15x7 wheel weighs a paltry 10.6 pounds.
Die Ultimative Freude am Fahren:
BMWs Automotive Erschaffungen sind
und werden unvergleichbar bleiben
Armin
Old 03-17-2004, 07:22 AM
Member
Rides:J-Stock E30 M3 #10JS
M-bird is a New Registered Member
Too soon for track tires for you IMHO. Do a half dozen track events on street tires - they are more foorgiving and have less grip - it will force you to be a smooth driver. r_comps have more grip and can compensate for poor skills.
Trust me, I went from novice to licensed Club Racer in a year and a half and I started on street tires...
FYI you are asking about R-compound tires, not slicks. True slicks would rip the suspension out of your car.
Kosei 15X8 wheels, light, direct fitment. For a street tire that will be a good starting point for what you want go with Falken Azenis Sport 205/50/15
Read books too,
Ayrton Senna's Principles of Race Driving
Skip Barber's Mastering the Art of Race Driving
Paul Frere's Sports Car and Competition Driving
have fun, be safe and make your own luck by being prepared in advance.
Eric Heinrich
Eric Heinrich
JS 10
Sansossio Autobody
HMS Motorsport
www.bmwccaclubracing.com
Old 03-17-2004, 07:39 AM
Rides:95 BMW 325is
Thanks, because of the deal I found. I'm going with 16" Racing dynamic wheels with toyo proxes with ~ 50% tread life left for 500!! I'm sticking with streets this year. can't beat that price.
Old 03-17-2004, 07:59 AM
Member
Good decision. Have fun.
Eric
Eric Heinrich
JS 10
Sansossio Autobody
HMS Motorsport
Old 03-17-2004, 04:05 PM
L8APX's Avatar
Rides:REAL M3
Eric
Word
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469
