View Poll Results: What will the fuel of the future be?
Electric 10 11.11%
Hydrogen 55 61.11%
Other 25 27.78%
Voters: 90. You may not vote on this poll
  #31 (permalink)
Old 05-24-2007, 01:36 AM
EEEEeeee36's Avatar
Rides:M-Technic 97 328i Black/Black
EEEEeeee36 is a New Registered Member
Originally Posted by domoarigato View Post
I think vegetable oil will be the next fuel. It can be used in high-compression engines, i.e. diesel, with some modifications and can always be extracted from varying vegetables. That would be the least expensive alternative to converting millions of existing gasoline-powered cars to diesel-type engines running on vegetable oil.
Vegetable oil is great... except that at the current production all of the vegetable-oil bio-diesel in the world it would only replace 15% of the entire worlds current diesel usage... that isn't even coming close to replacing all of the worlds gasoline cars. There just isn't enough product from the source to replace the usage of the world right now (or ever for that matter).
Jesse Mayor - cell 206 387-8008
  #32 (permalink)
Old 05-24-2007, 01:38 AM
EEEEeeee36's Avatar
Originally Posted by Kompressor View Post
Fuck hydrogen. I went to this presentation a couple years back from Ford. The guy said it would actually increase pollution most of the time if it was used today.
Yeah... all that water vapor going into the air. That would suck big time...
  #33 (permalink)
Old 05-24-2007, 01:41 AM
EEEEeeee36's Avatar
Originally Posted by BMW-Angel View Post
Pfft fuck that, I'm walkin' everywhere..... Give a hoot! Don't pollute!
Neo - where'd you hear about peaking out on oil? I know that we're eventually gonna run out of fossil fuels but I haven't heard anything about it being that fast...
I thought it was less than 70 years myself. At the current rate of consumption it was around 70 years, but with country's like China soon to outpace the US in automobile usage, those oil reserves will be depleted even faster (like 40-50 years or less).
  #34 (permalink)
Old 05-24-2007, 02:23 AM
EEEEeeee36's Avatar
Here's my take: there is no "silver bullet". It's going to be a combination of things. For smaller vehicles, it may be a combination of hybrid hydrogen. Larger vehicles it may be bio-diesel. Mid-size it may be pure hydrogen.
Bio-Diesel: almost the perfect fuel. Incredible mileage; comes from a natural renewable resource; 0% Green house gas emissions; 0% sulfur emissions; 80% less emissions of other gasses than gasoline exhaust. Cheap. Cons: Simply not enough of it! All of the bio-diesel in the world could only replace 15% of the current diesel usage.. and while that ratio could go up, it certainly could never replace all of the gasoline usage. That being said, this is my favorite argument for bio-diesel:
The Vegetarian Muscle Car | Bio-Impala | MTV
Clip 2 - bio-diesel Impala smokes a Lambo!
E85 Ethanol/E100 Ethanol: An awesome fuel source! Same benefits as bio-diesel - naturally renewable with more and more sources coming out with it all the time. Completely clean burning, and being 105 octane/115 octane allows very powerful engines to be made with it running higher compression! The problem again is the same with bio-diesel though; there are simply not enough resources making it to support the current worlds fuel needs.
Hybrid: Paired with either bio-diesel or hydrogen IC engines, these power sources get incredible economy - over 1000 miles per tank with bio-diesel! The issue is that they are expensive to produce and the batteries are extremely heavy, taking away from some of the economy. Lighter lithium ion and polymer batteries are being developed however that could lighten the load and make them more efficient. Also if the point is to not use gasoline, then an alternative IC fuel method would have to be developed.
Hydrogen: BMW has already developed a hydrogen tank that is completely air tight and can keep hydrogen in it's liquid form for direct injection. The hydrogen 7 series that they have is making over 230hp and 250ft/lb tq. It IS an 6.0 V12, so that is not all that impressive, but of course it is still in it's early phases The problem: hydrogen has almost 3x the power per weight as gasoline...that means the same 'poundage' of hydrogen is 3x as powerful as gasoline, HOWEVER hydrogen is also so much lighter than gasoline that it is 4x LESS powerful per volume in it's liquid form. SO, you would have to carry a larger volume of hydrogen in your car, and you would have to inject a larger volume of hydrogen into an IC engine to get the same power as gasoline.... BMW is currently working on a turbo charged variant that would put an IC hydrogen engine at an efficiency of 50% - a current IC NA gasoline engine only has an efficiency of 33% or so. Still, the range of travel of such vehicles is still limited due to the volume of hydrogen needed. Hydrogen also does not need "Fusion" to be harnessed; it is being done with electrolysis now using naturally harnessed electricity to separate it out. Like I mentioned earlier, in Sweden they already have solar-powered hydrogen refueling stations that are completely self sustaining and separate the hydrogen from purified water on the spot!
Hydrogen Fuel Cell: In my eyes, the most viable answer. Electric engines have a mechanical efficiency that is more than double that of any IC engine. Also, hydrogen is used in a more efficient way, causing it to not be used as fast. Aside from those arguments alone, electric engines can be as powerful or more than IC engines, and you can even have 4 small electric motors (one on each wheel hub) controlling not only power, but traction and suspension of the vehicle. Doing this also eliminates issues with driveline and so you are able to develop more creative chassis configurations. On top of that, you can pair these types of technologies with things like solar power so that they hydrogen consumption from the fuel cell is even slower. IMHO the easiest, most cost effective alternative to gasoline. Also the cleanest.
Electric only: Most of the same arguments as HFC. You would have to plug in your car at night to charge it, but it would be like having a fresh tank of 250 miles available every time you left home! The mechanical efficiency is so much higher that it would only take about $300 worth of electricity per year to power a vehicle like that...and with nuclear, wind, and water power sources creating a lot of our power grid's power the electricity is naturally renewable. In fact, there are Green Built homes now that have either a solar panel or a wind-powered turbine that generate enough power to sell power back to the grid! Imagine having a 3' tall turbine on the back of your house that provided all the electricity you needed for your home, AND your car. That would be awesome (and could be done RIGHT NOW).
Solar?: It's there. Issues are the ability to harness enough power to move an electric car with passengers and cargo. It just isn't being done right now. It could be a good add-on or supplement technology, but no one has made a solar panel that could charge as fast as a large electric motor could use it.
My vote? Electric cars, either powered by HFC or simply charged at home. They are nearly 100% mechanically efficient, have more options to re-charge, and are more powerful! They have 100% of the engine's torque available instantly! Gotta love that. Could I give up the scream of my engine for the whine of a electric motor? If it pushed my ass into the back seat I could!
  #35 (permalink)
Old 06-07-2007, 11:16 PM
White318i's Avatar
All show, no Go!
Rides:June 91 318i
White318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master License
Well said,
Electric unfortunatly still has one rather large draw back that nobody seems to want to mention.
What do we do with all the batteries when they eventually fail?
The estimated lifespan of a Prius battery pack is 100,000km (60K/miles) or 10 years. Toyota warrants them for 6 years I believe. The replacment cost is AUD$ 6500 just for parts then there is installation. Like any battery device you have to replace all batteries at the same time or the lifespan on the new ones will be greatly shortened.
Then what do we do with all of the old batteries? At the moment they are using Nickle Metal Hydride batteries and Recycling of them is still Very expensive and they are not 100% recycleable.
close to the cost of production.
Lithium ion technology is coming along relitivly quickly, these batteries are lighter smaller and will be more powerful. Eventually these will replace NMH though estimates are around the year 2010 before they will be. These are a little better for recycling.
As for throwing you back in your seat check out the TESLAR roadster!
It even has quite a dominating roar as it powers off...
http://www.teslamotors.com/
Luke.
I can't think of anything Witty or Smart to put here...
  #36 (permalink)
Old 06-26-2007, 08:46 PM
E30stain's Avatar
Sherminator
Rides:'95 Triton turbo diesel
right now its s tie between ethanol and electric... i reckon while batteries are gettin better and better ethanol will be used until they are cheaper... oh and theres huge amounts of evidence that says we contribute so minimally to global warming that it should be considered a natural phenomenon... when i hear the i think, sounds good, why the fuck did we have an ice-age? im gonna enjoy petrol while i can but otherwise i like electric cars :P ive seen videos of setups that were cheaper than modding an engine to get same power and jus rippin huge burnouts up the street starting at 0rpm... no clutch no gears, not much out of the whole car that can really break down and cause much trouble.
  #37 (permalink)
Old 03-26-2008, 10:02 AM
///M
Rides:e46 323i 99', e30 325 eta 87'
e36mmm has achieved their Master Licensee36mmm has achieved their Master Licensee36mmm has achieved their Master Licensee36mmm has achieved their Master Licensee36mmm has achieved their Master Licensee36mmm has achieved their Master Licensee36mmm has achieved their Master Licensee36mmm has achieved their Master Licensee36mmm has achieved their Master License
as long as the cars sound the same and power loss doesnt occur, lolss ill be more than happy
-= Burn all the letters, grow hatred against the ///M =-
  #38 (permalink)
Old 03-27-2008, 03:24 AM
Rides:98 328i & e46 M3
CraigMakDaddy is a New Registered Member
I see the future being with Hydrogen powered cars. They will soon be able to put out serious power, possibly having better horse power and torque than current gasoline cars. The technological hurdle we need to overcome is how to produce hydrogen efficiently. At the moment, it takes more power to create the hydrogen fuel than we actually get out of the fuel to make a vehicle move. It also costs a huge amount of money to create the hydrogen fuel compared to refining gasoline. Once we figure that out, it shouldn't be a problem at all. Hydrogen powered cars would actually be able to suppliment electricity into the power grid and operate as portable generators when the power goes out. Thus making hydrogen cars a double whammy of benefits. Zero emmisions AND extre electricity production. This all hinges on scientists finding a cheap, efficient means of producing hydrogen though. It may even be possible to put the hydrogen generating unit on the car making fuel stations a thing of the past. It would literally transform the automobile into something completely different than it is now. Electric cars will do nothing but simply sap power from our already stressed power grids. Emmissions are simply shifted from the tail pipe to a power plant. They arn't actually reduced when using a full electric vehicle.
  #39 (permalink)
Old 03-27-2008, 03:36 AM
Some things to know about gasoline. There is a known oil source in the ocean around the gulf of Mexico near florida that has more oil in it than all of Saudi Arabia. It only requires advanced under sea drilling technology which we currently have. A US company is currently getting ready to spend $4 Billion Dollars to set up drilling there. Once complete the USA would become the new source of oil and oil supply would literally double with two major sources instead of just one.
The USA is already the worlds largest source of coal which can also easily be converted into oil if we ever need to do so.
There is stuff in Colorado called oil shell. It is a solid rock with oil trapped within it. There is enough of this rock like substance in one mine in colorado alone to equal all of saudi arabias oil.
The lesson learned today is that there are many other HUGE sources of oil on this planet. They just happend to be a little bit more expensive to exploit than oil that can be pumped out of the ground. If these are utilized we will have enough oil for the next several hundred years at current cunsumption levels. And cunsumption will probably go down as technology advances.
  #40 (permalink)
Old 03-27-2008, 06:24 PM
fairweatherpunk's Avatar
Rides:E36 325
Hydrogen and fuell cells may be the future. The biggest problem right now is that hydrogen is extremely volatile and unstable. Even more so than gasoline. I'd say in the next ten years fossil fuels will going the way of the carburetor. If combustion engines are still going to be around there are many different replenishable ways to make ethanol fuel. One guy even made ethanol out of beat juice. It wasn't cost effective but like the brazillian guy said, you can make it out of sugar cane, and the U.S. is looking to make it out of switch grass instead of corn. A possible source for combustion engines.
  #41 (permalink)
Old 04-20-2008, 01:01 AM
Highboosted's Avatar
Road Race or Die
Rides:SPEED DENSITY!!!
Region: USA - Great Plains
Diesel. Bio-diesel more specifically. ULSD sucks ass.
Join NASA, too!!!!!
  #42 (permalink)
Old 01-21-2009, 12:22 PM
kormane30's Avatar
Rides:325e
kormane30 is a New Registered Member
eletric motors produce more torque tesla all the way.
  #43 (permalink)
Old 06-28-2009, 02:31 PM
Rides:89 325I
rvaughnp is a New Registered Member
magnets.
  #44 (permalink)
Old 06-29-2009, 10:27 AM
Rides:ferarri
AnxiouslyWovenC is a New Registered Member
interesting and great topic. i chose hydrogen
  #45 (permalink)
Old 07-02-2009, 01:26 AM
Rides:1998 Ford
adam156 is a New Registered Member
Appriciation
The things mentioned are unanimous and needs to be appreciated by everyone. The above thought is smart and doesn’t require any further addition. It’s perfect thought from my side.
Adam
uv air purifier
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
