  #46 (permalink)
Old 10-31-2005, 09:12 PM
Got DINAN?
Rides:1999 BMW M3 DINAN
hbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master Licensehbombfilmsstar has achieved their Master License
Alright. that's it, all you guys are talking about overfilling oil is bad well heres my life story. I run 8 quarts of oil when going to the track and when driving around daily. My motor runs very strong and never had a problem. Ur going to need to run with 8 quarts of oil on ur track day. i did one drift event with 7 and my engine burned 2 quarts during the event and the lifters were ticking all the way home. with 8 and 3 spare qt's i have no lifter tick whatsoever. well except for the oil consumption but 1 qt every 400 miles isn't excessive at all says bmw, they say it's my driving. now they say it's my oil weight. whats next? 10w60 isn't thick enough. they will probably say put gear lube in now. lol.
  #47 (permalink)
Old 10-31-2005, 09:31 PM
SG_M3's Avatar
Rides:#56 IP M3
8 qt? wow thats alot, you might be getting froth in the oil pan.
7 should be fine. Try running 15w50, I run in in my race car and have 0 oil consumption.
Have you done a compression/leak down test on the motor?
Sean
  #48 (permalink)
Old 10-31-2005, 09:37 PM
nondescript's Avatar
All Your Base
Rides:99 M3
Ummmm... No. [sarcasm]I think just a few of us have said that some motors need extra oil[/sarcasm]... Seriously, do more searching, you'll find that some motors - like the S14 (I think) will develop more oil pressure when you have a larger oil volume in the engine, and blow out the main shaft seal when you add too much oil. Others like the M50 family and derivatives (like in your car) have a constant pressure that is independent of oil volume in the system... Now you are only talking about adding enough oil to keep your oil sump pickup submerged at all times and that is a very different story.
Check your rings, I have a low mileage unmolested copy of the us flavor of the M3 and don't have anything CLOSE to the oil consumption issues you are describing - while autoXing etc etc. And um.... Don't use Mobile 1.
  #49 (permalink)
Old 10-31-2005, 11:02 PM
SG_M3's Avatar
Rides:#56 IP M3
Originally Posted by nondescript
Don't use Mobile 1.
Your not the first person to say this, but why? not trying to be an ass, i'm just wondering why.
Sean
  #50 (permalink)
Old 11-01-2005, 07:19 AM
All Your Base
Rides:99 M3
I need to find a website that can explain it a bunch better than I ever could, but there are a few things about it that are bad. First, it doesn't hold up to high pressure high speed shearing tests like some other synthetics do. Also, I've talked with a number of guys who feel that it runs "thin" for it's given grade, so M1 5w30 is thinner than other 5w30's on the market, etc etc... The result of that is that (especially on cars with boost) more gets by the rings and you burn a lot more of it. burning 1qt or more of mobile 1 for 1000 miles is something I've heard a lot of people with different cars (STi's, RSX's, M3's, etc) complain about.
There is another site I can't find right now, but as a primer, this site isn't bad:
http://www.bobistheoilguy.com/
  #51 (permalink)
Old 11-10-2005, 07:48 AM
werd
Rides:a car
czm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master License
I find that if I overfill my car with oil, it leaks out the rear main seal under pressure. I just check the level after every session. My car burns about 1 qt. every 300 track miles.
2007 GT3
2007 530XiT
  #52 (permalink)
Old 11-10-2005, 05:18 PM
NMJ-045's Avatar
abc123
Rides:Motor Vechile
NMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master LicenseNMJ-045 has achieved their Master License
I dont know about beemers -never looked at the inside of my sump, but with my WRX on the track you need to run a baffeled sump or you have problems with heavy track driving -esp when using slicks or very good R compound tyres. (The oil in the rex tends to pool on one side of the motor in long corners, or very hard corners.)
I have had surge a few times in the M3 on the track.
Over filling is not the answer. Remember with most cars the oil system was never designed for high g track driving.
And the right oil for your motor/application is always important.
Just my two cents
  #53 (permalink)
Old 11-10-2005, 05:26 PM
All Your Base
Rides:99 M3
Yeah, on M3 LTW or M3 GT's you have a dual pickup and an oil pan that is designed to fix the oil starvation issue... And yes, with out that expensive (and in my case, not SCCA stock class legal) option you are left with work arounds, like adding extra oil... as you said, a baffle in the oil pan is a better solution, still waiting on clarification on class legality... but for my purposes so far, the extra qt. of oil trick has done the job to prevent oil starvation or foaming, so while it isn't the answer, it does work.
  #54 (permalink)
Old 11-10-2005, 05:31 PM
NMJ-045's Avatar
abc123
Rides:Motor Vechile
Sorry didnt read the bit about regs. In that case if you cant make changes then the extra oil will have to do.
Surely they wouldnt know if you baffeled a standard sump and threw it on? -Not that I suggest you cheat but as far as protecting an expensive motor goes...
There cant be any performance increase? So not being familure with the series you run in I cant see why they would not allow you to run a baffeled sump.
  #55 (permalink)
Old 11-10-2005, 08:48 PM
All Your Base
Rides:99 M3
Yeah, I know... I think even in stock classes the rules should allow for safety of the vehicle as well as safety for the driver... Things that can prevent major damage with out providing performance gains are the type of thing I'd like to see allowed... but it's a can of worms... I can just see some strange situation where the EVO MR's are prooven after a few years to have such a high level of boost from the factory that they start blowing up engines, so suddenly under that vehicle safety clause they start running custom boost controllers and just like that you have a car with performance equipment snuck in for safety reasons... Since I have a working solution, I'm not going to push the issue... But yeah, I sometimes wonder how many people have those TMS kits welded into their oil pans.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586
