| Which wire can I use for ground for indiglo gauge install? Hey guys, I just got a visionwerk indiglo gauge set. I got everything up except the wiring. I can't seem to get it to turn on. I got the positive from the grey wire with red stripe from behind the lighting control panel. From that same bundle of wiring which wire would be negative? I assume black but I don't want to assume I want to be certain. I tried touching the ground to metal pliars and to the outside of the car but it is painted so still no luck. I dont have a meter or anything off hand so if someone could tell me which wire it is that would be great. Let me know Thanx |
| >>>Hey guys, I just got a visionwerk indiglo gauge set. I got everything up except the wiring. I can't seem to get it to turn on. I got the positive from the grey wire with red stripe from behind the lighting control panel. From that same bundle of wiring which wire would be negative? I assume black but I don't want to assume I want to be certain. I tried touching the ground to metal pliars and to the outside of the car but it is painted so still no luck. I dont have a meter or anything off hand so if someone could tell me which wire it is that would be great. Let me know Thanx<<< If you just need straight unswitched ground just get it locally via the chassis. There are all sorts of convenient bolts and so forth to use under the dash. Stan
