| well? Is one better than the other? (1995 M3)
__________________ ![]() Pic from AKA rally 2k4 New York to Los Angeles....6 days 160mph Last edited by xjeeper : 04-28-2003 at 01:29 AM. |
| I think the size for optimal performance is no larger than 16'. I'll see if I can dig up the formula. Based on that, I'm guessing 17s would be better than 18s.
__________________ Hell Rot 95 318ti |
| depends on the weight and width.... an 18in wheel that is lighter and wider than a 17in wheel is better, 1. because it's lighter 2. because the added width provides a larger contact patch.... that being said, if you can find a 17in wheel that is light, that's pretty much your best bet... ...but you also have to put into consideration how much your tires will wiegh and their widths as well.... ...just the watered down stuff ![]()
__________________ ~Chris ![]() 2006 M Coupe #293 |
| that's not entirely true. it's about the rotational inertia of the rim. (force required to spin up a wheel). The further out the rotational mass is, the more effort is required to start the wheel spinning. Just b/c the wheel with a greater diamter is less massive, (weighs less) doesn't always account to it being easier to start spinning. Reason for this, the translational speed doesn't depend on the mass of an object.
| I say it depends on many factors. Weight, width...etc. If you can get 265s on the back and 245 in the front... then your good. I have 17x8s in the front, and 18x9s in the back. OZ Superleggeras. I love it.
__________________ Engine & Driveline: RMS Stage II+ * 8 Rib * 11psi * 42lb injectors * 993TT HFM * Port & Polished Head * 3 Angle Valve Job * EvoSport's 4 Layer 1.8mm HG * E36TD Fan Setup * Custom Headers * UUC UDPs * S54 Oil Cooler * OEM S54 Radiator * S54 Guibo * Stromung Exhaust * ACS Delete * UUC SSK * Rouge WSR * UUC TME Chasis Tuning: GC COs * UUC Sways * X-Brace * Rouge RSM * GC RTAB * Z3 Steering Rack * OZ Superleggera 18x8Fr/18x9Rr * 255/35/18 Fr, 265/35/18 Rr * Front Strut Brace Exterior: DEEP BLACK PAINT * Rolled Fenders * Custom Vented Hood * ACS Diffuser * Red DDEs * 8,000K HIDs * Smoked Markers Coming Soon: Finish ICE * RaceLogic * LSD w/ 40% * 6-sp Trans * 6 Pot 13.6 Fr, 4 Pot 12.9 Rr BBK 4 Sale: RD RGS 17x8 * M3 Rear Seats * 99 M3 Fan&Clutch, Intake Manifold, Headers * Alum Therm Housing * Dresmann Rear Kit * Sanded CF Vented Hood * Custom 18x8.5 BBS RCs * 4 Silver & 3 Grey 17x8 OZ Superleggeras * UUC St2 8.5lb Flywheel + OEM E34 M5 Clutch Kit * OEM HIDs * & More |
__________________ '95 RIEGER 3 ![]() 2.8L OBD1 and then some... |
