View Poll Results: Paint it, lower it, or leave it
Paint the side moldings 32 50.00%
Leave the side moldings 11 17.19%
Lower the car w/ coilovers 50 78.13%
Leave it, is not worth lowering 5 7.81%
Multiple Choice Poll. Voters: 64. You may not vote on this poll
Old 03-19-2003, 07:31 PM
ClintonM3's Avatar
BMW Client Advisor
Rides:2006 Z4 3.0si roadster
ClintonM3 is a New Registered Member
Paint or not, lower or not?
Are these mods worth my money? Please respond with your opinion. BTW, thanks for voting before, on my wheels, the winner - SSR GT3 in silver.
Side moldings.
Pro-paint
1. Unique
2. May look cleaner, newer
Against-paint
1. May look worse
2. May look rice
3. May chip
4. Less a few hundred bucks, could have spent else where.
Lower with Coilover. (Seems like the only choice for cabrio)
Pro-lowering
1. Looks cool
2. Handles better
3. Last longer (than stock sping and shocks)
Against- lowering
1. Cost ( at least a grand)
2. Existing stock ride height
3. Won't be able to use coilover's potential, cause I don't track my car often.
Internet Manager - BMW Mt. Kisco
Old 03-19-2003, 08:08 PM
415 Frisco
Rides:1994 540i DINAN/ 2003 ///M5
DINANFIVE is a New Registered Member
id say paint, then stonegaurd the painted areas, and lowering springs if you just want it to be lowered.
i would do something along those lines if i were in you shoes
2003 ///M5 Sterling grey/silverstone-DADS
1994 540i DINAN orient blue/tan
Old 03-19-2003, 08:14 PM
Rides:Dinan 318
BMW_DINAN is a New Registered Member
it looks great now
i wouldnt change a thing
Old 03-21-2003, 04:46 AM
Incredible-Vick's Avatar
-v- Viola
Rides:A Ford in reverse 2 times
Incredible-Vick is a New Registered Member
It looks good now, but the main thing you should do is lower it
''LOVE IT''
Old 04-08-2003, 01:21 PM
///M3Driver's Avatar
Rides:1999 Jeep Cherokee Classic
///M3Driver has achieved their Master License///M3Driver has achieved their Master License///M3Driver has achieved their Master License///M3Driver has achieved their Master License///M3Driver has achieved their Master License///M3Driver has achieved their Master License///M3Driver has achieved their Master License///M3Driver has achieved their Master License///M3Driver has achieved their Master License///M3Driver has achieved their Master License///M3Driver has achieved their Master License
Lower it. I'd get springs though.....I've had both (Eibach on a Bimmer, and Skunk2 coilovers on a Honda) and the springs had a nicer ride to them.
///Brandon ~ 1998 M3 Sold
www.nothingrandom.com
Old 04-09-2003, 08:18 PM
Rides:97 328i
matthew-m is a New Registered Member
It depends. I originally would have said lower it, but now the ride absolutely sucks after 15,000 miles! Stock parts last much longer. If you don't mind replacing components so soon go ahead and lower it. IMO the side moldings are something you sould try to see before it is done. Try modifying the photo in Paintshop or something to give you a better idea of the finished look. Good luck!
Old 04-09-2003, 08:40 PM
Rides:Dinan 318
whats wrong with your suspension?
Old 04-12-2003, 08:35 AM
CMT CMT is offline
Rides:04 Jeep Liberty
CMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master LicenseCMT has achieved their Master License
While I have come to the unfortunate crossroads of also painting my moldings, it is only because I am sick of dressing them up every three days. I honestly think that body-colored moldings looks sissy/effeminate on Estoril, which is a color that needs the black perimeter strip to break it up. I considered painting them black, which would yield the stock look, but then I go right back to the matter of "why bother painting them at all if you aren't changing anything."
But I cannot stand it when my moldings start looking like ass after the end of the three day run. I have had enough, and if it drives me to do something I would rather not do, then so be it.
As for suspension, my vote is for coilovers. You can adjust the ride height to be close to stock, and the ride on my H&Rs is amazingly factory, and quite surprisingly supple over bumps and rough pavement, while still making the car razor sharp in a corner. It is true that a spring/shock combo is less expensive, but I wanted a matched spring/shock combo on my car that you can only get with a coilover setup. My ride after 30,000+ miles has not deteriorated one bit, and I have the car on its lowest setting in front and almost all the way down in back.
This is its ride height while driving:
In my .sig, I had yet to drop it down all the way when the picture was taken:
Old 04-12-2003, 09:22 AM
Suneal's Avatar
Rides:Cooper S
Suneal is a New Registered Member
I also have mixed feelings about painted moldings; they look pretty good, but Estoril looks good without them also. If you want to spend the money on them, do it.
And get the coilovers
Old 04-12-2003, 09:04 PM
Rides:97 328i
What's wrong with my suspension?
Well I have a lowered car in an agricultural area, so the ride is very rough on uneven pavement and I feel every bump and pothole on every type of surface. It wasn't like this for the first 10k miles, but with another 15k miles the ride has deteriated greatly. I went with Eibach springs and dampers, thinking I would get the possible advantage of a matched spring/shock like a coilover, but that hasn't happened since I replaced the shock mounts.
Oh well, I do get to drive some of the best back roads in California, and they are all within 60 miles of home!
Old 04-12-2003, 11:12 PM
Rides:'95 325i
Potter is a New Registered Member
The moldings i could go either way on, they both look good, depends what you wanna go for more, the STOCK look or the nice plain look!
HOWEVER, with the suspension, COILOVERS are a MUST, just cause its such a good thing to be able to control your ride height, and depending on which coilovers you get (H&R OR BILSTEIN) they will last you as long as you need them!!
Old 04-25-2003, 08:05 AM
Rides:Buick Century 90
Yuriy is a New Registered Member
Lower it But not too much. Just about a half a Inch. no more cause then it wont look to good when racing. Dont paint leave it how it is
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622
