Old 10-05-2002, 08:00 PM
Rides:M3
Spencer is a New Registered Member
Stand Along ECU ?'s
Sup guys,
It seems that my only option for software to go with my RMS Stage 2 S/C kit is going to be AA, after hearing even MORE stories of shaddy tuning from RMS.
AA wants $799 for their S/C software. They guarentee a flat a/f curve, and will re-do the software til its right. Obviously something I expect at that price.
I also have some money invested in a UNICHIP which I have had for a while. I figured I'd use it ontop of the software I go with if I decide that I need to mess with it at all.
Together, I'm going to have almost $1500 tied up in a chip and a piggyback ECU. So now I'm thinking at that price, I could go with a stand alone ecu.
I know the Motec is the best, but its much more $$$ than I'm willing to invest.
Right now, I'm thinking either a TEC 2 or 3 or maybe a Halteck (forget the model name, something with a 6).
Before I waste any time looking into this option, are there any huge drawbacks from using a stand alone? I like the fact that I can run a MAP sensor capable of 3 bar, not having to buy a new "chip" with every mod, and having a much higher level of capability over the stock ECU.
Basically my plans would be to add cams to the S/C system in the next year, along with large tube headers, and a full 3/3.25 exhaust system along with a high flow intake manifold. Obviously the AA software isn't going to run with these mods. And I know they dont have any software maps for these mods.
Do you guys think a UNICHIP would be sufficient to compensate for these mods?
Any ideas/comments on stand a lone ECU's would be appreciated.
Thanks.
Old 10-05-2002, 08:12 PM
FEDERAL AGENT
Rides:1995 m3
95sdm3 is a New Registered Member
i have a friend that is putting a link stand alone system in his turbo golf vr6. they chose that over the tec system because a couple of customers were complaining about it. the dta system i have heard mixed reviews. as for the link system, it is from a company in australia and i thing they are more geared to vw/audi. i have another friend with a turbo e46 330i that is running the unichip, but he is not done tuning the car on the dyno to really tell results.
"Ahhh...Much Better!!"
Old 10-05-2002, 09:02 PM
Rides:'94 325is
SoGold is a New Registered Member
couldnt you just add an Apex-i S-AFC and dyno tune it? you can pick up a used one for 250 and with a little tuning you could have that "perfect" a/f curve and it could adapt to each mod. you could also tune it without a dyno if you feel like forking over 700 or so for a wideband o2 sensor (FJO).
Mods: BMP Intake, TMS Big Bore TB, Remus Exhaust, Dinan Chip, M3 Short Shifter, Inpro Ellipsoids
Old 10-06-2002, 07:45 AM
Rides:87 325is
RageHard is a New Registered Member
The Haltec E6K is a nice unit, does not have a Knock Sensor IIRC
The TECII is a good unit, knock sensor, coils and will drive low Impedence Injectors but is a little exposed when mounted, The TECIII has solved this.
Hand's down the best EMS is the FJO Unit
http://www.fjoinc.com/automotive/341Bdetails.htm#341B
Made with military spec connectors and more features than you'll ever need.
If your running OBDI then the unichip should provide enough control, it'll raise the rev limit control fuel and spark and can drive 1 additional injector. I dont think it likes the OBDII System much though as most of the tuning is un-learned.
One oif the biggest concerns is finding a shop with tuning experiance and base maps, once the unit is setup you can then tweak it yourself.
Old 10-08-2002, 01:03 PM
Misterdvs's Avatar
Island Boy
Rides:2002 Hubbard BZ
Misterdvs is a New Registered Member
Old 10-09-2002, 03:58 AM
Rides:Dinan3 Supercharged330i
mooreta is a New Registered Member
Another option is the AFC and MSD ignition. This is cheaper than the stand alone, allows you to modify the fuel and timing to tune the car the way you want. I have the ESS SC and am in the process of adding a FMIC. I will have to add those item just to keep things in check. If you like I'll let you know how it works...
Old 10-09-2002, 05:10 AM
Rides:M3
I'd rather run a UNICHIP than that setup. Remember, with an MSD ignition you have to run TWO DIS-4 boxes, because MSD doesnt make a distributorless ignition box for 6 coils. So you run 3 coils on each box. So if you want to get plug-in's for ignition timing, etc, then you'll have to buy two of those also. It will become very expensive very quick.
And its not like our cars need an upgraded ignition anyways.
Old 10-09-2002, 05:49 AM
Rides:'98 BMW M3
That depends on what type of forced induction you're using and how much boost or shot of nitrous it'll be putting out.
Old 10-09-2002, 05:51 AM
schnazzy's Avatar
Porn Cinematographer
Rides:.
schnazzy is a New Registered Member
Another fuel system is the SDS fuel syste www.sdsefi.com.
Their system is about $1000 retail, it is easy to setup and has a breakout box instead of requiring a pc and software.
A local shop puts these in all the time. They also do Apexi and Motec but those systems take longer on the dyno compared to this system. Most of the cars they put them in are Subaru's and toyota supras. (really fast supras). For a motec system installed and dyno tuned they said it costs about $4000+, for an SDS with the same features used < $2000. Retuning for a new part is super cheap, for a very clean tune when adding major components they recoment a new dyno tune but it isn't a lot of time on the dyno. They do 2nd gen supra's with custom turbos/exhaust etc in less than an hour dyno (note, they have done a few) plus the few hours of install.
Most importantly pick a GREAT installer/tuner.
I bet AA can do a chip for whatever mods you do. RMS can do the same thing. RMS is more of a supercharger company and AA is more of a turbo company. Both can do the software but if you don't feel great about shipping chips in the mail, then a standalone may be for you (with mods).
I am no chip tuner (yet ;-)) so I can't tell you how good or bad AA or RMS are, but I know they have the equipment and have experience.
http://www.schnazzy.com
Old 10-09-2002, 07:02 AM
Twin Screw Jockey
Rides:1997 M3/4 + other
Coupla things, first of all, the OBDII DME does not "unlearn" anyhing. It does adapt, however the only way things get changed enough that anyone could consider it "unlearning" is if you do not tune the closed loop settings properly, such that the open loop settings then get altered due to the closed loop corrections being applied. If you tune it properly, your settings will "stay". The OBDII system does not magically "rewrite" the engine software like so many people seem to think...
Also, the S-AFC will NEVER give you a "flat AFR" curve as someone mentioned. The thing does not even come close to having enough resolution in its "maps" (and I use the term loosely) to allow proper tuning of all operating points. I am not knocking the AFC for what it is, as it is a nice piece that provides some self tuning capability, but if your base maps in the car are not close, it will not provide you with enough adjustability to get all areas of operation tuned correctly.
Of course, all of the above is just my humble opinion!!!!
Steve
Old 10-09-2002, 08:07 AM
E36M3's Avatar
Rides:E36M3 3.3 OBD1, RMS Stg3
E36M3 is a New Registered Member
I am sending my car up to Vic Sias later this month in San Jose since he has done several TEC3's on BMW's...both OBD1 and OBD2.
The reason I chose a TEC 3 was because it had multiple outputs which I can use.
I don't see a reason to simply invest in a AFC if you need a management system that controls boost, water injection, etc. AFC is just that...air and fuel. If you have needs other than air and fuel, you need something more sophisticated.
By the way, I have noticed with some tuners in our industry that they focus too much on fuel and not enough on timing. Remember that not enough fuel will lean you out...but so will TOO MUCH TIMING.
E36M3's Avatar
I am sending my car up to Vic Sias later this month in San Jose since he has done several TEC3's on BMW's...both OBD1 and OBD2. www.siastuning.com
Old 10-10-2002, 11:19 AM
paul e's Avatar
Rides:'99 SC M3
Steve, maybe you or somebody else can comment on this aspect of tuning. We all know that Dinan employs their Turbotronics-9 device which is an HFM Signal scaler. Im not calling it an HFM 'Clamp' here because there is some conjecture as to whether this device only functions as a clamp, or in some other ways scales the signal. Im guessing its the latter, and not a simple clamp, but I dont know for sure. But regardless, the point is that it keeps the HFM signal from exceeding 5 Volts, and triggering a CE light. I believe rMS uses their own version of this device, again preventing the CE light.
So, what happens if you decide to use one of these stand alone units...HOw is this 5V limit dealt with. Then, there's the question of guys like AA (well, there are really no other guys 'like' AA, so lets just say, 'Then theres the question of AA...). How do they keep the signal from exceeding 5 volts? Or, can they reprogram things so that 5 Volts is no longer the problem that it is now? ie, I dont know how high the signal will go with, say, an 11 psi system, but my clamp triggers at 6000 rpms. Lets say hypothetically that without a clamp device, it'll go to 7 volts at redline on a CF type blower. When they write their dme software, do they rewrite this CE trigger point? Or is this beyond their control. And, if they can rewrite it, then why didnt Dinan or RMS do so?
So, I guess its a two part question: First part deals with stand alone units like those mentioned, and the second deals with AA, and how theyd like approach it.
Paul E
Old 10-10-2002, 11:44 AM
Rides:M3
Most of these stand alone systems replace the HFM setup we have with a 2 or 3 bar MAP sensor so there is no problem with maxing out.
As far as AA goes, I spoke with Tong (tkm3) a week ago about some S/C software. He claimed that the euro hfm, which they use on higer boost applications will read up past 12 psi, so it really never hits the 5v clamp.
Also, from my understanding, the HFM wont send out more than 5 volts, so even if you setup the ECU to read above 5 volts, the HFM would basically stop reading at 5 volts.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
