| The install of the DDE basic kit into the Inpros is simple if you can take your lights apart and solder and/or use quick taps. The rings are the same shape as the indentation in the plastic in the light, and you just use some silicone glue to tack them down in a few spots. After that, just tap them into the daytime light wire inside the light and you are good to go. I do not have any night time pics yet, give me 2 weeks since I'll be home from school. The reason they look blue in my sig is because that is an old pic with the LED modification.
