| Need to replace the whole Vanos unit , Could someone tell me how much it cost (parts+labor) to replace the Vanos unit at the Stealer?? How much is the vanos unit itself (new and used)? Where to find the cheapest? Thanks in advance!
__________________ ///M FREE |
. sh*t happens. Dinan325ic,. I can hear this loud vibrating noise and it shakes quite a bit if i kept the rpm exactly at 1500. My mechanic tried putting in the updated "piston" inside the vanos, that didn't worked. I am going to meet up with my mechanic and take a look at the vanos tomorrow. I will let you know if it is the cams that killed it. I heard that it is normal for Vanos to make noise as they age, by looking at your dyno graph, i doubt that you need to replace your vanos. Genie_Tinik thanks for your help, i will pm you if i can't find one locally.
| A rattle at exactly 1500 RPMs is the lower timing chain tensioner, not the VANOS. Have you tried replacing it yet? It's WAY cheaper than a VANOS unit too. |
By the way, my mechanic took the vanos off already, he said he will show me which part is sticking tomorrow. How can i know he is telling the truth? Is there anything that i can do to check the vanos?
| M52 - Probably no easy way to check the VANOS after it's off the car, but I bet that once it's back together with the new until you'll still have noise. VB - http://www.understeer.com/onlinestore.shtml ![]() |
| the book states like 6hrs for the vanos. i still have a tick in my engine, even after i switched the vanos, and lower timing chain tensioner, and checked for the sparks plugs tightness. next on the list is lifters since my mechainc screwed me when he replaced the old vcg and had a lot of oil drain out the back of the motor. ![]()
__________________ 93 lag grn: ///M3 cams *jc cam & lwfw chip *UUC stage II lwfw and udp's *bosal exhaust *ecis intake *fan delete * billetwerks *///M3 mirrors *///M3 shift lever *///M moldings & rear spoiler*17" BBS RX & 18" zenetti milano *jbl/mtx sub system *clear corners *h&r and bilstein sport suspension Last edited by jesd325is : 12-04-2002 at 07:14 PM. |
