Hey peeplz
For starters all 4 tires i had were cheapo brands and two different thread patterns.
Front- Euro Typhoon Rear-Roadstone
After installing my Koni sport/ Apex 40/40mm set-up hard-cornering seemed mighty fine.
I had to get change front tires some days ago cause one got punctured and they were both worn. (inner-> positive camber etc.) Now since i changed them i can feel the rear end slightly slippin during hard cornering.
Now i have Firestone's (better i would feel) up front and Roadstones in the rear. The amount of thread on all four are
I would like to know from you guys if this can be explained by simply saying that:
1. the Firestones perform better...
2. now that front and back have optimum grip, you see the result of non
50/50 weight distribution..
3. the Roadtones have a groove round the rim for curb-protection, this
makes the rears sidewalls lean more or so..
4. It's a kinda paranoia cause.. the rear had most of the traction at first
therefore you sense the cars limit at a lower speed
Hope the long ass story didn't make u loose track..
