Old 07-15-2003, 03:37 PM
Rides:'04 M3
kidsdoc is a New Registered Member
need advice re:drop-gotta get it right the 1st time (already done an extensive search
i posted pics a couple of weeks ago (jb 330i w/ sports suspension/m-tech/BBS RC's) re: whether or not i should drop!
the overwhelming majority obviously said i shoud;
i had recently been pretty sure about getting the "classical" time-tested combination of eibach/bilstein's or the eibach pro-system; however recently i've been thinking of pairing up the eibach pro-kit (or UUC v2 springs) w/ Koni dampers (I like the adjustability, although from searching it seems like you'd have to remove the rear shocks to adjust)
my first & most important factor is comfort (ruling out the H&R cupkit, no offense to anybody who has one) & second most is $$$, thus (almost) ruling out coilovers, which i still have in the back of my mind (however i can't justify right now paying about $300-400 more for coils as i'm 99.99% sure i would never adjust the ride height or other settings)
all opinions (except "get coilovers" for the time being) re: ride comfort, value, durabilty/longevity (shock/damper manufacterer warranty; i plan to keep the car for a long time) would be greatly appreciated (this is the first time i'm messing around w/ any car's suspension )
Old 07-15-2003, 05:22 PM
tdc's Avatar
tdc tdc is offline
Rides:a white car
If comfort is of utmost importance, just leave it alone. Nothing is going to compare to the stock suspension ride.
But if you can deal with a stiffer ride, more road feel, more jostle going over road ruts, less roll on turns, tighter cornering, and just better handling overall, the best bet for the money is getting the springs/shocks combination.
The ones you listed are a good way to go but you should also check out what Ground Control has to offer.
stockWERKZ
Old 07-15-2003, 06:53 PM
Rob ITR1035's Avatar
Beer Technician
Rides:Subaru Legacy Wagon
Rob ITR1035 is a New Registered Member
cup kits dont ride that rough, much better than race springs. Try the UUC springs alone, they're designed to give a good ride and work with the stock shocks.........
Beer Tech's Very Own Forum
Old 07-16-2003, 04:22 AM
Alan's Avatar
Rides:2000 Dinan 740i
Alan is a New Registered Member
I would say in your situation Koni adjustables over Eibachs is an excellent choice. The konis are more comfortable than bilsteins and the eibachs are decent for ride quality. I'd stay away from any track geared system (like Coilovers, Cup Kit, Ground Control) as they tend to be stiffer. Also, I hear both the Bav Auto springs and some Racing Dynamics springs are softer than Eibachs.
Note: Most of my info comes from E34s so it might not apply fully to you. Although I know Koni's would be a better choice than bilsteins.
As a side note, if ride quality is a concern for any of you older BMW Owners, don't do sway bars! They made the ride of my E34 firmer than any other suspension mod I did. (eibachs, bilsteins 750i bushings)
Old 07-16-2003, 06:01 AM
Cone Killer
Rides:99 Porsche 911 Carrera
teuton is a New Registered Member
You arguements are very valid as I went through the same logic process when I decided to change my suspension. While I would tell you to spend the extra money for the coilovers as I have used the shock adjustability and ride height over 4 times in just over a year of owning them. You will not regret the additional exspense. Especially after you discover that you spent all this money on a normal suspension and you can't drive to a certain place because your car rubs on an entrance (this can be very fustrating, especially if the entrance happens to be your office parking garage). Plus the coilovers provide the added flexability for ride quality adjustments which give you a ride very close to stock (mine ride better than a sport package 3er) and if you decide to become more serious at any driving event, it can easily handle that as well.
What I would advise is trying out the perspective suspensions and try to get a guage of whether the system is comfrotable enough and drivable enough that you will be satisfied. There are a large number of bimmer owner in the DC area that get together and meet whether it be DTM, Bimmerforums or the local chapter of BMW CCA. Most members will be glad to give you a ride and will help you out. I took rides and tested out all the combinations that I was considering: BAV auto Springs/Bilstein HD's, H&R Sport/Bilstein Sport/ and Bilstein PSS9. By the way, PSS system starts at slightly higher than the standard shock spring combinations ($899).
Oh and finally, If your looking for merely a more agressive look but no comfort degridation, perhaps you should consider the bav auto springs and bilstein HD or tourings. They will give you the look but none of the harsheness of the sport type springs.
Hope this helps,
Pete
Old 07-16-2003, 02:16 PM
Beer Technician
for the record, cup kits are a looks-oriented system, they are designed to lower a lot without a bad ride. much softer that the race springs.
Old 07-16-2003, 08:22 PM
Rides:'04 M3
thanks all
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732
