Old 04-19-2009, 11:41 AM
thomastuck11's Avatar
Rides:BMW, 525i, 2003
thomastuck11 is a New Registered Member
Talking Dinan Performance Upgrades for E39 525i
Guten Tag,
I really love my 2003 525i (sports package, steptronic transmission) but I'd like to get some more pep out of it and I've been looking at the Dinan website. However, Dinan indicates that an increase of only 13Hp is the most improvement I can achieve for my car (for about $5k).
13 Hp is only about a 7.1% increase (from 184Hp to 197Hp) in power, and it seems that I wouldn't be getting very much "bang for my buck". I'm looking to get at least a 10% increase (without having to spend $10k or more). Any thoughts and suggestions would be most appreciated.
Also, I've heard rumors that BMW has intentionaly under rated the output of M54B25 engine (published output = 184Hp). Has anyone ever put their E39 525i on a dyno to verify the output before and/or after a performance upgrade?
Old 04-19-2009, 01:03 PM
BUMP
Also, the car is a very nice ride, and I'm surprised at how much throttle is left even at 120 mph.
Old 05-03-2009, 05:25 AM
Rides:'97 E39 523i
justlikemusic is a New Registered Member
Vortech/Powerdyne supercharger shouldn't cost more than 5k.
These mods are documented everywhere... M3 cams, M50 inlet (I think M54 is ok for conversion too), ecu... there is a M50 tuning guide online somewhere, er, everywhere!
I fit a 3" CAI to my M52 and it's worse below 3k rpm, I can't even floor it without it just dying in the arse. I have to work my accellerator down firmly. However, after 3k it gets an absolutely crazy roar and goes hard to 6k+rpm. Once I do the exhaust and ECU it should run right.
Old 08-05-2009, 07:42 PM
Registered User
Rides:bmw e39 525i
lilr3dlin3e39 is a New Registered Member
Hey i also have a 525i i was wondering if you guys think a dinan ecu would do much in hp increase also i was wondering if there are any turbo kits for my car.
thanx
Old 08-08-2009, 04:33 AM
Registered User
Rides:Nissan Skyline GTR 1991
bnr32_coupe is a New Registered Member
Originally Posted by thomastuck11 View Post
Guten Tag,
Dyno runs are about $50 - $75 for 3 runs. Definitely worth your money for the assurance and peace of mind, rather than guessing. If available, go with a mustang dyno for some accurate results. It's nicknamed the heartbreak dyno because of the realistically conservative numbers it puts out. Dynojets have no load and give you very attractive HP numbers for what its worth. Let us know how it goes!
BNR32
Japans Import Ambassador
Old 08-29-2009, 08:23 AM
Palantirion's Avatar
Z4 M'vangelist
Rides:2007 Z4 M Coupe
Palantirion is a New Registered Member
Guten Tag,
-I usually advocate suspension and/or tire mods as the most cost-effective way to increase performance. But if you're after just power I would suggest contacting ESS and see if they have a twin-screw system for your car.
Old 08-29-2009, 10:08 AM
Thanks, perfect!! It appears that ESS has a 2001-2003 525i supercharger system for about $6.2k. Output = 290Hp.
I'll contact a dealer.
TT
Old 08-29-2009, 06:22 PM
Z4 M'vangelist
TT
-Send Roman an email (tell him Earl sent you): roman@esstuning.com
Old 10-27-2009, 12:54 AM
Registered User
Rides:Jermony M5 2009
t3tj30n560 is a New Registered Member
Arrow Increes & Proformence Upgrades
For U.................
BMW E39 Brake Performance Upgrades - Page 1
Without a doubt, your brakes are the most important part of your car. It doesn't matter how fast you go, you will eventually need to stop, and sometimes stop quickly. We don't recommend skimping on your brake system - do the job right and you'll protect more than your car. It's also highly recommended that you check out our Pelican Technical Article on Bleeding BMW Brakes.
Brake Super Kits
Now available from Pelican is our brake super kit for the E39 BMW. In this kit, you get everything you need to replace your front and rear brakes all at once. All the parts contained in the kit are either OEM or Genuine BMW parts. If you are spending the time and effort to pull your brake pads out, you might as well make sure that you are replacing and fixing every piece that might need attention, while you have access to it. We also allow you the option of ordering a kit with or without cross-drilled brake rotors. Here's what the kit includes:
* New front and rear rotors
* New front and rear caliper rebuild kits
* New front and rear brake pads
* New front and rear brake wear sensors
* New E-Brake shoes
* New brake disc retaining bolts
* Three liters of Ate Super Blue brake fluid
* Two cans of Wurth brake cleaner
* Brake caliper rebuild grease
* Lubro-Moly anti-seize compound
Cool Carbon Performance Brake Pads
Cool Carbon Performance establishes the new reference in performance braking for street/track and racing formulations. Both Cool Carbon compounds have been developed at German R&D facilities and have been tested extensively on the German autobahn. Cool Carbon Performance brake pads deliver true undiluted performance.
Street Performance/Track Tuned (S/T) - This compound is a higher friction level than OE, with much better torque and stopping capability. It is very stable, both cold and hot to temperatures exceeding 600 C (1112 F), due to a special "hollow" ceramic structure that exhibits excellent heat dissipation characteristics. Stainless steel noise shims, bonded to what is already a very quiet formula, ensure virtually no noise under all driving conditions. Improved pedal feel and significantly reduced dust can be expected.
S/T compound features: excellent initial bite, consistent torque, stopping ability & temperature stability; very good fade resistance; long life, rotor friendly, low/no dust; virtually without noise; excellent for daily street use and with very good track performance.
Max
make money
Old 10-28-2009, 09:37 PM
Thanks, I already have.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
