Old 05-11-2003, 02:56 AM
bmwmpower1's Avatar
Banned
Rides:1988 BMW 325I, 1988 BMW 325IC CONVERTIBLE
bmwmpower1 is a New Registered Member
Guys I Have No Brakes Help!! Cant Stop!
Hey Guys,
Im having a problem with my brakes I dont know if you guys will understand my situation. Well about a week ago. I have noticed that the brake pedal became loser meaning. If I tap the brake fast it holds, but when you step on the gas and let it cruise and apply the breaks softly the pedal goes all the way down and doesnt hold and sometime I cant even stop cause there is no brakes. Only if I tap two times fast it holds like new, but when I apply like in one motion the pedal seems to sink in and not hold anything. What is the problem? I check that brake fluid its ok. What can I do guys, cause i need my car to go to work and all. Anything I can look at or fix?? Please help me out.!!!
Old 05-11-2003, 05:17 AM
news@11's Avatar
Rides:330ci 2002 3series
news@11 is a New Registered Member
my brakes are skreching ...
what should i do?
change them
Old 05-11-2003, 05:28 AM
Rides:92' BMW 325 coupe, 01' BMW M3
GirtzB is a New Registered Member
I gues that there is air in the system. You should drive to service, it is work for 20 min, if they do not have to change some brake lines.
Old 05-11-2003, 05:32 AM
to news@11
Change the pads, maybe you wold have to change disks too.
Old 05-11-2003, 07:49 AM
Rides:2002 M Roadster
Iwannadinanm3 is a New Registered Member
brake's master cylinder?
BALLERWERKS
Old 05-12-2003, 07:59 PM
bmwmpower1's Avatar
Banned
Hey is there anything else that can be the cause of it. Cant I do this myself I have alot of tools. Does it have to be done at the dealer im pretty good with tools and all.
Old 05-12-2003, 08:20 PM
Rides:e36 M3 EVO
gt.c is a New Registered Member
I don't know much about this, but I think you should re-machine your rotor ... hope that helps
Old 05-12-2003, 08:24 PM
scottycs's Avatar
Custom Turbo 328
Rides:e28, e30, e36, e39
Did you recently do anything to your brakes?
-Chris
Old 05-12-2003, 10:32 PM
Banned
Rides:87' 325iS & 95' M3
ComeOnNow is a New Registered Member
There is nothing wrong with your rotors or pads. Its something wrong with the brake hydraulic system.
First off make sure your fluid level is where it should be.
Attempt to bleed the system of any air first before spending any money.
If that doesnt help, i would look at the brake master cylinder, or the power booster as the source of your problem
Old 05-12-2003, 10:43 PM
womanizer
Rides:nothing toatled old person hit me :-(
porkyzilla is a New Registered Member
please dont go driving around like that....your only looking for troubble if you do
hmm...got lots of money now i need a bimmer
Old 05-13-2003, 06:58 AM
Privatestreet's Avatar
$10 V.I.P.
Rides:'96 328is
Privatestreet is a New Registered Member
yes... i agree
and I also agree that the problem is in your hydrolic system. Bleed the brakes. Its quick and easy to do. If you dont know how to bleed your brakes im sure you can search this forum for a thread to do it.. or just do a simple google search.
So do that - get out any air that might be in there. If that doesnt work I would have a mechanic look at your Master Cylinder.
Good luck.. and seriously, dont go driving around. After you bleed your brakes, just go for a small short drive in your neighboorhood. Go slow.. just see if the brakes work.. be sure you are ready with the e-brake if you have to use it.
good luck
Old 05-13-2003, 07:01 AM
scottycs's Avatar
Custom Turbo 328
How did he get air in there is what I want to know, unless he recently changed his brakes.
-Chris
Old 05-13-2003, 10:07 AM
$10 V.I.P.
Rides:'96 328is
good question.
but it definatly sounds like something in the hydrolics. Id be willing to bet its the master cylinder.
Old 05-13-2003, 12:29 PM
bmwmpower1's Avatar
Banned
Guys thanks for the reply! I havent changed the brakes the only time I did that was last summer. Which I did myself. Well not the disc but the pads. I check the pads and they are about 50% life in them. I check the brake fluid and its full as usually. One thing I noticed aswell is. Even when the cars engine is off and I press softly at the brake pedal it still sinks in. But when I press it in one shot fast or double time it stiff and it holds. Yes I know its dangerous to drive like that. How would I bleed the system or take out that air like you guys said cause i didnt find it on yahoo search nor google? Can anyone provide me a step by step. I have the day off from work today so I have the time to do it. Thanks for the info!
Old 05-13-2003, 12:34 PM
tdc's Avatar
tdc tdc is offline
Rides:a white car
A soft brake pedal usually indicates air or a leak in the system or a bad master cylinder.
Air in the system is simple enough to fix, just bleed the brakes.
A bad master cylinder is simple as well, just replace it with a new one.
A leak in the system is going to be a problem because you have to troubleshoot the entire system and figure out where the leak is since you apparently cannot see it. If that's the case, you're better off bringing it to a professional (not necessarily a stealer).
still around
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
