Old 11-23-2003, 12:40 PM
Rides:e30
emi323i is a New Registered Member
a quick problem in physics: estimate the temperature of a rotor ...
3500 lbs car is moving at 80mph. estimate/calculate the temperature of the front rotors after comming to a complete stop.
assumptions:
ignore the amount of heat dissipated into air during braking
ignore the amount of heat absorbed by the brake pad
the rotor is a 12.6" brembo rotor. info i found on the net it weighs 15.9lbs.
By asuming that 80% of the braking is done by the front wheel (therefor 40%/front rotor) i came to an increase in temperature of 126 degrees K (or C).
Can someone double check my answer...
here it is broken down:
Ek = m * v^2 /2 = [1590 kg*(128 km/h)^2 ] /2 = ... =1005 KJ
1005Kj * 40% = 401KJ (Energy distributed on one front rotor)
Specific heat of steel is .44 J/g*K
mass of rotor: 15.9lbs = 7200 g
change in temperature = (401*10^3)/(.44 * 7200) = 126 Kelvin
thanks
Old 11-23-2003, 02:52 PM
Zor Zor is offline
Interboro Specialist
Rides:95 civic Group N, 99 Subaru Impreza Rally Car
Zor is a New Registered Member
..er...why not just drive and test to see how hot they get with one of those laser heat guns
Old 11-23-2003, 03:06 PM
Rides:1997 m3 4DR
Bretts02 is a New Registered Member
the amount of heat lost to the air is not neglidgeble at all. The e36 specificly has brake cooling ducts in order to cool the rotors, your math is correct but it will clearly be less than that becuase the air is moving across the rotors quite fast
Old 11-23-2003, 07:56 PM
Rides:e30
i can drive it, but i don't have the cool laser temp gauge. and yes, the heat lost in air is not neglidgeable, of course, but this was theoretical... and surely the actual change in temperature would be significantly reduced... the important thing of this was the upper bound... the temperature would increase by a maximum of 126 degrees. all other aspects i chose to ignore would simply decrease this amount...
tomorrow, i'm gonna call brembo and tell them to screw off and send me two new rotors, cause there's no way in hell I warped those rotors by doing ocassional highway, 70-80mph stops.
thanks a lot guys.
Old 11-23-2003, 08:03 PM
Rides:99 M3, 600rr
Nitrous115 is a New Registered Member
Maybe you warped them by having your foot on the brakes while at a stop sigh/light after heating them up. If you do that then the part of the rotor where the pad is touching would cool faster then the rest of the rotor. Which could warp them.
Old 11-23-2003, 10:02 PM
werd
Rides:a car
czm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master Licenseczm3 has achieved their Master License
I used my laser senser on the rotor of my e46 after a track session. 662 deg. f.
2007 GT3
2007 530XiT
2008 Titan
Old 11-24-2003, 09:53 AM
Rides:e30
looks like i'm gonna have to swallow the cost... i talked to both brembo and race tech, the distributor, and they don't have any warranty on warped rotors ... $209/piece. it sucks... but i guess that's the price we have to pay for having the best technology. Since i'm unemployed, and the bmw is gonna be garaged for the winter, i'm gonna delay this expense 'till spring. perhaps even later... this sux really bad.
Old 11-24-2003, 10:04 AM
Alex Mc's Avatar
NC Rep.
Rides:E30 Evo Schwiiing
Its a buttload more than a 126 Celcius increase.. more like 500+
Old 11-24-2003, 10:10 AM
Rides:e30
are you sure? how did you estimate that?
Old 11-24-2003, 05:04 PM
Rides:VW/BMW
LITEWAITM3 is a New Registered Member
This is NOT a physics problem, its a dynamics and thermodynamic problem. To properly calculate the temperature you have to determine WHERE you are taking the temperature at, since the gradient will be different across the rotor. Air is a big factor!!! To CORRECTLY calculate this, and have thw calculations relate to the real temps if you took a probe to it, it would take about 2 pages of work.
Old 11-25-2003, 10:28 AM
Rides:e30
of course it would take pages to accurately calculate it.. all i wanted was a simple estimate. kinetic energy turns into heat. very simple concept.... sure there's rotational energy in the wheels and all the rotating parts, and etc. i wasn't trying to overdo it... like you said, i could just simple get a laser temp sensor, and get it over with.
Old 11-25-2003, 01:55 PM
SirTony76's Avatar
Mob Boss
Rides:Trek 4300
SirTony76 is a New Registered Member
Well your calculations are wrong b/c the dimensions of energy you used are wrong...you need an acceleration dimenstion...and another distance dimension. The dimension of the length it took to stop, and the time it took you to stop. Then you can calculate that.
I am not sure I understood your work either, I think the better way to do it would be to calculate the energy that was lost while braking, then set that to the specific heat of the brakes. Then use the factors you need to arrive at the appropriate dimension.
"If you've crashed a sports car worth $300,000 while getting blown by a Playmate, you've just about done everything...." ~Nikki Sixx
« Best? | Sema M3. »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
