Old 07-02-2003, 01:00 AM
Rides:acura rsx type s 2002
miztahsparklez is a New Registered Member
Resistor trick? and makeshift cai?
Hi!
my friend owns a bmw 325 i e something 25 is it?
he said its a 1986-8 model.
anyhow, i was looking for some dirt cheap "mods" that he can try out on his car. i remembered reading about a resistor trick that fools the IAT sensor into thinking the engine is getting colder air.
Is this possible to do on his car? and how would i go about doing it? what wires do i tap into and what size resistor do i use?
and another thing, he also wants his car to have a little meaner tone to it. we bought him a cone filter and some tubing, however we stopped designing the intake when we ran into problems connecting it to the huge sensor thing that was stuck onto the air box. is there a way to take the sensor out? or even bypass the sensor? we ran the car without the sensor without much luck, as the car died instantly after cranking.
thanks for all the help!
Old 07-02-2003, 08:34 AM
xmdfmk7x's Avatar
Big Turbo SRT
Rides:Shiny Blue Surprise™
xmdfmk7x is a New Registered Member
Re: Resistor trick? and makeshift cai?
I've heard a lot about this at the track and such, but I don't think it really works. All the GM guys talk about it and most of them say that it doesn't show any sort of noticeable gain on their timeslips.
Do some research on the net (www.google.com) and you should be able to find some information on it.
2004 SRT-4
Big turbo, lots of fuel, Wilwoods up front, 11's all day long.
Old 07-02-2003, 02:21 PM
415 Frisco
Rides:1994 540i DINAN/ 2003 ///M5
DINANFIVE is a New Registered Member
i dont think it would work because it would think its colder when its not causing it to put more fuel in the mixture and less air. that would make it run to rich and you would lose performance. someone correct me if im wrong.
2003 ///M5 Sterling grey/silverstone-DADS
1994 540i DINAN orient blue/tan
Old 07-02-2003, 03:11 PM
Rides:bmw 325i 2003
hamannHM3 is a New Registered Member
yea, i agree with dinanfive. if you trick your engine into thinking its getting cold air when its really not your gonna f*ck up all your air fuel ratios and kill your performance while at the same time waste tons of gas with no real results. just install a CAI and put cold air into the engine instead of tricking your engine into thinking its getting cold air. but thats just my 2 cents
Old 07-02-2003, 11:37 PM
well, i was planning to install the cold air + resistor trick.
ive searched online for the info, and it just says to leach off of the IAT sensor. it is also very vague in what youreally are supposed to do.
also. how in the world do you get around that airflow sensor? one side is square, making it impossible to hook up any round tubing to it. however, taking it out of the loop disables the car completely.
ill ditch the resistor if i can just figure out how to mount the cai.
Old 07-03-2003, 01:10 AM
Rides:bmw 325i 2003
u gotta some how run that sensor into the cai try soldering it or just ghetto rig it to fit some how
Old 07-03-2003, 01:14 AM
soldering it? like making an adaptor thats flat/square on one side. soldered to a round pipe where i can put some rubber fittings with hose clamps onto?
Old 07-03-2003, 01:15 AM
Rides:bmw 325i 2003
ya sure. u might be able to find a machinist that will make the part for u. try calling around
Old 07-03-2003, 01:21 AM
im thinking just stopping by the hardware store once again.. buy a metal tube.. lightweight but strong.. and use some of the leftover sheetmetal that i had. cut a hole in it, solder pipe on. then hose clamp it to the intake tubing.
does solder stick to aluminum?
Old 07-03-2003, 01:23 AM
Rides:bmw 325i 2003
take a metal rasp or a metal file and file the aluminum so it's rough and then solder to that. polished metal is HARD to solder to make sure you do the same with the sheet metal so the solder will hold.
Old 07-03-2003, 01:25 AM
any specific kind of solder?
Old 07-03-2003, 04:53 PM
Rides:bmw 325i 2003
you want thick solder, talk to the people at the hardware store and they could probably tell you exactly what to use
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
