  #16 (permalink)
Old 01-10-2002, 08:24 AM
Rides:'97 Z3; '84 325e
Carzzi is a New Registered Member
HIOP Race Tec
Originally posted by Rich 328
I doubt a Pos. Displacement SC will see the light of day. its the holy grail of 6 cylinder BMW's. I think if it was possible it would have already been seen on the E36's; downing atlanta has a 4-cyl model, I am sure there is a reason why they didnt tap the 6 cyl market.
Hiop racetec (www.hioprace-tec.com) makes a lysholm/autorotor for the M52 single VANOS. Dunno whether they make one for the newer sixes tho'. They advertised in either Bimmer/Roundel or summin'likezat. They had an intro price of around $5-6K. Call them if it's not listed on their website.
Carzzi
'97 Z3 2.8
Sharked and Supersprinted
'84 325e
Drehkraftmeister
  #17 (permalink)
Old 01-10-2002, 10:41 AM
Rides:2000 328ci
wontonjon is a New Registered Member
figured it out...
so there are basically three types of blowers on the market
1. centrifugal blowers (everyone's heard of vortech)
2. screw-type blowers
3. positive displacement ...otherwise known as roots blower
just an fyi
...waiting patiently for blower...and money...
and btw, did any of u guys check out one of the ebay auctions...bout to end but i thought it was a pretty good deal...item:600015061
evidently...the divorce is forcing the sale of below vehicle...
http://cgi.ebay.com/ebaymotors/aw-cg...item=600015061
  #18 (permalink)
Old 01-10-2002, 09:50 PM
Rides:p-car
RichP is a New Registered Member
Re: HIOP Race Tec
Carzzi, this company has been touting this thing for years now, and I still havent seen anything become of it. When I designed my kit, I came to the conclusion that it may be nearly impossible to do a roots blower without major modifications to the car.
  #19 (permalink)
Old 01-11-2002, 07:50 AM
Rides:2000 328ci
hey rich 328,
what kinds of "major modifications" would we be talking about...and why would it take all that...if you don't mind delving into that conversation a bit...
furthermore, what type of SC are you running and would you recommend it to others??? im assuming centrifugal?
thanks
  #20 (permalink)
Old 01-11-2002, 08:09 AM
Rides:95 M3
Keith 95 M3 is a New Registered Member
Originally posted by wontonjon
figured it out...
just an fyi
Sorry, but not exactly.
1. Exhaust-driven superchargers (ever heard of turbos? )
2. Centrifugal superchargers (crank-driven turbo)
3. Positive-displacement superchargers
#3 covers Lysholm / screw-type as well as straight-rotor roots-type. Positive-displacement means that it's always in a greater than 1:1 (more than atmospheric could drive in).
And Am1r, get a clue. If positive displacement blowers were so superior, then WHY do they generate so much heat, why do they (especially roots) suffer drastic pumping losses, and why do you see so few of them? Do you know much about forced induction in general?
Maybe the boost not comming on until 3k is an advantage? (One might not *always* want to be in the boost (traffic? idling?)) And screw-type superchargers are more efficient than straight-rotor or even twisted rotor, but there is still the issue of heat. The action of compressing air, even with a 100% efficient compressor, STILL generates significant heat. ALL superchargers, regardless of drive, will be better with an intercooler.
The best method for supercharging intake air is turbocharging. PD and centrifugals both take power off the crankshaft, which is power that would have otherwise gone to the tires. If the crank-driven blower makes 150hp extra and takes 50hp to drive, then you only get 100hp to the tires, while the engine gets 150hp worth of stress (efficiency here hypothetical for discussion). Turbos get their drive energy off exhaust gasses, most of which is waste energy which would have otherwise been bled off as heat into the exhaust system. However, since the turbo is basically a restriction in the exhaust path, you do lose *some* power from that. But when others have taken the 3 methods and driven them with an external input to the engine, the turbo is shown take the least amount of overhead to compress air. The downside is the high complexity of a turbo system, and an air-to-air (or whatever) intercooler is a small price to pay for the efficiency returned.
Even positive displacement and centrifugal superchargers gain much when intercooled (aftercooler is what Vortech calls it, it's still an intercooler).
I run a centrifugal supercharger, but I *still* would advocate a turbo system over either of the other two types, given the lesser horsepower loss and what you can do with them, when going for the most amount of power. There are only a few times when I wouldn't - if you want to keep it simple, if you want to improve the overall powerband and are willing to sacrifice making alot more power up top, or if it just suits you.
What I'm curious about - isn't the compression on the E46s and ESPECIALLY the M3 (11.x:1?) far too high to run any worthwile amount of boost? I'd like to know because although I have an E36 M3, the dad unit just got an E46 330i.
-keith
1995 Hellrot M3, Dinan supercharged -- status: IN SHOP
  #21 (permalink)
Old 01-11-2002, 09:22 PM
Rides:2000 328ci
thanks for the info!
  #22 (permalink)
Old 01-12-2002, 07:00 PM
Rides:p-car
Wonton,
Ill talk E36, but it would be the same for the E46. I have only seen one installed, on an Aussie car that must have cost a fortune (a lot of custom parts).
First, a custom manifold is needed, that somehow can fit the large blower. Then the piping is an issue. The intake on the SC is on the back, which means you then have to mount the throttle body (and move it significantly) to the intake of the SC,and, if you arent already hitting the firewall, then pipe it back toward the front of the car. The brake booster then gets in the way, and perhaps the strut tower, as well as all the other things hidden under the manifold.
It may be able to be done, but I feel there is a reason why Downing Atlanta does not have one, nor did Dinan chose this route. The units are just to big overall.
I use a Vortech blower. Yes, there is little difference down low, however, the car has a very wild top end and pulls nicely. If I disconnect it, immediately you can tell the car is lacking. The power comes on seemlessly, and overall, the unit is very quiet.
  #23 (permalink)
Old 01-13-2002, 06:25 PM
Rides:2000 328ci
when does the vortech "kick in" in your 328...in that cobra that i was riding it...it started to pull hard around 3500 rpms or so and on up to redline...
and also, which company did you go with and why?
thanks
  #24 (permalink)
Old 01-13-2002, 09:17 PM
Schalldruck
Rides:M3 and M6
Samir is a New Registered Member
This is a very generalized statement and is not necessarily true...the consensus among tuners views the screwtype as just that, a screwtype. Positive is usually reserved for roots type blowers. It's the ignorant that cannot distinguish between the Lysholm design and the roots design.
The reason for distinguishing between the two is this:
-A roots type positive blower compresses the air inside the intake manifold, not the blower itself. The screwtype does the opposite and compresses most of the air inside the unit (like a centrifugal).
-The internal workings of the roots are completely different than the screwtype. While both display twin helical blades, a Lysholm screwtype's rotors are more twisted with conical tapering, making them more efficient, and are arranged in an intermeshed female/male fashion.
Uhhh...that doesn't make any sense? You lost me there. Positive displacement simply means that for every revolution of the rotors, a given "positive" amount of air is displaced into the engine.
Perhaps you're the one that needs to get a clue. Again, you are displaying your lack of knowledge about the Lysholm screwtype. The new units from IHI which are currently being used by AMG and other car makers are internally intercooled thereby eliminating any excess heat from the intake charge. This cannot be said for centrifugal/roots setups which do not include any type of heat exchange methods. In addition, the adiabatic efficiency of a screwtype is right around 80%...much higher than a roots. This can equate to roughly a 100 degree drop in intake charge temp vs. a centrifugal/roots @ 9+ psi.
Yeah...perhaps for racing purposes where boost pressures of 30PSI are needed. For low boost street applications, a screwtype can offer the same type of performance as a turbo, for less cost and maintenance.
Yawn...that's everyone's defense of the turbo. So you're saying that Saleen, AMG, etc. are all wrong?
The M54 3.0 in the 330 has a CR of 10.2:1...which is safe for about 6-9psi of intercooled boost
  #25 (permalink)
Old 01-15-2002, 10:55 AM
Rides:two four dour family sedans :)
ernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master License
Techna330,
This is Ta right? I saw an article about your crew in some import magazine a while ago, congrats
Samir,
I heard that you posted something on e46fanatics about the advantages of the lysholm blower, are you considering making a kit?
Ernie
ernie-2 dremel tool-0
richard is my hero
  #26 (permalink)
Old 01-16-2002, 11:23 AM
Rides:330ci Steptronic
Gibba is a New Registered Member
So is it worth the money or not to supercharge a 330? You people are saying that the ESS/ERT superchargers dont produce any power down low right? So if the power only comes on at 4k RPMs, what is the point? You will be near redline soon enough anyway.
So I am guessing the acceleration; 0-60 and 1/4 mile are not really improved much on a 330 with a supercharger? Anyone clarify that?
What would be a rough estimate of the 0-60 of a Step 330 with a supercharger producing 340 hp(as advertised by ESS)?
  #27 (permalink)
Old 01-16-2002, 04:01 PM
Rides:2001 BMW 330i
techna330 is a New Registered Member
ERNIE
Yes...it's meeh TA...i don't if i met u before ....but i got to say rite now is your car looks so dope with that custom exhurst....right now i'm running RMS supercharger kit on my car(330i). it's really good.....if u are interest let meeh know...caz i work for RMS. i'll hook u up.
  #28 (permalink)
Old 01-17-2002, 09:44 AM
Rides:2002 330i 5spd
K-DOG is a New Registered Member
Gibba, probably around 5.5 for step, probably 4.8-5.0 on stick.
  #29 (permalink)
Old 01-17-2002, 12:11 PM
Ta,
thanks for the compliments man! it means a lot coming from someone who is experienced in modding. I have yet to meet you but the guys all have nice things to say, so hopefully i will sometime soon. thanks for the offer regarding the supercharger, i really appreciate it. im kind of low on money right now but if i do start thinking about a supercharger you will be the first to know. thanks again!
Ernie
richard is my hero
  #30 (permalink)
Old 01-17-2002, 06:30 PM
Rides:2001 BMW 330i
ERNIE
i wonder that .....where did u get your rollbar at....it's look really nice....when i saw it in the bimmerfest picture....i do want it for my car also.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347
