Old 06-15-2009, 06:03 PM
Rides:BMW, 528i, 1997
thetallwun is a New Registered Member
HELP! I cant figure out what's wrong with her!
Hi guys:
Desperately need your help here. Sorry for the length, just wanted to give all info.
Back in January, I had my car overheat which resulted in a cracked cylinder head. Didn't search around for the best indy, went the cheaper route. The guy is known as a great option to go to when welding cracked heads. (I know I know, I shouldn't have gone the weld route, but money was tight) He said replaced the PCV valve, upper and lower hoses, valve gaskets etc. Got the car back, but the car drove sluggishly. 50 miles later, the CEL light came on. Took the car back to the indy the next day and asked him what was going on. He pulled some codes, and got p1188 and p1189. He said that I prolly just needed to put more mies on the car, and that I might want to look into changing the o2 sensors. He wanted to do the job for me, but I didn't trust his opinion after getting the car back with more problems than when the car went into his shop. By now the car was idling rough as hell at stops, had no acceleration going up the smallest hill...and was sluggish past recognition. Also mpg was shot! And when driving on the freeway, in the first 3 gears, ALL of traffic passed me, as I couldn't accelerate, even with pedal to the floor.
Went to my family bmw indy and he said that things looked shifty and that I might want to call the Bureau of Automotive Repair. I'm a college student, and didn't have time to go through all of that. My family indy said he would check out the spark plugs to see if they were causing the misfiring and rough idling. He ended up changing them out with some NGK ones. The car drove slightly better for the test run, but was back to its horrible state on the way home.
Three weeks ago, I replaced the o2 sensors myself. I have a 1997 528i, build date 9/96, so I actually only have a total of two o2 sensors on my car. Immediately my mpg went up, then slowly went back down (I'm averaging 20.4 mpg, and usually cruise at 75, I used to average 28 before the car overheated)
Then a week later, I bunch of BMW enthusiasts and I with m52 engines replaced our vanos seals with the Beisan Seals. I thought this would fix the problem. While doing my vanos seals, I tried to lock my cams in the dead center position, and noticed my cams would not align. Then one of my buddies noticed that there was a paint marking on the front of the head. This leads me to believe that the jack A** that did the cylinder head job, didn't have the locking tools and realigned the cams improperly! Luckily there was a bmw mechanic hosting the vanos seals replacement event and showed me how to properly align the cams. Futhermore I noticed that the gaskets where never replaced, the same gaskets that were on the car when it overheated where reused on the engine!!! I replaced the seals, my cold start issue was gone, the car idle a little less rough, and the CEL light was gone, or so I thought. On the drive back from Modesto, CA to San Fran, the light came back on!
I have no clue what to do now. When I'm in 4th gear, the car runs like a champ. Off a dead stop its slow and sluggish. It doesnt idle as much at dead stops, but still is noticeable. At lower RPM's when driving, the car drives like sh*t!
The job done by the indy is warrantied, but after discovering that he did a joke of a job in the first place, I rather fix it myself, then go the Bureau of Automotive Repair route and let them handle things. As for now, I need to get my car running like it should.
I searched the forums, and saw that some people experienced what I've experienced, but there own situations differ from mine. Just to refresh, I've replaced:
o2 sensor
vanos seals
pcv valve
all applicable gaskets
gotten a smoke test (thought there might be a vacuum leak)
I read somewhere that people said you should check coil packs and cam sensors. I was going to have my fuel filter replaced, but my family indy said it was replaced in 2004, and that it was VERY unlikely that it was the cause of the problem. Maybe the fuel pump regulator?
Here are the codes that were pulled when I did the vanos job (Some are gone by now, like the vanos jamming):
P170
P300
P301
P302
P303
P304
P305
P306
P1189
P1188
P0173
Once again sorry for the length. I've been dealing with these problems since January, and finally have my summer break and can give more attention to this issues. All advice, comments, opinions, appreciated..
Old 06-17-2009, 12:02 AM
this is what I have so far...
P0170 Fuel Trim Malfunction (Bank 1)
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P1189 Fuel Control (Bank 2 Sensor 1)
P1188 Fuel Control (Bank 1 Sensor 1)
P0173 Fuel Trim Malfunction (Bank 2)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
