Old 05-12-2007, 10:26 PM
toxik iroc's Avatar
Track License
Rides:chevy, iroc camaro ,1987
toxik iroc is a New Registered Member
bunch of questions need help asap!
~EDIT ALL~
I have a few questions, mabe you can help me get them answerd
1. can H.I,D’S be installed on a 535I 1989 bwm? If so what would it take to do this? How much would this cost? What brands/parts should I look for?
OR
2. Is it possible to switch the light set up that is on the car now{ the two speaperate lights } for the newer style lights like on the m3{ I think} if im imstaken the headlights im talking about are the one unit that is inclosed
3.In the glove box there is a rechargable flash light. My question is if it is plugged in and in the on possition should it be lit up? Or does it only turn on when it is unplugged? What can be the causes of the flashlight not working? Besides the bulb.
4. The left windshield washer nozzle(where the water sprays out from) on the drivers side of the hood, is clogged. It only trickles out when the button is pushed,and does not reach the window. How do I unclogg it, So it works proporly?
5. I what more horse power and torque, I don’t have a lot of money, any cheap mods that I can do to get some more power out of this car? Any mods you can do for free? If so any tricks you guys know of?
6. where is a good place to get parts for bwm’s? For OEM and performance parts with my american car I just go to summitracing but ive no clue where to go for a bwm so please shed some light.
7. what are some good fog lights to upgrade to?
Hope this is better
~EDIT END~
thanks for the help
Old 05-13-2007, 12:06 AM
Rides:2008 MB ML350 & C300
I know this is the Internet, but please write in sentences. It gives me a headache trying to decipher what you are attempting to say.
I'll make you a deal: if you re-write your post with proper grammar I will thoroughly answer every question.
Old 05-13-2007, 07:54 AM
toxik iroc's Avatar
Track License
hey man
First off, im sorry for all the grammar issues.
hope this is better
Old 05-14-2007, 02:50 PM
cornercarver's Avatar
Track License
Rides:BMW 540ia, circa 97
cornercarver is a New Registered Member
I'll chime in on a couple... HID's and cheap shouldn't be in the same sentence. Its more expensive. See if you can get an all in one package deal through ebay on the lights including bulbs.
Regarding the flashlight. Its probably the battery. Open it up and take it to radio shack or somewhere and see if you can replace it, or look for a new one on, again ebay.
Cheapest bang for the buck? I have a V8, so its a little harder for my car, but I would assume chip is the most bang for the buck. Air filter setup, exhaust, maybe underdrive pulley's. Lop off your Cat ( I dont endorse that) I have also heard of changing out the mass air for a 540i unit. The Search button on yahoo with the words "cheap bmw upgrades" should net you a wealth of information. Then there is always NOS. Better be careful with that and your engine though.
Bavauto, BMP, Turner, in your case, Ebay probably. Nothing is really "cheap" on BMW's.
Carving Corners German Pimp Style
Old 05-14-2007, 07:57 PM
toxik iroc's Avatar
Track License
thank you for the info
So H.I.D's aren't cheap, but how much are they around?
what brand air filter to get ? or are you talking about a cold air kit or somthing of that sort.
what would changing out the mass air unit do ?
im staying away from nitrous. i want constant power....superchargers and tubos are outa the budget.
the flashlight is a rechargable unit meaning no batteries needed
lol i know nothing about these bmw's......
Old 05-14-2007, 08:23 PM
HIDs can cost anywhere from 200 for knockoffs to 600+ for pricier kits. Check out HID XENON CONVERSION KIT 3000K 4300K 6000K 6500K 8000K or Welcome To Xenonking.
Air filter can be either a drop-in filter that fits in the stock airbox, or an aftermarket intake such as: East Coast Induction System :: Intake Systems :: E39 5 Series Intake System (97-00) 528
Changing the mass air will allow for more air to enter the engine and is typically calibrated with engine reprogramming. Not many companies make this part for BMW's - mine is from Dinan, but for the six cylinder motors you should be able to use an HFM from a 540 as they come stock with larger HFMs.
The flashlight is rechargeable, but since the vehicles are older, the battery may not be holding its charge. These batteries are soldered in, and require a little surgery to replace.
Old 05-14-2007, 08:29 PM
Track License
Just beat me to the bunch, James. I wasnt sure if I was going to answer the flashlight thing. I have heard the Mass air works great with the reprogramming, but a custom tune may cost a little.
Old 05-16-2007, 06:13 AM
toxik iroc's Avatar
Track License
what is e39?
thanks for the help with the flash light.
i dont know if that intake system would work for me,ive got a 535i 1989 and not a 97-00
how much is this mass air flow sensor. where could i get it? wouldnt just disconecting the batt for aboput 20mins make the comp reprogram its self?
Old 05-16-2007, 07:19 AM
E39 refers to the BMW Chassis code. The engine in the '89 535i is known as an M30 - which refers to the BMW engine code. When you are searching for engine modifications, you should search for M30 mods, as this engine was used in numerous other BMWs as well.
As far as intakes go, the one made by Turbo Charging Dynamics looks pretty good. I would search out a used one in good condition and save yourself some money over the $225.00 retail price:
I'll have to do some more search regarding swapping out the mass air-flow on your vehicle.
Since it's an OBD1 vehicle, you are in luck. You will be able to purchase a chip instead of getting more expensive engine reprogramming. Conforti makes excellent OBD1 chips, and you can read the details here: M30 Chip Just like the Intake, I would search for a used version. Typically there are different ECU models for each vehicle, and you have to make sure yours matches the one of the vehicle you are buying it from.
Old 05-17-2007, 07:56 PM
toxik iroc's Avatar
Track License
Awsome, thanksfor the help! are these intakes commonly found for sale and used? how much do they go for used?
keep me updated on the mass air swap info please.
Old 05-18-2007, 02:33 PM
Boost Issues
Rides:E34 535turbo, E34 535i-SC, B5 A4-1.8TQ STG 3
racer535 is a New Registered Member
The best place to get the MAF mod is from Miller Performance Their is only $500 compared to the rest which are closer to $1k. This generally give you about 10-15hp and I believe it includes a chip. Theirs is actually cheaper than the used one I'm selling. (Although mine allows you to adjust the air/fuel mixture on the fly).
The drop in filter is the cheapest, but doesn't do much(5hp). Same with the CAI. The stock intake sits next to the exhaust manifold, so unless you have a really good heat sheild, it actually causes a lose in power. Good luck finding a used one, I rarely see any.
Exhaust mods only yeild a better sound. My car lost power when I went to the exhaust/intake combo, until I got a chip. The engine needs back pressure to create its torque and without it, its a slug.
A chip helps a lot, but you'll have to use 91+ octane gas, all the time. EAT/D'Silva and Jim Comforti make the best M30 chips. It takes about 20minutes to pull the old chip and install the new one, if you know what your doing.
Nothing's cheap on a BMW for mods. The best bet for used E34 parts is bimmer.info or bimmerforums.com (the 2 biggest E34 online groups)
MAF-$500
Intake-$200
Chip-$150 used to $250 new
Exhaust $700
Realistically, if you engine is in good shape, the next cheapest thing for power is a stage 1 turbo. THe best bang for the dollar. I had a streetable M30 built as NA tune and only got 210rwhp (160-170rwhp stock) for over $6000 spent. Stage 1 turbo will give you 250rwhp easily.
Racer535
Redfive - 1989 E34 535GTR - TCD S2 w/ 3.6l M30/M106
1998 Audi A4 1.8T Quattro APR STG 3 - For Sale
Redfive Racing
Old 05-18-2007, 04:16 PM
toxik iroc's Avatar
Track License
wow, all this stuff is awsome thanks fdor the help. how much does the tubo cost? with the turbo wouldnt i need intercooler and all that?
Old 05-20-2007, 09:28 AM
Boost Issues
Stage 1 non-intercooled = $3850
Stage 2 intercooled = $5500
Although you always need to figure on more than that to get the job done. Its never cheap, but totally worth it.
TCD
The M30 has a low 9:1 compression ratio, so you can boost it a good deal before needing an intercooler.
FI is a great upgrade for this engine and really makes the car come alive.
Racer535
Redfive Racing
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476
