Go Back   DTMPower BMW Forum > DTMPower > Motor Sport
Old 02-28-2004, 04:01 PM
what kind of camber are some of you running front and back
Right now I have -2.8 front with about a little less then a degree to go in the front.
In the back I have -3.5.
Running on hoosiers SGS.
Pro Imports aligned it for me today just as a base and then we will mess around with it at the track once we get the tire temps. They also installed my camber plates, rear shock mounts, and new differential.
Old 02-29-2004, 12:00 AM
Rides:VW/BMW
LITEWAITM3 is a New Registered Member
You won't get numbers from the guys who are fast
Its a cut throat world in that respect in BMWCCA. Not many guys will share thier setups.
From what you just mentioned, you need to look into getting data on your car and setting it up for yourself. Each car isdifferent, and those settings seem a little off.
To find out what camber will work for your car/tires/etc ...Just grab a tire pyrometer and have your crew take temperatures when you come in off the track, and they will make the proper changes.
Also you know they are called Hoosier SGS because they are the SGS class tires, the actual tire is not called "hoosier SGS"
Heres the GA tire array http://www.hoosiertire.com/grandam.htm
Old 02-29-2004, 05:35 AM
Max M3's Avatar
20 min in the future
Rides:few people nuts!
Max M3 has achieved their Master LicenseMax M3 has achieved their Master LicenseMax M3 has achieved their Master LicenseMax M3 has achieved their Master LicenseMax M3 has achieved their Master LicenseMax M3 has achieved their Master LicenseMax M3 has achieved their Master LicenseMax M3 has achieved their Master LicenseMax M3 has achieved their Master LicenseMax M3 has achieved their Master LicenseMax M3 has achieved their Master License
Re: what kind of camber are some of you running front and back
Originally posted by Dado
Right now I have -2.8 front with about a little less then a degree to go in the front....
More.
heh heh...
f-> -3.12 toe: +1/4"
r-> -2.0
///Max
Taking the season off from racing to play a little more music!
MaxBoogie Blues Project
Old 02-29-2004, 10:42 AM
Rides:VW/BMW
What Toe are you running? Since its being trailored now, I suggest you adjust that accordingly with the camber.
Just do everything at one, get the scales out, camber/caster/toe guages, and get itall aligned.
Old 02-29-2004, 02:08 PM
Max M3's Avatar
Well since you brought it up... what might be the proper sequence for getting a car corner weighted (assuming adjustable coilovers)? In other words, should one get an alignment done first then cornerweight, or the other way around?
Seems that adjusting the spring perches will affect an already performed alignment, doing an alignment may possible affect a previously done corner weighting... I just don't know of anyone who can do both simultaneously.
///Max
Old 02-29-2004, 02:17 PM
Rides:VW/BMW
You basically answered your own question
When you adjust the height your other alignments are going to change. So corner weight/balance, then set camber/toe and be as consistent as possible.
Depending on your suspension configuration (if you are using stock pickup points, which most are, unless its a purpose race built chassis) the height will be dependant on what you are running, clearances, and the angle of your A-arms. The real purpose of coilovers is to be able to changre weight distrubution, since a racecar should be as low as possible anyways. This is why for example turnermotorsports E46's look very low, because they have moved pickup points. And in some purpose built race and "mod" cars, the roll center can be below the ground, with a CG as low as possible with a good balance (which for e36/e46 is right at 50/50). It gets fairly complicated when instead of tuning suspension you are designing it, choosing pickup points, bellcrank size/ratios, its a little easier with Mcmpherson struts, but theres still quite a bit involved in determined the proper range of camber/caster and toe, that with given tire properties will yield the maximium grip and properlyutilize the suspension.
If you are really interested, you can pickup some Milliken suspension design books.
Old 02-29-2004, 03:06 PM
Max M3's Avatar
Yeah, but it never hurts to have a little backup... ;-)
But to be more specific, my car is a daily driver 1st, auto-xer 2nd, and track car 3rd. I have TCKline Tru-match coilovers, Turner bars, and KMAC camber plates, all on original mounting points. As I'm in the Northeast, I raise the car for the winter and lower it for racing season. Of course that means alignments twice a year too!
This season I want to balance the corners. My basic plan is to:
A. lower to desired height.
B. get alignment done
C. corner balance
To me, that seems the most logical plan...
Again, looking for either confirmation or alternate plan...
///Max
Old 02-29-2004, 03:11 PM
Rides:VW/BMW
I would say:
1. Lower the car to desired height without going below the point where your a-arms are parallel to the ground.
2. Get corner Balanced, each corner will probably have its height changed slightly, depending on how accurate your height adjustment was.
3. Get alignemtn of Toe, camber, and caster if needed.
If you have the alignment done first, once you change the heights, the camber/toe will be changed.
Note: If you have a knowledgable shop (any race shop "SHOULD" know how to do it) just tell them what you want. They will know what order to do it in...hopefully
Having an alignment done can also be done at the track when you are dialing in the car. For all conditions/tires/setups your chassis/suspension configuration will be different. If you have the camber plates, tire pyrometer, and proper measurement and normal tools, you should be able to set your front camber in like 20 minutes.
Old 02-29-2004, 06:53 PM
Scho's Avatar
Moderator
Rides:1999 White M3
I dont think you should be running that much negative camber in rear. Most guys I talk to are not running near that. It is more like -3 front, -2 rear.
Old 02-29-2004, 08:11 PM
Rides:VW/BMW
It depends on tire and setup. Somepeopelc an be fine with -2front, some might need -6 up front...
Old 02-29-2004, 08:43 PM
SG_M3's Avatar
Rides:#56 IP M3
-3, 0 toe
-2, 1/8" toe in
Sean
Old 02-29-2004, 08:48 PM
Rides:VW/BMW
SG I assume your car is a street car more then the track seeing the 0 toe up front.
With the slicks, and it being a trailer-to-track car, you can go about 3/16 toe out fornt, and 1/8 toe in the rear sounds good.
And caster depends on what camber plates you are using, and what else was done when they were installed.
But as for camber, you really have to find out for yourself how it changes with conditions, tires, etc. Really all you need to do is bring the tire pyrometer, and look at the temps...thats your best companion at the track.
Old 02-29-2004, 09:09 PM
Matthew C Smith's Avatar
Rides:hellrot machine
Yeah I remember a few years back hearing that Pierre was running upwards of -5* up front.
Me?
I'm just at a lowly -2* all around.... I may kick the front up to about -3* in the spring though. We'll see.
Old 02-29-2004, 09:12 PM
Rides:VW/BMW
Just adding more camber in any situation won't always help. He probably runs about -6 becuase he might have Dunlops, they require a bit more camber then other slicks. Each tire/setup has a different setup. No two cars can really have the exact same setup work perfect for them.
Old 02-29-2004, 09:33 PM
SG_M3's Avatar
Rides:#56 IP M3
Its my daily driver that sees about 6-10 track events a year. I'm running non-solid rtabs, so i need that much toe in.
No plates, just swapped 96+ hats, and 6+ degrees of caster.
I would love to get a hold of a pyrometer, but don't have one.
Sean
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
