Old 09-22-2003, 09:34 PM
Rides:96 328is
Blitz is a New Registered Member
Exclamation Wtf Is Wrong With My Car!!!!!! Please Help Guys, Asap!!!!
I just bought a 96 328is. When I was done fooling around in the car, I went to close the driver's side window and it would only roll up less than half-way. After pulling and pushing the window, I finally gave up and slammed the door. Then I hear some part in the door either dislocate or break or something, and suddenly the window works! The window was kind of crooked and did not go under the weather stripping, which was just replaced and is still not softened up. To top it off, this morning, the passenger side window is starting to have problems rolling up as well. I press the up button and it goes up a little, then stops and rolls down a little. I have to repeatedly press the button over and over little by little to get the window to close. This problem also exists on my driver's side window too. So now I got both windows with electrical problems and the driver side widnow may possibly need a new motor. TO TOP IT OFF, MY F*CKIN SUNROOF DOES NOT COMPLETELY CLOSE!!! The sunroof opens very little and does not completely close. Also, the part of the sunroof that can be moved by hand, that sliding part, is possibly stuck inside the sunroof, in the area where the sunroof rolls back to. SOMEBODY PLEASE HELP!!! IM SUPPOSED TO BE ENJOYING THE FIRST DAYS WITH MY CAR, NOT LOATHING THEM
BLITZ
Old 09-22-2003, 10:39 PM
Scorp965's Avatar
Despises PA
Rides:red turbo nsx, yellow s4 avant
Scorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master License
Sounds like you may need to acquire a new 'flux capacitor'...
Old 09-22-2003, 11:41 PM
Rides:325i m3 convo
DeMon3 is a New Registered Member
haha funny,,, arnold
Old 09-23-2003, 05:32 AM
hightcn's Avatar
Blounce
Rides:1993 325i; 1997 740il; 240Z
hightcn is a New Registered Memberhightcn is a New Registered Memberhightcn is a New Registered Memberhightcn is a New Registered Memberhightcn is a New Registered Memberhightcn is a New Registered Memberhightcn is a New Registered Memberhightcn is a New Registered Member
i had similar problems in my 89 325i with the window problems you speak of......never got around to fixin them though(accident put my baby down).......might try fixing the things......ya know that make the windows go down....buttons thats it....the underneath part....i have problems describing things....
Old 09-23-2003, 07:53 AM
L8APX's Avatar
But it's just a 4 :)
Rides:REAL M3
Try lubing the sunroof rails, it is common with sunroofs to close slowly or get stuck when the rails, cables get dry. Use spray on grease or Teflon lube. I had this problem with my Benz and my BMW and lubing the rails and cables helped alot! If it is stuck, you may be able to manually overide the motor with a screwdriver through a service port that should be by the overhead lights and sunroof switch.
As for the windows, I don't know. Maybe you should post to the E36 section for those answers.
The only thing I experienced is that the window switches on the center console sometimes crap out. They are reasonably cheap $20-$30. Buy one and put one in and see if it helps. I know my E30 benefited from new window switches.
Hope this helps,
E30 M3, the only real M3
Old 09-23-2003, 10:50 AM
POTHOLE DODGER
Rides:03-330I STERLING GREY CUSTOM ORDER COLOR
TG328TG is a New Registered Member
I HAVE SENT YOU MAIL TO RESLOVE YOUR PROBLEM
"you want it i'll get it"
TGILLESPIE@JMKBMWSAAB.COM
http://members.aol.com/_ht_a/tg328tg...mtbrand=AOL_US
http://www.jmkbmw.com/body_shop.htm
Old 09-23-2003, 10:53 AM
POTHOLE DODGER
OK, HERES THE DEAL....THE WINDOWS HAVE TO BE RE-INITALIZED. ROLL THE WINDOW ALL THE WAY UP, HOLD THE BUTTON DOWN UNTIL IT REACED BOTTOM AND THEN HOLD IT DOWN UNTIL IT REACHED UP. DO THIS 2 TIMES AND IT SHOULD RESOLVE YOUR ISSUE....AS FOR THE SUNROOF, IT IS ALSO A COMMMON PREOBLEM. YOU CAN TRY THE SAME REMEDY. SOMETIMES IT HAS TO BE DONE AT THE DEALER THOUGH UNFORTUNATELY. IF YOU NEED ME
Old 09-23-2003, 12:53 PM
UNDERCONSTRUCTION
Rides:96 TTsuprabeemer
red|ine is a New Registered Member
HMM.... i had the same problem... when i went to my friends shop to get it fix.. i found out it was the regulater.. its the tin metal piece that retracts up and down... its either bent or very weak.... its about 80 bucks each side.. aint that bad... once you get that fix make sure you lube the sides.... often for a while until your window starts rolling up and down smooth again.... when you lube it dont use wd40.. that will just make your rubber piece on the side expand.. and cause more problem... use armor all or some sort of oil
UnderConstruction...
Pocket bike for sale... Pm me for price
47cc 4.2 air cooled pull start bikes!
Old 09-23-2003, 03:33 PM
Rides:96 328is
UPDATE
The driver's side window is now completely broken, it wont roll up or down, I hear the motor working, but the window doesn't move. The passenger window works ok, it sometimes stops going up when the button is pressed, but it does it seldom and other then that it works fine. The sunroof is still f*cked up, theres no way in hell i can fix that one. My first week with my BMW is now officially a nightmare. I can only park the car in my dads garage, which means his 740 has to chill outside on the street. And when I park my car somewhere, Im shitting bricks as to whether or not someone is climbing in the car from the driver's side window. What a nightmare........
BLITZ
Old 09-23-2003, 04:35 PM
Mountain Junkie
Rides:1997 318ti
msportti is a New Registered Member
i had the same problem in my 97 ti. most likely one of your tracks that the window sits in when the scissor arm puts the window up has dislocated from the ball/socket joint. you'll need to pull your door panel nad fiddle around in there to make it work. i found an extra window mechanism form when my car was wrecked in my garage and used that. check your connections for your wires, antiseize or white lithium the track, and check the bolts that hold the mechanism to the door. also, be sure the window is in its velevet-lined rubber track on the front and rear of the door. watch your hands in there as it is easy to pinch them while messing around with the controls.
1997 318ti
17X8 Mille Miglia Sports w/ worn out Kumhos
BMPD urethane swaybar bushings
K&N filter element
Black Flowmaster muffler w/ BMPD tip
1984 E30 350i
400hp 5.0 mustang engine + 2400lb 318i + M3 and 325 suspension = 1 nasty little Bimmer
Old 09-23-2003, 04:37 PM
Mountain Junkie
Rides:1997 318ti
also check to see that the weather-stripping that was just replaced was installed correctly, mine was installed upside down and i determined that was what started throwing the whole mechanism out of line.
1997 318ti
K&N filter element
1984 E30 350i
Old 09-23-2003, 08:23 PM
Rides:328is
onthefacial is a New Registered Member
I have the same problem with my 98' 328. When I press the button for my driver's side window to go up, it will go up a quarter of the way and then go back down a little. This doesn't always happen and if I hold the button down, it goes all the way up. It's fukin annoying!
It seems like there's always some little thing going wrong with my car. One thing after another! God damn it. Anyone eles experience this with their car?
Old 09-23-2003, 09:31 PM
Rides:96 328is
Thats exactly whats happening with my car. It is so f*ckin annoying. Thank God my car is gonna go in the shop by tomorrow, then I can enjoy my car this weekend. Things are starting to look up a bit......
BLITZ
Old 09-24-2003, 07:30 AM
hightcn's Avatar
Blounce
damn we all have had the same problem.....this website should have like a tech Q&A on common problems the BMW has over time, so peeps can check it out if their car is taking a turn for the worst
Old 09-24-2003, 03:36 PM
rmn rmn is offline
Rides:1996 328is
rmn is a New Registered Member
I have the same thing (window goes up about 3" then goes down about 1") with my 96 328is driver window. I have tried lubing everything and I replaced the nylon runners that were suggested but no help. If anyone figures this one out please post it.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
