  #16 (permalink)
Old 02-29-2004, 09:37 PM
Rides:VW/BMW
LITEWAITM3 is a New Registered Member
Yea thats the one thing everyone really needs if they want to dial in thier car correctly. Fairly cheap at $90 for the economical Longacre. Unless you arecompetitively racing, you don't need the higher end memory model.
And good camber guages are not cheap, but they pay for themselves with the accuracy and preciseness over the competition.
  #17 (permalink)
Old 03-01-2004, 11:18 AM
vjlax18's Avatar
DOHC Vanos
Rides:lots
vjlax18 is a New Registered Member
~ -4+ F and -2 rear now... thanks SG_M3!!!!
  #18 (permalink)
Old 03-01-2004, 11:35 AM
into things retro
Rides:2001 S54 M Roadster
scottn2retro is a New Registered Member
I'm actually limited by SCCA T2 rules to -2 deg. camber.
  #19 (permalink)
Old 03-28-2004, 08:47 PM
Rides:03 E46 M3,95 M3
GMGBMW is a Permit Holder
Dado..
Cmon man,, Just call me and we will set it up..
Or ask Sofronas.. he will gladly share the set up with you ..
Fabryce Kutyba
Global Motorsports Group Inc
SCCA Speed World Challenge Touring E46 325ci # 29
Grand Am Cup E46 M3 & E36 M3
BMW CCA E36 M3
2001/2002 USTCC Champions
  #20 (permalink)
Old 03-28-2004, 08:48 PM
Rides:86' Peterbilt, 08' 335I Coupe, 07' Yamaha R6
thank you
  #21 (permalink)
Old 03-31-2004, 01:59 AM
Feenin4OpconLaminova
Rides:E36 M3, 951
megatron is a New Registered Member
F: -3.5*, 0 toe, 6 caster
R: -2.25*, 1/4 toe in
  #22 (permalink)
Old 03-31-2004, 06:38 PM
OldSkoolBmw's Avatar
My Car is Slow :)
Rides:1969 Alpina 2002ti
Anyone have a recomendation for camber gauge... I have one that's a bubble level with an adjustment knob on like kinda a Tsquare lookin thing... I'm curious if those things are accurate or if those magnetic hub gauges are where it's at or what's the good tool to use... I'm running about 2 degrees in the front and 1.5 degrees in the back on hoosier R3S03's.. seems to work well but I don't think I have any way of measuring castor with my device....
1969 2002ti Alpina
  #23 (permalink)
Old 03-31-2004, 06:48 PM
Rides:VW/BMW
Well if you got some cas around, order alongacre tire pyrometer and thier toe/camber guage.
So you can determine what camber you need with the pyrometer and make sure you are consistent with the guage.
  #24 (permalink)
Old 03-31-2004, 10:30 PM
My Car is Slow :)
It's a good deal.. I remember camber gauges and pyrometers being much more expensive than $139 and $89 respectivly... that's alot of bang for not alot of buck... never considered using my laser temp gauge for a tire pyrometer... sounds like it might work... but then again... for $89 you can get your answer for sure deep down by the cord... $389 for their one with tire memory is a nice deal as well... thanks for the tip...
1969 2002ti Alpina
  #25 (permalink)
Old 03-31-2004, 10:36 PM
SG_M3's Avatar
Rides:#56 IP M3
you can't use a laser temp for tire temps, you need a pyrometer.
Sean
  #26 (permalink)
Old 03-31-2004, 10:45 PM
Rides:VW/BMW
Yep what Sean said Lasers arefor break surfaces, engine surfaces, and ground surface readings.
If you just took the surface temps of your tire with a laser thermo, you would be getting the wrong temperatures.
  #27 (permalink)
Old 04-06-2004, 11:53 PM
Member
Rides:1995 M3
ptsbmw is a New Registered Member
adjustin toe?
i have an 95'm3 with H&R Sport Springs and blisteins sport strut/shocks. 17x8 all around
235/40-17 i need to get an alignment is there any suggestions as to what i should have it set to ?
  #28 (permalink)
Old 04-07-2004, 04:12 AM
Matthew C Smith's Avatar
Rides:hellrot machine
Front or rear?
If you want to save the tires, I've had pretty good luck with 0.0* up front and 0.2* total in the rear.
  #29 (permalink)
Old 04-07-2004, 10:52 AM
Member
Rides:1995 M3
front and rear so 0.0 front and 0.2 rear thats positive or negative?
  #30 (permalink)
Old 04-07-2004, 11:09 AM
SG_M3's Avatar
Rides:#56 IP M3
You are stuck with the camber you get in the front its non-adjustable, caster isn't adjustable either. Only toe is adjustable with stock adjustments. Matthew is saying 0 toe in the front.
In the rear camber and toe are adjustable. Get the camber under or at -2 degrees, and .2 total toe in.
Sean
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
