Go Back   DTMPower BMW Forum > DTMPower > Motor Sport
Old 01-17-2004, 01:19 PM
kiley_sean's Avatar
I'm Brian Fantana...
Rides:'05 EVO MR
kiley_sean is a New Registered Member
Does Staggered tire set-up always= Understeer?
I just bought a set of Fikse FM/5's (used). They are 17x8 front and 17x9.
I already have a set of staggered 18" wheels, and really wanted to pickup a set of non-staggered 17" wheels for autoxing, and as a spare for when I send my 18"s to get straightenend (Don't buy MAS Italy wheels, they are weak).
Anyways, I couldn't resist the bargain on these Fikse, and snapped them up.
I have a 330ti that has alot of weight upfront. I know it is not 50/50 balance anymore since I still haven't pulled the battery out of the engine bay, and added a 6-cyl. radiator and electir fan.
My question is :Would running a slightly staggered tire setup- say a 225/40/17 front and a 235/40/17 balance things out..... or does the F/R weight distribution not have such an effect as the tires?
I am just going to be Autoxing, not tracking (yet ).
Second option, would be to throw 235/40's on both front and rear. Yeah, I know I won't be able to rotate them, but that doesn't matter to me. Does the 1" difference in rim width play any effect on anything?
Third option. Try and trade 2 of my Fikse FM/5's to another owner so we can both have matching sets.
4th Option. Maybe I should just STFU and just deal with it!!! That will probably be the most likely answer from you guys!!!
Anyways, thanks for any oncoming advice.
Kiley
'05 Evo MR
Pictures
Old 01-17-2004, 09:40 PM
Matthew C Smith's Avatar
Rides:hellrot machine
A staggered setup typically will mean more understeer, but it could be worked out with a suspension setup. Really though, unless you've got monster power, the way to go is the same size tire all around. If you've got the staggered wheels, your best bet it to try and go with the same thing all around despite not being able to get the best footprint possible out of both tires.
I suspect your car is a little front heavy at this point, but it couldn't be too terrible. Is the ti's wheelbase shorter?
Old 01-17-2004, 10:24 PM
kiley_sean's Avatar
Rides:'05 EVO MR
No, it's the same wheelbase as the E36, like ~108", if I remember correctly. If with the M44 318ti achieved 50/50, then with an extra 100-150lbs of an S50 (some past the front hubs), M3 front suspension &brakes, and a heavier radiator setup & electric fan (which is way at the front of the vehicle), I can see this mother easily being 60/40 F/R., no BS!!!
I plan on weighing it at my work sometime soon to get the actual C/B of it. There just isn't enough meat behind the rear axles. A full tank of fuel, and a 45lb weight strapped in might do the trick though!!!
I guess I will be going for a 235/45 all around then. I am not looking for a perfectly "neutral" handler, just not too much of either side-affect.
I understand that Autoxing is more driver skills than anything else and that a good driver can overcome alot of problems. I just want to go in there with somewhat of a "balanced" car.
So will the different wheel widths will play a role in the footprint?
Anyways, thanks for the advice, Matt.
Kiley
'05 Evo MR
Pictures
Old 01-22-2004, 12:56 AM
Rides:Honda, Prelude, 92
MrPayne is a New Registered Member
4 x 235 is not neccessarily faster than 4 x 225...
Old 01-22-2004, 05:12 AM
Why the 235 45? Most people and the M3 came with 235 40 17's
Anyways, If you put something like a 255 on say a 17x8" wheel you're going to balloon out the tire basically, so the footprint of the tire's not going to be very square. If you were to go with something like a 205 on the same wheel, it's going to really be stretched over the wheel.
I wouldn't worry too much about the 60/40 weight distribution. You'll have lots of extra power that'll help the car to rotate anyways.
Old 01-22-2004, 02:21 PM
kiley_sean's Avatar
Rides:'05 EVO MR
I wish I could go to 235/40s, but because of my Darn MAShaw front bumper, my 225/40/18' fronts are barely tall enough to get me over most of the bumps and drvieways, etc. If I went to a 235/40/17, I would be hitting all kinds of crap, especially my driveway (yes, I come in at an angle).
I also have bent 3 of my MAS italys, so I kind of want to get a little more tire on the rims. I am just tired of having to keep the car under 80mph because of the "shakes".
I am most likely going to go with the 235/45 all around and see where that gets me. I am not a pro at AutoX, so it's not really that big of deal, like you said.
Now that I think about it, the big thing hurting me is my non-LSDifferential and it's short final drive of 3.45. I hope I can control that beast exiting the turns but I am expecting to spin out a couple of times (Noob). Anybody want to go see a guy spin his car out?
Thanks for the advice.
Kiley
'05 Evo MR
Pictures
Old 01-23-2004, 05:09 AM
Good luck with it and I know what you mean about minimal ground clearance.
Let me know if I can do anything to help.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
