| Bmw Alarm Help Does anyone here have knolege of OEM BMW alarm systems from before 98....???? i need help ---------------- E34 ![]()
| OMG i had a 1990 525i amd te alarm goes fing crazy on you doesn't it?. it the fuses take the alarm one out, need help just post i know i rewired my alarm hit the kill switch under the dash its a red button
__________________ 1999 M3 1991 318is 1987 325i vert 00 Lexus GS300 Platinum Series VW Passat 1.8Turbo |
this is a 95...and the remote broke so nothing wants to work...we cant lock the doors and everything is f*cked...we can drive it though... but thats gonna get fixed...i wanna know how to completly remove that god damn thing. ![]()
| the alarm, or the door lock ? if the remote for the alarm is broken, i'm not sure if the 5er had a fuse for it but just take the fuse out, it might set the alarm off all the time, not sure didn't do it on the 90, but take the fuse out, got to look up what number it is on the fuse cover lid, and pull it out, if you got a problem with the door locks, check their fuse, remeber the hole car is one big electrical unit, check fuses first then look into mechcanical error like new lock "motors" if you get lock out of the car with the keey not sure if its the same on the 95 but there is a way to manually open the lock useing the key you have to turn it a certin way i forget. if you need more help post that you do and i will try and remeber how to wire a bypass on the alarm cause i know all mine did was drain my battery so i bypassed it with some wire setup so it was never on unless i pull in a new battery of got a jump start.
