| Yes! In my case it was my differential carrier bolt backing out. Three times so far. Have someone get it up on a lift ASAP and check it, before, like mine, it potentially shears through the differential casing resulting in the need for a helical weld. ![]() Does it do it when you go from accel-to-decel AND decel-to-accel ?? |
__________________ BLITZ |
__________________ ![]() JL 4lb pulley, airbox mod, K&N panel filter, JDM chip, NGK TR6's, OEM soft tonneau cover, 3.73 gears, 90mm mass air, aluminum driveshaft FOR SALE: dual 12" Fosgate subs, 600 watt Fosgate amp, and sub box - $250 shipped for everything email or message me for details |
| c.k. = check. just make sure all 3 of the bolts are there and that they are all tight.
| I better check mine! its been doing that for a while I changed my RSM and they still clunk. Did yours clucnk in decel/accel or accell/decell? I think mine might do it for both, but im positive it does it from decel/acell. When Im in 1st and let off a little and get back on I hear it creaking, but when I turn corners at slower speeds I hear clunking. Is that similar to waht you were experiencing? |
__________________ ![]() 97 BYZANZ M3 LUX |
