| Need help w/ diagnosing problem. Father's car: The car is a 1995 325i w/ approx. 160,000 miles. Upon starting the engine, a very loud, repetitive squeak-like sound comes from the engine bay. I removed the accessory belt and ac belt to try to elimate the possibility of the sound coming from a pulley, roller or belt. Started the car after everything was removed and the sound is still evident. Shut the engine of within 10sec and I noticed a burnt smell. The only thing I could think of is the oil pump is bad causing no lube to the top of the engine. Any ideas? thx
__________________ 1995 M3 *Various mods |
| oil pump, could be bad, now that u say it. I'd look into that. But im not 100% sure. Lots of e36 experts out there, help this guy ![]()
__________________ BALLERWERKS |
| Ok, tommorrow we are going to drop it off at the dealers. I just wanted some insight before we took it there so we dont end up spending a lot more $$$ than need be. any other ideas?
| Similar to a loose belt or even a bad pulley. Actually, its more of a friction-like squeaking... almost like metal on metal. It sounds nasty.
