Old 12-11-2001, 03:23 PM
Supercharger Detonation Aquamist
Hi,
I have a Euro version 3,2 supercharged M3. I started to spray aquamist. Metanol and water are mixed 50/50.
Is there anyone who increased boost after the aquamist installation?
How did you know you were on the rich side and there wouldn't be a problem due to lean mixture?
Best regards
MERT DASTAN
Old 12-11-2001, 03:47 PM
psk145's Avatar
Rides:Blown 332i, AMG C32
psk145 is a New Registered Member
you would just change the pulley diameter to increase boost. Ask paul e. He has the water innjection kit on his car, and he has just recently increased his boost as well.
Custom tuned by NickG
Old 12-11-2001, 05:24 PM
E36M3's Avatar
Rides:E36M3 3.3 OBD1, RMS Stg3
E36M3 is a New Registered Member
Charles,
You ever thought about doing this to our cars? drawbacks? hype? advantages?
Old 12-12-2001, 11:37 AM
psk145's Avatar
BJ:
Heard nothing but positives on the system. The only drawback i can see right now is the 1000+ price tag which I cant afford now.
and the wife
but you my friend, I say give it a try!!!
Old 12-12-2001, 11:49 AM
Rides:98 M3
fourfa is a New Registered Member
$1000+? Look at the price tags at www.aquamist.co.uk, they're a lot lower than AA. you can compare the details with AA to see what they give you.
Old 12-12-2001, 12:05 PM
Hellred's Avatar
Rides:2003 BMW M3
Hellred is a New Registered Member
The water injection principle has been around for a very long time. Apparently they used this system in WWII planes, to prevent engine detonation during flight.
The common misconception is that the alcohol has some mysterious power. The only reason it's present is to prevent freezing.
I personally called ERT about their kit, and they said that I could potentially up my boost from 6 to 7.5 psi.. No problem.
Old 12-12-2001, 12:15 PM
psk145's Avatar
Oh I know fourfa, you've told me about that before. I was just figuring what paul e had said came extra with the AA kit. Yeah, I figure its probably cheap to make my own resevoir and stuff, but for budgeting, its a safe number to use. So maybe directly from aquamist,labor, and all the other bits and pieces, a grand is still pretty close I think
Old 12-12-2001, 12:28 PM
Hellred's Avatar
Rides:2003 BMW M3
Psk,
The fellahs at ERT suggest making the kit in the Windshield Washer fluid container. This way when it runs low, you have a light that comes on, so that you never run dry, and kill the engine.
If you need to clean the windshied, you can still use the water...
Old 12-12-2001, 12:43 PM
psk145's Avatar
Originally posted by Hellred
Psk,
hey, thats an excellent idea!!! I didnt think about that! I always thought the washer fluid resevoir could only be used for the injection. Hmm, too bad I got my xmas stuff already, but my b-day is coming in february
Old 12-12-2001, 12:47 PM
Rides:98 M3
I really think it's more like $500 with parts. labor is DIY because it's very simple. about as hard as headlights maybe.
the window tank is 2.5l, which would be fine if you check it every time you get gas.
Old 12-12-2001, 12:56 PM
psk145's Avatar
which kit is it that AA sells? 1S or 2S?
self install huh? Hmm, might have to research this some more. This would get injected after the aftercooler right?
Old 12-12-2001, 01:14 PM
Rides:98 M3
I'll check later, but I thought the AA kit was the bare-bones 1S kit.
you probably would want to inject after the aftercooler, yes, to keep the vanes dry. liquid water on the air side might impede heat conduction. however it might promote better mixing too. worth an experiment, actually.
Old 12-12-2001, 01:47 PM
Rides:'98 BMW M3
I dont know what aquamist supplies with their kit but Active Autowerke sends you the pump which includes all the necessary brackes, electrical parts, and wiring in a box. Active Autowerke also makes and supplies you the hoses and all wiring and switching pre assembled so the installer doesnt have to waste a lot of time. I guess the labor involved in making the hoses, tank mounting, and wiring harness is included in the price.
I would never use the windshield washer tank as the water supply for the water injection system. The tank is way to small plus you would always have to use distilled water. If hard water was poured in, the nozzle would get plugged up. I saw an ERT SC M3 with an water injection kit which used the windshield washer tank for water injection supply. The supply line runs on top of the radiator and to the pump. Not really a nice setup to since the radiator will just heat up the water thats being supplied to the pump. I dont think I want water heated up going misting into the intake manifold.
Supercharged engines only use a stage 1 system while the turbocharged engine pushing more than 12psi use the stage 2 system which has 2 nozzles.
Old 12-12-2001, 02:01 PM
Matthew C Smith's Avatar
Rides:hellrot machine
Keep in mind that the air coming into the engine can only hold so much water. So, if it's humid outside, water injection isn't going to do much good.
Old 12-12-2001, 02:09 PM
Rides:'98 BMW M3
I dont know about that but AA has one installed on their demo car and it helped alot when outside temps. where like 90+F degrees and 100% humidity. The nozzle emits a very fine mist and by the time the mist makes it into the runners, its evaporated and air intake temps has dropped like -70F degrees give or take.
It may help only on forced induction vehicles where air intake temps can go over 200F degrees.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481
