Old 10-02-2003, 07:44 PM
Rides:BMW 328i
daa328 is a New Registered Member
328 Questions
I recently purchased a 98' black/black 328i (4 door) with sport package. My questions about "sport mode": Can you shift between all the gears (1,2,3,D) or just 3rd and drive?, When at a stoplight do you shift to first or stay in current gear? When launching what is the best gear to start in? I am trying to decide what mods I want to do, and so far I think I might get a JC chip, intake, possibly exhaust. Sorry for the list of newbie questions but i'm just curious. I'll post pics soon-
-Dan
98' 328
Old 10-02-2003, 08:02 PM
Rides:BMW 328i
So far I found bavauto.com a good starting point for a few things. I am new to BMW (Used to drive Land Rover) and I realize the 328 isn't a racecar especially when auto and stock. I am basically asking if anyone can give me some worthwhile mods that are within reasonable price. For instance will an CAI really make a difference more than a few horses over just a k&n filter? I was looking for an e36 m3 exhaust until i discovered that it's heavier than stock, so I am looking for a replacement muffler with maybe a better sound to it. Once again, thanks for the help and I realize I won't see significant gains without going forced induction.
-Dan
98' 328
Old 10-03-2003, 05:45 PM
MOVE OVER ** **
Rides:328i
stevewashington is a New Registered Member
Try suspension mods
It is easier and cheaper to make a 328 handle like a M3 than it is to make it run like a M3 in a straight line. The K&N or CAI only add a few HP but they sound GREAT. Same with the exhaust. The biggest improvements I have found are with suspension upgrades. Shocks & Springs, Sway bars & lower control arm Bushings. X-brace, Front & rear Strut tower braces. I usually run top 15 at my local auto cross. With many Corvettes & Porches behind me. But in a straight line I would be lucky if I could keep up with a Maxima or v6 Accord. If you want to go fast in a straight line you need to spend about 8k on a Turbo kit or start with a M3. I am thinking about getting an M3. Have fun.
Steve
96 328i SCCA STS
88 MR2 SC GRM $2003
Old 10-03-2003, 09:27 PM
Baby M3's Avatar
Ba Dawg
Rides:Cha Ching!
Baby M3 is a New Registered Member
Re: 328 Questions
Congratulations on your purchase!
You may shift from 1,2,3 and D on your auto tranny but I am almost positive that you will achieve the best result by stepping on your brake until your RPM hits 3 grand, and just floor the car in third gear. I would not recommend doing this often as this launching method puts a lot of wears and tears on your tranny.
I usually drive around in 3rd gear and I think it feels better than manually shifting my auto tranny and it's more responsive under most circumstances.
Chip is NOT available on E36 3 series BMWs produced in 1996+ years. Due to the more advanced OBDII design, you'll have to upgrade your ECU by buying software upgrades from either J. Conforti (it's called the Shark Injector) or Dinan. The software upgrade costs about $300 or so.
The most common, performance oriented intakes I've seen nowadays are either:
1. J. Conforti (expensive though. $400+ new),
2. Dinan (almost as expensive as the J.Conforti one but it utilizes a carbon fiber tube and looks nice. The only problem is that it extends down to the bottom of the engine and many have worried about the possibility of the intake's sucking in water when it's raining, which would cause great damage to your engine).
3. Active Autowerke
4. ECIS (Very similar to the AA intake but it does not cost as much. In my personal opinion the ECIS is your best bang for the buck for which intakes will hardly give you any hp anyway).
Exhaust wise, the ones that received the most amount of hypes are:
1. Active Autowerke exhaust (known to produce that Ferrai sound in E36 3 series).
2. UUC exhaust
3. Rogue Engineering exhaust
4. Tri Flo exhaust (known for being loud)
5. RMS exhaust (also known as Fox exhaust in Europe. This is what I currently have on my car and it's very loud. Prob. even louder than Tri Flo's Loud Version exhaust).
If you have more questions, you can try the search function and I am pretty sure you'll come up with a lot more than you can imagine.
Good luck.
Jon
Old 10-05-2003, 08:04 PM
Rides:BMW 328i
Hey thanks for the responses- I was a little unsure about the sport mode but I think I have it now. As far as mods, I only had an m3 suspension put in when I got into a minor front end accident. For now I might just put a k&n panel in and start looking for exhaust pretty soon. Hopefully I can take a few pics when I get my smoked corners and indicators in from bavauto.
-Dan
98' 328
Old 10-05-2003, 09:50 PM
xicethugx's Avatar
SeDaNs RoCk
Rides:98 328i, 97 m3
xicethugx is a New Registered Member
thanks guys i needed to know also
silver 98 328i
cosmos 97 m3
Old 10-07-2003, 08:49 PM
Rides:BMW 328i
Right now i'm at 57k miles and I have my next service date coming up at 60k. What does this service include, and is there anything relatively simple I can do or check myself? Also, how much will this service cost at a dealer?
-Dan
98' 328
Old 10-08-2003, 11:44 AM
Rides:Bmw 328i 1997
SinCity328 is a New Registered Member
Question
The service is expensive, but you must do it. My service wasn't done at 60k, i bought the car at 70k and found out when my automatic tranny fell apart at 80k, luckily i had a warranty!
As for the Engine, the 328 makes about 18-25HP less to the wheels then the m3 of the same year, many people pretend their a ton faster but i go to the track every 2 weeks and my 328 w/Dinan intake is within .3-.6 seconds of every e36m3, it has alot to do with the drivers but even on the steet the 2 different m3's i raced couldn't get more than 2-2.5 cars on me by 90.
Check out
www.eurospeedperformance.com/Products/intake.htm
I have talked to alot of people and the Older style intake manifold can produce alot of topend with the right mods.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734
