  #31 (permalink)
Old 10-10-2004, 09:25 PM
paul e's Avatar
Rides:'99 SC M3
>>I really I want to get to 12 Psi <<
I really dont think you do! 11 psi would be a better max, supported by some charge air cooling.
>Is 170 F Intake Air Temp to Hot?<<
Its typical of SC cars without charge air cooling.. Is it too hot for what? Too hot for good power? yup.. Too hot for good, safe engine running with max advance without pinging? yup. Too hot to not install some charge air cooling? Definitely yup
Paul E
  #32 (permalink)
Old 10-10-2004, 09:31 PM
Banned
Rides:BMW S/C 540i 6 spd.'95 and BMW 535i 5 spd.'90
Jimmyz2 is a New Registered Member
"guess from who?
I love his hardware , hate his software.I have finally liberated myself from Osh. I am getting Nick G software tomorrow. Cannot wait.Nick G's reputation and courteous service to me makes know the oldtime a-holes are out, and the new generation Nick G's of the world are in.. "
I'd say from Nick's Dad. Sorry for the OT.
  #33 (permalink)
Old 10-10-2004, 10:52 PM
Rides:e36m3,e46m3,e28m5,mini-s
littlefeat is a New Registered Member
resurection of the dead topic
Originally Posted by NickG
Wow, talk about resurrecting an old thread........lots of things have happened that makes some of the info given in this thread outdated.
Chad, your AFR values actually look pretty darn good. There really isn't anything needing change there.
I am now able to reprogram the MS41 OBD2 BMW ECU to handle DOUBLE (or any factor actually) the airflow of stock. This means the ECU can now handle airflow readings as high as 2000+kg/hr. I can effetively use any mass air meter that I like, because I have complete control of the ECU's code and maps. No more clamps or fancy electronics required in order to run high-capacity meters, which means no Check Engine lights either
As an example, in my OBD2 turbo kits, I'm using a custom calibrated blow through mass air meter (which I specify the flow curve to) that can measure over 500hp worth of airflow before 'maxxing' out. When I install it on my stage1 kits (running 8psi), the signal only gets to around 3.85v. The meter still has PLENTY of range left before going static. This also means that the ECU can adjust the mixture for different boost levels and ambient conditions, since the MAF has the resolution to detect the differences.
As an example, in my OBD2 turbo kits, I'm using a custom calibrated blow through mass air meter (which I specify the flow curve to) that can measure over 500hp worth of airflow before 'maxxing' out. When I install it on my stage1 kits (running 8psi), the signal only gets to around 3.85v. The meter still has PLENTY of range left before going static. This also means that the ECU can adjust the mixture for different boost levels and ambient conditions, since the MAF has the resolution to detect the differences.[/QUOTE]
Dear Nick
I'm new on this forum so I'm just getting to know some of the members and how they are tuning the obd ii M3. What type of sensor are you using to widen the airflow range? At what airflow ( CFM or kg/hr) will it reach the opp limit? I'm assisting a young man with a turbo project and we will be researching many avenues.
LF
  #34 (permalink)
Old 10-11-2004, 05:29 AM
Rides:2001 BMW 330ci
NickG is a New Registered Member
Originally Posted by littlefeat
Dear Nick
LF
The mass air sensor I'm using is proprietary and custom made to my specs. The sensor can be used because I'm able to change the actual operating code, not just the maps, in the MS41 ECU, to handle the increased flow.
Nick
Technique Tuning, Inc.
Forced Induction BMW ECU Tuning
  #35 (permalink)
Old 10-11-2004, 10:34 PM
Rides:95 M3
EpDarks is a New Registered Member
Nobody has mentioned AEM EMS yet? Not bad at a grand or so...
  #36 (permalink)
Old 10-11-2004, 10:42 PM
it's just coming out for the bmw. Not much info on it yet.
  #37 (permalink)
Old 10-11-2004, 11:16 PM
opperating code?
Very nice.
What do you mean by opperating code? In the sensor or the ecu?
  #38 (permalink)
Old 04-14-2009, 11:36 AM
Rides:BMW 328 99
driftspin is a New Registered Member
Finally i found a topic on the right subject. :-)
I read a few things here off my intrest and need some advice please.
I live in The Netherlands and want to go for a rotrex setup.
I prefer the front mounted I/C setup. I am aiming for the 320 Hp mark
The car is a sub 100K miles 328i 1999.
The kit is somewhat like the AA kit.
The thing is, i have some doubts about the tune the tuner offers here.
After setting up 8PSI with bigger injectors and frontmount intercooler.
They want to go for the added resistor setup on the sensor / oem ECU.
Then remapping/programming the ecu to get it working together.
I understand AA connects the airflow meter without any mods.
Some questions were asked before but awnsers are not quite clear to me yet.
1 Can the oem ecu handle the Supercharger setup? and if yes does it calculate or guestimate the injector and ignition timing in the higher rpm range under load or can it really measure the airflow with the oem sensor?
Or can i use the M3 / M5 sensor orso and hook that one up to the ecu?
Ive heard when the ecu is "tricked" (by a resisitor for example) it is remapped 1 dimensional and wont compensated the variables like outside temp cold start and so on.
and some less important questions
2 Do i really want the frontmount intercooler? AA does a 320 hp setup w/o front mount.
3 I hear rumors about rear axles that have intensional weakpoints is this true? I cant find any info on this subject
4 Can i use the e46 330 clutch (and twinmass flywheel if needed) on the m52 engine?
Thanks in advance
Driftspin
PS the car is a daily driver but will be driven hard 10% of the time maybe some circuit visits so i want a reliable but cost effective way to tune this setup.
If aftermarket ecu or any add-ons do the job it might be a good solution too.
Open for Mothers Day Dinner
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737
