Old 10-09-2002, 08:41 AM
I drive a beater....
Rides:A sleeper....
need help from those w/turbo timers...
I was wondering what aftermarket alarm system are you using with your vehicle, and how are you using it considering the turbo timer keeps the car on for "x" amount of seconds/minutes?
I would like something with:
1) starter kill
2) motion sensors (e.g., if the car is towed)
3) dual-stage motion/shock sensors (for the exterior and interior of the vehicle)
4) something that will rollup my windows AND close my sunroof
I don't want the system arming AFTER the turbo timer turns off b/c there is that period where the car is running without protection. I would want something that I can actively arm -- rather than a passive arming system.
For instance, say I am at a grocery store, I am not going to stand there and wait for the turbo timer to go off for me to arm the system, I would like to get out, close the door and arm the system, that way, if someone jumps into the car and attempts to drive it while the car is still on ... the alarm will go off
TIA
Old 10-09-2002, 12:02 PM
Rides:'98 BMW M3
James,
Dont forget that when your key is removed the steering wheel is locked! It would take a theif about 20mins or more to rip or completely destroy the steering lock housing (try making that not obvious). Plus when the timer goes off he has no way to start the vehicle. You can also wire the turbo timer to your e-brake so that if the e-brake is ever placed down, the engine shuts off.
I dont have an alarm on my M3 but I know some people with factory alarms have to wait till the engine shuts down to arm the vehicle.
Old 10-09-2002, 01:53 PM
Rides:2001 Z3 3.0i
hellrotZcoupe is a New Registered Member
Aight dont hold me to this. but here is what i know.
On my turbo integra i had a greddy turbo timer and it had an e brake kill switch, basically it was wired into the ebrake and when u release it the car would shut off even if the timer was running. This kept the car from being driven because the timer was on with the ebrake up, therefor to drive it u have to lower the ebrake thus shutting the car off, i dont know how all this BMW turbo stuff works because im new to this but im sure with all the money you guys pay for this stuff it is equal if not better than what was on my integra.
JJ
You're not driving hard enough unless your check engine light is on
Old 10-09-2002, 02:02 PM
Rides:BmwE36, M3 motor swap
M3Turboca is a New Registered Member
Turbo Timer & Alarm
My car is a OBD I and I have a older baisc Clifford alarm with a Greddy turbo timer.
The alarm has a basic shock detector and starter disable once the alarm is armed.
Once I take the key out of the ignition I can arm the car while it is running and it will locks the doors like normal.
Once the hand brake is let down the car will shut off.
Not sure how the OBD II with the key code would work when you remove it though.
AA Stage 1 Gen III, 11.5 psi on stock compression, Custom 3.0" Exhaust no cats, AA Muffler, Bored Throttle Body, UUC Pulleys, HID 4500'K, water injection, AA 3.5"HFM, cyl & manifold porting
Old 10-09-2002, 03:18 PM
Rides:'98 BMW M3
Mark,
The EWS control unit doesnt need to see the code in the key fob once the key is removed or when the engine is running. The code is only read when starting to enable the starter, fuel injection, and ignition.
Old 10-09-2002, 06:02 PM
1985 Euro 635csi
Rides:85 Euro 635csi
LastCat is a New Registered Member
Just about how long does the engine run, after you have parked the car?
Thanks
LC
Old 10-10-2002, 01:15 AM
ESP's Avatar
ESP ESP is offline
Most any aftermarket alarm will work with the car running. You can find some more advanced alarms that have shock/motion sensors that will delay long enough for the car to stop running.
Find a competent Car Stereo/Alarm shop and they should be able to steer you right.
BTW you should never leave a BMW in a Grocery Store Parking Lot, unless you can not see the physical store from where you are parked
01 E53, 97 E39
Old 10-10-2002, 04:34 AM
Rides:A sleeper....
Thanks for the replies...
I have used UNGO, VIPER, CLIFFORD, and ALPINE all before. I DO NOT have the timer hooked into the ebrake. Can someone explain to me how I can go about doing this -- it is a greddy turbo timer. Can I just purchase the needed materials from radio shack, or, will I need to purchase a special harness unit?
My timer is currently set for 70 seconds. The problem is -- I park my car underneath in the garage in my apartment complex -- there have been a rash of burglaries and thefts recently. Sometimes I come home at 3:00 a.m. -- sometimes when I grocery shopping this worries me also. I don't park 9 miles away from everyone, I will park next to anything for the most part. I've found that if you park farther away trying to "protect" the vehicle from door dings, those people's cars usually end up getting messed with even more than if you just park with everyone else.
Mark -- my car received the OBD-I conversion, does this affect the factory alarm that is on there now then?
BMWguy -- thanks, I forgot the steering wheel locked.
I don't have a stereo system in my car (stock H/K system) -- it's just the fact it'll give me more piece of mind. The only reason why I am thinking about this is that a couple of weeks ago, I was in a grocery store, and I got out of the car and was walking into the store and turned around. I saw a group of 4 individuals, maybe admiring the car but all were crowded around it. A car running by itself......poses to me, temptation to some people....and right now, without glass breakage sensors and shock sensors....I'm a little worried.
If you guys have any SPECIFIC recommendations, e.g., specific MAKES and models of alarms that work particularly well with the bimmers..., please give them to me. I'll probably be purchasing one this week. I know some alarm systems are easier to install with certain cars than others.... the Viper system installed in a Lexus is a BITCH to work with....I speak from experience....
Thanks again,
James
Old 10-10-2002, 07:52 AM
Rides:Road Missle
TURBOCAR is a New Registered Member
one idea
i know on my alarm (avital phoenix) you can set it to active or passive arming..
in active arming as soon as u hit the arm button its armed, but in passive arming it delays 30 seconds before it arms.
so then youd have 30 seconds i know its not 70.
now have you ever thought of the problem of if it arms, while the eninge is running, when the engine stops it might set off the alarm??
well luckily my alarm waits about another 30 seconds after it passive arms for the sensors to work good..
so try that.
surely in that 30 seconds you wont be all the way in the door yet. just turn your head and look when you go in the door. if you see someone hopping in hit the panic button or something.. hehe
Old 10-10-2002, 02:49 PM
1 wire to connect.
All you have to do is connect one more wire to the park brake handle.
You do not need any additional harness to do this.
Just make sure that your shock detector is not too sensitive that when the motor is being shut off it does not trigger it.
The timer you can set to run for any time and it will not affect the alarm when you leave the car running and arm it. There is no need to have the alarm have any delay in arming.
Go to brake switch.
http://www.greddy.com/Technical/TurboTimer_Frame.htm
Hope this helps.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
