Old 09-01-2003, 09:35 PM
Rides:Nothing yet (looking)
Sanguinius is a New Registered Member
BMW repair cost questions
Yo everyone :P I've been a fan of bimmers for so very long, and for so very very much longer have not been able to afford one. I've been saving for a down payment on a new car for a while now and finally am ready to buy something new or slightly used. I want a BMW so very bad, but people have told me they're expensive to fix. How expensive are they to keep up compared to other cars? I'm probably looking at a new to 3 year old 3-series or maybe a bit older 5-series. And are there any models to look out for as far as reliability problems? This is going to be my only car and the one I use to commute, so I can't have it breakin' all de time. Any answers are appreciated greatly!
Thanks for your help
Old 09-01-2003, 09:40 PM
Rides:Doc Vtoc
ryder_23 is a New Registered Member
If its fairly new, you shouldnt have a big problem with it breaking down. Try and get something possibly still under warranty. But eventually you might run into problems, u'll prolly have cash saved up again by then :thumbsup:
Old 09-01-2003, 09:46 PM
True, unless my car payments ate it up
What have repair jobs cost you and did you have it done at a shop or did you do it yourself?
Old 09-01-2003, 11:06 PM
Premium Member
Rides:325i, 00 Lexus GS300PS, Jetta:GLS,VWPassat
Agaru_Vala is a New Registered Member
well here it is, when you buy a used BMW it might need some bring up to speed on repairs, that could get into the thousands like may 1500 depending on the shape of the car, after that if you keep it up it will keep you cash up out of the car and in your pocket, but you let it go bad again and it cost you in the end, the more you keep it up after you bring it up to speed the more you save.
I have had 3 used bimmers, went through the same thing on all of them the "bring up to speed on repairs" phase.
1999 M3
1991 318is
1987 325i vert
00 Lexus GS300 Platinum Series
VW Passat 1.8Turbo
Old 09-02-2003, 12:04 AM
What types of things went wrong on your used bimmers and how much did each cost (just ballpark)
and again any models to look out for? I know some of the pre 96 "Nikasil" engines had problems with american gasoline. Just stuff like that would be good to know.
Thanks for your info Agaru
Old 09-02-2003, 07:16 AM
Alcoholic
Rides:bmw, 323is, 98
ive had my 98 323is for almost 2 years and the only repairs ive had done to it was a new battery... changed some light bulbs... and the o2 sensors total cost like 400 bucks in 2 yrs (not including oil changes and tires but thats standard stuff with every car) and i did all the work myself it was real easy... but believe it or not the dealers around me charge 85 bucks and hour which is the average price for labor... i know the mercedes dealer charges 99... and some private shops charge 85 so thats not to bad if u need stuff fixed. You shouldnt have to many problems with a newer car
Old 09-02-2003, 07:44 AM
Scorp965's Avatar
Despises PA
Rides:red turbo nsx, black nsx
Scorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master LicenseScorp965 has achieved their Master License
Re: BMW repair cost questions
BMW's are some of the most reliable cars, provided you do not skimp on the preventative maint....
basically it goes like this:
With a dodge, toyota, etc. you drive the car until it breaks, then you take it to get repaired.
With a BMW you get the oil changed, you get it inspected, you have all the minor issues addressed, you take it into the shop when it is not broken and you keep it perfect. If you do this when it eventually does break it will only cost you about the same amount in repair as a toyota/dodge - if you do not do the routine maint then it will cost you significantly more.
Be good to your bimmer and it will be good to you...
Old 09-02-2003, 10:13 AM
Premium Member
I have had a 525i that went for 250k and still running -sold
I think the only think that happen to E36, that could cost you alot is what happen on the 525i and the 325i, 525 was a 90 and 325 was a 95, they had the plastic water pu,p arm, overheated and on the 325i the radiator blew.
But on the 325is 94, it need like hmm and oil filter, or somthing related to it, a very cheap part but killed me in labor like 600 total
cause 3 total unrelated parts had to be removed to get to this oil thing lol
they might cost you a little at first or alot depending if the last owner of the car took care of it, a good newer car will have it owners book in the lather cases, with all the mile marks inpection stamps, like the brake in period stamp, the 50,000 mile stamp
not alot of dealers do it , i think but someone told me to check on that.
you have to have the car inspected before you buy it, it may cost you 350 for a inpection, but it might save you alot later on
hoses are one big thing too, if the hoses in the car are old or trashed, it will cost you about 700-800 to get all the hoses repleaced, DO NOT replaces the hoses with non OEM hoses even 8 year old hoses will do better than brand new non oem hoses, why
cause if you feel a BMW hoses it is modeled for that place in that car and the angel and shape of that hoses and feel semi hard.
a nonOEM hose is soft like clothing and has no shape, they are ment to be fitted into a shapre and rip and tear easy., this as my first big mistake
any more questions?
over all I think the 1994 325is took about 1000 to get into top running shape, and a bit more to replace just old parts with new ones for looks and newness, but was not needed bought at 94k
the 325i took a little less with 55k on it, but need the radiator done cause it blew, but my dealer covered that, cause it happen within 30 days of the sale, I had buyer choice on it
then it was recommend to change the hoses 700
the other stuff was just tunning for about 150
the 525i we took it from 0 to 250k with some minor and one major repair, overall it was not really cared for, because I was not as educated about BMW as I'm now, but it still runs strong.
If you take care of it it takes care of you like he said, FIRST thing you do is get a per buy inpection then you spend the rest of the moeny getting it to TOP running codition , then it just keepin ghe car in good shape oil changes here and there.
don't be afraid of the repair cost just get a bimmer that was cared for if not then tell the buyer hey lower the price the car need repairs
make sure that you know what you are doing so you come off as a BMW god to the dealer or seller so that they know they can't get something buy you, just ask them straight up what needs work.
1999 M3
1991 318is
1987 325i vert
VW Passat 1.8Turbo
Old 09-02-2003, 11:17 AM
Hey thanks again Just what I was looking for.
One more thing, how often do you take your bimmer in to have it looked at?
Thanks guys!
Old 09-02-2003, 05:32 PM
Premium Member
hmmm about every 3000 miels for a oil change, my service guy ( not the dealer) only works on BMWs and he will send me a lettle remind me if I'm do for a check up lol.
at the 3000 mile oil change things are looked at for wear, but about every 5-10k miles i have it in for a tune up.
1999 M3
1991 318is
1987 325i vert
VW Passat 1.8Turbo
Old 09-03-2003, 12:00 AM
mikeyz325's Avatar
NStarBMWCCAWebmaster
Rides:'92 325i, '74 2002, '00 323Ci
mikeyz325 is a New Registered Member
I spent $10,000 on a 92 325i a few years ago. Since then I have spend nearly that much in repair costs. However, I can't believe that everyone has as bad luck with their car as me, or BMW would out of buisness.
On the bright side, there is not much left to go wrong on my car, and it will likely last a long time to come.
See list below for past repairs, add to that recent replacement parts: head gasket, water pump, theromstat, fan clutch. BMW parts ARE more expensive because usually the only place to get them (aside from routine maintence type things) is thru the dealer, and there isn't much way to make that cheap. And labor costs are a b1tch.
BUT, I plan to always own a BMW because all the extra cost is worth it in the end.
g a l l e r y w/ l o t s o f p i c s o f a l l t h e c a r s , c l i c k
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684
