| have you changed the sway bar links and bushes??? these can both cause lots of noise but wont make any noise if you get underneath and feel for play!!
__________________ If it aint broken, dont fix it....but by all means make it better!!! |
| its a 528 not an M5......and sachs is a company that makes supension components...theres no real such thing as a "sachs suspension"....theres 100s of components!!
| I got it taken care of, some of the bushings were totally shot to hell. I also put in my new shocks and springs as well. It's like a totally new car.
__________________ "Education is when you read the fine print. Experience is what you get if you don't." ![]() |
| My 528i makes a similar noise over bumps I was prepared to get the bilstein hd's on my stock sport springs to fix the problem. But for you was it the strut or the bushing that made the noise, and which one fixed the problem? thanx |
| Actually the problem was the sway bar links. The factory ones were shit. The bushings ended up being fine (originally the shop thought those were the problem) but I had them replaced since my car was in pieces anyway. The shop I had work on my car actually ordered new sway bar links with a nylon mesh material instead of the rubber that was originally used. One of the links actually had zero rubber left and it came from the front left which was loose as hell all the time. I hope this helps. The next job for me is to fix out my drive line clanks. I think some of the bolts on the drive shaft have become loose. I just need to see what's loose first. This car has had the weirdest shit break on it but fortunately nothing major has gone wrong and I pray it stays that way.
| Well, it comes down to personal preference. I think 18's look pretty good on an E39, but the wheel wells can easily accommodate 19's. I think the biggest factor though is wheel width. The fronts are not so much of a big deal but for me the rear wheels need to fill the entire well. Currently, I have a new set of Beyern Mesh Type wheels with a black hub on order. I went with 18x8.5 front and 18x9.5 rear. I wanted to go with 19's but a lot of the roads here in New England are truly terrible. I wanted a little more tire to cushion the ride a little bit so I didn't go with 19's.
| I was debating between: SIZE - 19X8.5 FRONT 19X9.5 REAR with OFFSET - 13MM FRONT 15MM REAR or (18X8) with 2" Machine Lip 20MM Offset. also for brakes: pre-drilled& slotted, would the slotted really wear my pads down that much. Should I just go with pre drilled for every day driving? and Have you heard of MAGNUM (Made in Canada) CROSS-DRILLED ROTORS or possi quiet pads? sorry for the short essay! thanx |
| I didn't really notice any changes in acceleration to be honest, however I did notice that the car handles much better than it used to with the factory 16x7's.
| Do you what your stock wheel's weight or even how much the 17inch basket are, my deal now is that i don't want a rim thats to heavy or feel like I'm driving a boat.lol |
