| Help! 525i is pissing oil! Leak should be no big deal to fix I hope. The top of the oil filter housing where the bolt meets the cap. The washer was originally rubber the new kit was an aluminum crush washer. Worked fine for 1 week started to leak about 1 hour ago ONLY under pressure while engine running. Should I retorque, replace with aluminum crush washer OR replace with OEM rubber washer?
__________________ My 525i |
