Old 10-08-2003, 05:46 PM
Poke2120's Avatar
0wned you!
Rides:1994 325i
Poke2120 is a New Registered Member
New Contours and Tires = Horrible steering wheel shake! HELP
This problem has been long solved 5 months ago. No more problems, got new wheels...
Poke
Old 10-08-2003, 06:04 PM
Eric's Avatar
4 banger
Rides:87M3,
Eric is a New Registered Member
have the tires static and dynamic balanced. any good wheel shop should be able to do this for you.
Karl Kraus --Education is a crutch with which the foolish attack the wise to
prove that they are not idiots.
tdc's Avatar
tdc tdc is offline
Rides:a white car
Wheel balance?
Loose lugbolts?
still around
Old 10-08-2003, 06:05 PM
Bimmer RaVer's Avatar
Digita1 Ecstasy
Rides:E34
Bimmer RaVer is a New Registered Member
yeah balance them, you can actually do this at a high school shop if you have one, its as simple as adding little .75oz wieghts
Old 10-08-2003, 07:19 PM
Poke2120's Avatar
0wned you!
Rides:1994 325i
The wheels already have been balanced. They were balanced this afternoon (before I put them on) by the tire shop I go to. I trust them to do a good job, they have never let me down before, and knew exactly what I wanted.
So yes they have been balanced. Any other thoughts? The wheels looked in perfect shape when I got them, I couldn't see any bends whatsoever with my naked eye. Is it possible they could still be bent but undectable to me? These are used rims, only 10k miles, but they looked perfect to me before they were mounted.
Poke
Old 10-08-2003, 07:30 PM
tdc's Avatar
tdc tdc is offline
Rides:a white car
Weights can fall off. And did you check your lugbolts? Sometimes if the wheel isn't centered properly it can feel like the bolts are tight when they're really not.
still around
Old 10-08-2003, 07:33 PM
Poke2120's Avatar
0wned you!
Rides:1994 325i
All the weights were there when I bolted on the wheels at 5:00 today. So unless is somehow knocked them off during the bolt on, and didn't see them on the ground, they are all there.
The lugbolts can't be loose, I torque wrenched all of the wheels down with 100ft lb of torque. And I double checked each wheel as well, just to be safe.
Poke
Old 10-08-2003, 08:21 PM
SG_M3's Avatar
Rides:#56 IP M3
ouch a 100ft lbs, watch out not to shear them.
Sean
Old 10-09-2003, 03:45 AM
Poke2120's Avatar
0wned you!
Rides:1994 325i
The lug nuts are fine My dad always uses 100ft lb and recommeneded that I do so as well.
Well I am going to drive the car now, I have to. Hopefully nothing bad happens.
But has anyone else with had a problem like this with aftermarket wheels on a E36 325i w/ stock suspension?
Poke
Old 10-09-2003, 05:46 AM
Matthew C Smith's Avatar
Rides:hellrot machine
Well, I say 100 ft-lb is too much. Things have torque specs for a reason....
Try 75 ft-lb next time.
If the wheels are balanced and nothing else has changed and the problem did not exist before, you've probably got a bent wheel.
Old 10-09-2003, 06:44 AM
I drive a beater....
Rides:A sleeper....
Does this occur (steering wheel shake) when you ALSO apply the brakes or only under acceleration??
100 ft*lbs is to much. Max I would go is 82-85 ft*lbs.
Like people said, you could have a bent rim. Are you sure the tires are on the rims correctly??
Can you have someone look at them while you are moving slowly.
Old 10-09-2003, 07:07 AM
///Samson's Avatar
Rides:M3less .. ..
///Samson has achieved their Master License///Samson has achieved their Master License///Samson has achieved their Master License///Samson has achieved their Master License///Samson has achieved their Master License///Samson has achieved their Master License///Samson has achieved their Master License///Samson has achieved their Master License///Samson has achieved their Master License///Samson has achieved their Master License///Samson has achieved their Master License
I agree with Matthew - * who knows a lot of good tech info.
You really should tighten them by hand.
~Check the rims for bends
~hopefully you didn't bang your caliper/s - causing them to be tight on your rotor/s.....
~* Check the psi -- make sure it isn't too high or too low.
^SOLD^
5000k HID Startup Clip + DEPOs
Old 10-09-2003, 08:35 AM
BadNewsTravelsFast
Rides:1990 325is
ben325is is a New Registered Member
Switch out the front and rear wheels, swap in your spare, etc. Figure out which wheel is bent. I had a bent wheel, felt like the whole car was going to rattle apart at anything above 55.
Old 10-09-2003, 03:28 PM
Poke2120's Avatar
0wned you!
Rides:1994 325i
Well guys I took the car, with all 4 rims on, to the tire shop my family has used for over 20 years. The owner personally spent an hour of his time, taking off each wheel and putting it under the machine that spins them to test for warps or bends. He said he found nothing. He swapped them all around too. Took the car out for 3 different test drives after each step. I saw him get out of the car, after the 3rd test drive, and he said to me "jesus, that thing will rattle your teeth out."
He told me he had never seen a car react to wheels like that before, after them being properly rotated, mounted, and balanced. His only guess was the offset was completely off. Now, I am VERY confused, since the previous owner of these wheels had them on a 93 325i with stock setup, exactly like mine. How could the offset be different on my stock 94 325i?
I have taken the Contours off and put the stock rims back on, until I can figure out what the hell to do.
Poke
Old 10-09-2003, 04:15 PM
Are they replica kontours?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
