| Sounds like you have a parasitic draw somewhere. Do you have any aftermarket electronics on the car? If so, I'd grab my multimeter and check all the wiring and make sure everything is connected properly. Also, I don't know why you changed your alternator when it was charging at 12.33V. That's what your battery is supposed to be charged at. Under load it will drop down to 11V.
__________________ still around |
| well I was told and remember from old cars that it should be at 13.5 or better. and underload it shouldn't drop below 12. As far as a system nothing on the car. While i'm driving the battery dies I don't have anything on just the car is runing and it seems as the alternator doesn't charge the battery..
| Parasitic draw is when the car is off. Where did you measure the output voltage at the battery or at the alternator? If output is fine from the alternator and low on the battery then you have some resistace in the line so there is a voltage drop going to the battaery! So double check! Also check if the belt is slipping! |
