Go Back   DTM Power BMW Message Board Forum > Technical Discussions > Mini Cooper
  #16 (permalink)
Old 09-06-2004, 11:30 PM
Rides:E36 M3 sc - E46 M3 - E28 M5 -
Powerplay is a New Registered Member
I was reading this thread and I though I could offer some information that I received from a MINI factory engineering person. Apparently overdriving the blower is leading to poor water-pump operation. Not because the pump is weak. Once the pump speed surpasses the design limit, it causes cavitation. Once you have cavitation the water will not flow. Fortunately this only happens at the highest rpm limits. A daily driver probably won't encounter this problem as the high revs are not sustained for long periods of time. On the track is another story...
The stock blower has no ceramic treatment like the cooper-works blower. The Ceramic rotors are a very tight fit. The clearance between the rotor and blower housing is very close. They can do this with the ceramic coatings as the rotors will not grow under full duty. The stock superchargers will fail in time. It's just a matter of time and excessive heat cycles before the rotors start to gall and fatigue.
Hope this helps
  #17 (permalink)
Old 06-13-2005, 03:52 AM
ACS Driver
Rides:325ci cabrio
2//KML\\9 is a New Registered Member
hey guys what will happen to the fuel consumption of the car if i go with the 15% pulley? does it changes dramatically or not? now with full tank i can do 400 km until the light on.
  #18 (permalink)
Old 06-22-2005, 11:33 AM
Rides:'95 M3
Need4M3 is a New Registered Member
If you are using ur mini for track, i would recomand the 15% i heard the 19% gets to hot. For street ur fine with the 19%
-F.Toscano
  #19 (permalink)
Old 06-25-2005, 06:52 PM
mcs's Avatar
mcs mcs is offline
Rides:MINI, Cooper S, 2005
mcs is a New Registered Member
im waiting to do mine. i have an 05 mcs with 15000 miles. im uneasy to the pulley but need more boost. Can anyone chime in on how long they have had pulley up grades with no probs et. miles.
  #20 (permalink)
Old 10-31-2005, 02:54 PM
99MMMPWR
Rides:BMW M3 1999, BMW M5 2006
swest2507 is a New Registered Member
Talking 19% = Boom
OK, I used to work for MINI, I have seen cars that came in with 19% pulleys. They didn't live long. Either the motor would blow up or the supercharger would. The biggest problem is that the 19% pulley spins the supercharger too fast, it wasn't designed to be spun so quickly and it usually goes first. If it doesn't then you end up with a blown engine
  #21 (permalink)
Old 11-11-2005, 04:36 PM
Rides:Several toys
Enzothemaddog is a New Registered Member
I have used a 19% for a couple of years in my 'track only' MCS. I have to say you are right about eventual failure but its a long way off for most people. Its hobgobble about not tracking with a 19, most people do....or at least those with decent times if not a 17%.
As for the cavitation, i'm figuring out how to install a standalone electric water pump with temp adjustment. Adding this to JCW SC I bought so should perform without a problem.
I do have a backup SC and head if things go wrong but even with my rev-limiter based driving I expect a good 30-40,000 miles from it. Things like air ducts can slow down the failure but things do get very hot under there. But unless your a clown who does'nt realise a car needs to be cooled every ten or so laps then you probably will blow the SC with a 19%.
....IMHO
  #22 (permalink)
Old 11-28-2005, 02:42 PM
Rides:04 Mini Cooper S
djhellfire is a New Registered Member
I have been using my %15 with superchips ECU flash for 60.000kms with no problems. It is both a daily driver and track car. A friend of mine has %19 on his car w/o intercooler upgrades and he is on 30.000kms or so with no problems. But under his bonnet it is way too hot. After we drive fast for 10 min there is no way that he can go past me.
For the fuel consumption; when you floor the pedal you can see the fuel going down. My whole fuel tank finishes like 180km with really hard driving all the time. But If i stay away from being naughty, I can go about 600km s with cruising around about 60-70miles/h..
  #23 (permalink)
Old 03-10-2006, 11:29 PM
I Heart JDM's Avatar
Rides:your mom
I Heart JDM is a New Registered Member
hey any of you guy's test out the 17% pully. Any tuning or IC upgrade required? I know you have to get new spark plugs and a new belt, but is that it for the 17%? Is 17% kind of the best of bolth worlds from 15% and 19%? Any suggestions? I have about $500 bucks and lookin for a pully upgrade. Just don't know which route to take.
Thanks
Koya
  #24 (permalink)
Old 03-11-2006, 06:12 PM
I tend to overboost
Rides:mcs 05
RalphzMCS is a Permit Holder
if $500 is your budget then you could go with the 15% or 17%(add s/w and injectors later when you get extra $). There are some that run the 17% without software and bigger injectors, but it makes a really big difference if you do all three together.
HELIX 19% pulley, GIAC, helix 380cc/intake/ssk, clutchmasters stg. 3 & flywheel, optima yellowtop, LSD, invidia exhaust, obx header, flik ftd's w/toyo t1r's, h-sport competition rear sway bar and springs, V1
  #25 (permalink)
Old 03-11-2006, 06:54 PM
yeaaa05's Avatar
mk3vdub
Rides:mk3 golf
yeaaa05 is a New Registered Member
17% ftw
coul
  #26 (permalink)
Old 03-13-2006, 09:09 AM
kalvin's Avatar
super slow
Rides:02 Mini Cooper S
kalvin is a New Registered Member
i'm running the 17% with the JCW injectors. Its running strong i dynoed at 185@ the wheels.
  #27 (permalink)
Old 12-05-2007, 02:17 PM
deep throat's Avatar
Rides:Individual Vert
Region: Middle East
deep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master Licensedeep throat has achieved their Master License
Where do you get these pulleys from?
H&R///UUC///Repair Shop///ASA///TOYO///Hamann.....& Exclusivity
  #28 (permalink)
Old 12-05-2007, 07:55 PM
ESP's Avatar
ESP ESP is offline
In the US from
mini-madness
outmotoring
promini
I am sure there are a few others.
01 E53, 97 E39
  #29 (permalink)
Old 12-06-2007, 12:55 AM
Region: Middle East
Thanks for the info bro...
So is there still an issue with copreseeor wear and heat using the 19% pulley?
  #30 (permalink)
Old 03-25-2008, 10:01 PM
Rides:M3, Ferrari 348SS, SL55
Rascasee is a New Registered Member
What I have found is that for the most all-around driving experience the 15% is adequate. But if you don't tie things together with the right kind of ECU set up, you won't get the most out of what you are trying to do.
Ciao...... Dino
M3
SL55 AMG
348SS Challenge
F40 (sold)
MCS
March/Cosworth Indycar
www.VelocePerformance.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
