Originally Posted by Blackwidow The flap is just a special oil pan, serves the same purpose but a dry sump needs another oil pump and the oil is stored outside the engine. |
that is not technically correct, the flap is only there to stop oil splash in high G corners, braking etc. dry sumping an engine works by scavenging the oil from the engine, into a separate tank, the more stages of scavenging in the pump, the better, and one stage of the pump feeds oil from the tank, into the engine oil galleries at required pressure. there are 2 entirely different benefits of dry sumping an engine, 1; because oil is in a reservoir, it will never suffer from oil surge and subsequent terminal bearing failure from lack of oil and 2; IF it is a 4 stage pump, 3 scavenge, 1 pressure, and to a lesser extent 3 stage, you can gain large h.p. increase, because crankshaft is spinning in a vacuum, i.e. almost no friction. this may not sound right, but try swinging a baseball bat under water and you will soon get the picture
cheers
