Old 05-14-2007, 11:16 AM
cornercarver's Avatar
Track License
Rides:BMW 540ia, circa 97
cornercarver is a New Registered Member
Depo light install...HELP
Installed! See how I did it below! Thanks all!
I got my Depo lights today, they look nice. Problem is is that a 3rd grader wrote the instructions onto 2 pieces of paper one sided which means there is not a lot to go on. In fact it, its mostly pictures for cavemen or qualified electricians who have done this many times. Anyone in westside washington near oly done these swaps before?
Carving Corners German Pimp Style
Old 05-14-2007, 11:47 AM
Rides:2008 MB ML350 & C300
I'm sorry to hear that your headlights are screwed up. Would it help if I took photos of my Hella install?
Old 05-14-2007, 11:52 AM
Track License
I started taking the lights out and hit my first obstacle. The tray's that are under the PS res. Looks like I try to remove them or work around them by bending them back. I dont have a manual, so I have no idea whats under the lights holding them in. Bolt? clip? Are there only four locations holding the bracket in?
I am disappointed in the quality of instruction for the Layman though. Any help appreciated.
Old 05-15-2007, 05:01 PM
Track License
Thanks for those that helped. Lights are in and look sharp. I havn't hooked up the angel's yet for that is another day. Lights are easy to take out. I thought it would be more difficult than it was. FYI for all... Just four bolts and unplug the bulbs, and I didnt have to cut the power. Reverse that for install and dont forget the trim piece and gasket that sticks to the old light. Depo's have my seal of approval.
Old 05-17-2007, 01:44 AM
legendary's Avatar
502MotorSports.com
Rides:e39 540i | e46 325xi | e46 330i
legendary is a New Registered Member
good deal. let me know if you need help with wiring
The instructions are horrible
Thank you,
Leon Millette
502MotorSports.com
Old 05-17-2007, 11:11 AM
Track License
Thanks, Legendary! I'll probably run into a prob tonight when I try to hook it up. So far, I have put in the lights, put the bulbs in, attached the wiring that went directly to the bulbs to the depo hookups, and just have the angel eye wiring and harness left. there is an extra male 2 pin receiver that dangles with the AE wiring, I think its extra for maybe HID or something. I will check it out again and post when I do. Again, thanks.
Old 05-17-2007, 09:50 PM
legendary's Avatar
502MotorSports.com
yes, you are going to end up not needing one of those harnesses, but do not cut it off.
If you were to cut it, the AEs will not illuminate.
It is weird how they were setup, but once wired, they will look better than OEM imo.
Thank you,
Leon Millette
502MotorSports.com
Old 05-21-2007, 01:19 PM
Track License
Taking the @#$%$# thing in and have it done... @!#$%$
Old 05-21-2007, 11:24 PM
legendary's Avatar
502MotorSports.com
man, I wish you had contacted me - I could have helped you with it. I did it myself
Thank you,
Leon Millette
502MotorSports.com
Old 05-22-2007, 01:39 PM
Track License
Well as luck would have it, my mechanic, Count, is booked for a week or more so maybe you can. I will take a pic of the remaining wires I have left and the harness and maybe you can give me some advise if thats alright?
Old 05-24-2007, 04:52 PM
Track License
Angel's in!!! Found out something very important regarding these Depos... wiring harness is useless. I just tapped into my parking lights with crimp connectors and fuses, a couple of zip ties and wallah! I lost one of my headlight bolts in the underpan though. Here I come ACE hardware.
The lights are way easier than I thought. The crappy instructions make it look complicated, as it is not explained very well. In fact, your supposed to get to the wiring under the cabin filter. Does it tell you that, no.
No Harness Instructions: More like suggestions. I am not liable for your install, no matter how good or bad you do.
On the Drivers Side, just use the brown as ground from the blinker and tap into the black wire. the grey green wire from the blinker is the hot that goes to the blue wire and done.
On the Passenger side, the colors are different. My ground was the same but the hot was grey blue wire to the same AE configuration. Hope this helps someone out!
Old 08-13-2008, 02:24 PM
Rides:BMW, 528i, 2000
Lopaka13 is a New Registered Member
I would like more information on how to install these as well. I am interested in upgrading my 2000 lights to the newer look. I am torn between buying the Depo's at a lower price versus being the Hella lights. I have stock Xenon and the auto-leveling feature as well. I found the Depos on ebay but they come with no instructions. Any and all advice is welcomed.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657
