| auto-x'ing isn't new, tacking is. I was not able to get to the track because of the snow :P I will be going this spring. I was also debating to buy a 87 E30 325is to use at the track as oppose to my 95. it would be a pretty cheap car because it is a salvage title. you think it's a good idea? it is in good condition ( no bent frame) just body damage. I don't know if I can afford to loose my 95 bmw. thanks for all the tips.
__________________ http://www.bmwpower.ca |
Never, ever, EVER use silicon brake fluid. Not in these cars.
__________________ ...steven 1990 325iC • 1996 328ti • 2003 Mini Cooper S www.nccbmwcca.org www.318ti.org |
not going on a 2 week vacation to a SNAP-ON facility yo tatawaki ... bring ur car and ur car keys. Last edited by TMINUS : 02-01-2004 at 04:15 AM. |
| I take all that stuff too..... Better safe than sorry. I usually take more oil for the engine, coolant for the radiator, brake fluid and bleeder in case the fluid gets cooked, air pump to fill the tires a bit, chair to sit in when I'm not driving, a tarp to cover everything if it rains, an umbrella regardless to keep the sun off you, water to drink, and some rudementary tools like duct tape, a metal clothes hanger, etc for a limp home repair. |
Most High performance brake fluid is compatible, but I recommend flushing the system before any track event. Most clubs require it anyway. Here is a wet and dry boiling point comparison. I have been using ATE fluid for years and everyone I speak to recommends it or one of the other HP Brake fluids. http://www.seinesystems.com/BrakeFluids.htm Here is the same info from Bimmerworld.com http://www.bimmerworld.com/Tech/brakes.htm Post a thread, "Best brake fluid?" and watch. Brakes are more important than anything else on the car for a track event, period. ![]()
__________________ E30 M3, the only real M3 |
Matt, Some of that stuff is important. Come to the track with me this summer and you will see. BTW, most of that stuff fits in a milk crate and I keep it in there so I can just grab it and go. So when it you need to check you air pressures, what are you gonna do, stick the key in the valve? ![]() I will call you, we have to meet up.
| Since we're on brake fluids, here's an awesome link from Steve D. http://www.gti-vr6.net/library/wheel...d_comparo.html |
Screw that, overfill by 1/16th of an inch over the full mark, and check the level after ervery session, and don;t forget to put your oil cap back on. Check your tire pressures cold and more inportantly hot, as soon as you come off the track, and if you can do it, check temps in 3 spots across the tread, that is a more accurate way of diagnosing suspension settings and tire pressures. And don;t overfill your brake fluid by a half a quart or it will be all over the floor. |
So yeah, M-brid is right Over fill? Yes ![]()
| Im going to VIR this weekend for my first driving school. Just wanted to thank you guys for the info, this thread and section are extremely helpful, so Thanks, Brian
__________________ ![]() ::Cant trust a big butt and a smile...that girl is poison:: |
__________________ 1969 2002ti Alpina Striding on the fields, wielding an oversized scalpel, cometh OldSkoolBMW! And he gives a bloodthirsty grunt: "This one's for you, mom! I sow darkness and discord like a four-year-old on a sugar rampage!!!" |
